Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. animal8324
    animal8324
    from nj
    Wired up all 4 coils to both distributors today. As soon as the fuel pump gets back she'll have all 24 spark plugs firing! 20240525_152542.jpg
  2. animal8324
    animal8324
    from nj
  3. Ziggster
    Ziggster
    Found a YT vid of it.
  4. atch
    atch
    Today I ate lunch at a small town restaurant about an hour east of where I live. Across the street are the remains of a very BIG very old chain drive truck. The differential and the ***ociated shafts/sprockets were missing. Someone with a lot more money, energy, and youth than me could probably turn it into something really cool. I didn't see any stampings or markings that would help identify it. Rear brakes were mechanical and it appeared that all the rods/linkages were intact. Front had no brakes. Rear spring packs had 16 leaves per side. I didn't count the front springs. Pics:
  5. patsurf
    patsurf
    chain drive mack?
  6. atch
    atch
    @patsurf,
    While you were posting I edited and added more information that might help someone knowledgeable to make identification.
  7. patsurf
    patsurf
    chain drive AND A diff!?
  8. atch
    atch
    Well; you can see the differential housing between the frame rails. The "axle" housings that go out to outside the frame are still there, but the actual shafts and sprockets are missing.
    I'm only guessing that that housing held a differential. I have no idea why it "faces" upward instead of forward.
  9. Ebbsspeed
    Ebbsspeed
    Possibly a "worm drive" type of ring and pinion? The housing orientation would lend itself to that type of arrangement.
    Blown Red Ram likes this.
  10. animal8324
    animal8324
    from nj
  11. SS327
    SS327
    What was all that knocky, grindy noise?
  12. animal8324
    animal8324
    from nj
    Alot of things lol
    Sprockets kissed on the right side. Frame bottoms out pretty easy. Smashed a brake line. Carbs need rebuilt.
  13. SS327
    SS327
    Bet it feels good to run it around the block.
  14. animal8324
    animal8324
    from nj
    Absolutely awesome!
  15. atch
    atch
    I've been following along since you first posted about this project. I'm blown away with the engineering and solutions involved.
    Good work and I'll be watching to see another video when you get the rest of the bugs worked out.
    chryslerfan55 and Thor1 like this.
  16. animal8324
    animal8324
    from nj
    Thank you very much
  17. chiro
    chiro
    Very cool. The first ride is always awesome.
    Andy
    41 GMC K-18 likes this.
  18. animal8324
    animal8324
    from nj
  19. chiro
    chiro
    Noice!!! Are you double-clutching that beast?
    Andy
    46international likes this.
  20. animal8324
    animal8324
    from nj
    No just driving it like a normal car
  21. animal8324
    animal8324
    from nj
  22. animal8324
    animal8324
    from nj
  23. ratrodrodder
    ratrodrodder
    from Boston
    This thing continues to be freaking awesome!
  24. animal8324
    animal8324
    from nj
    Thanks
  25. animal8324
    animal8324
    from nj
    The Beast of the Valley will be running in the Fins And Films Dirt Drags next weekend in Ostrander MN. If you can make it stop on out it's a blast! FB_IMG_1717026097018.jpg
    chryslerfan55, brEad, Thor1 and 4 others like this.
  26. animal8324
    animal8324
    from nj
    Well I gave the Beast 3/4 throttle on pavement and my mock up axles didn't like that very much. Getting them machined and sleeved now. Screenshot_20240720_200837_Gallery.jpg
  27. SS327
    SS327
    Those axles look like some serious beef.
  28. Ebbsspeed
    Ebbsspeed
    The axles and differential are from a '28 Plymouth rear per the original poster. He narrowed the rear housing, then cut and welded the axles to the required length. Looks like the break is right at the weld.
    The rear differential from a 28 plymouth will be connected directly to the trans and speockets will be mounted on the axles which will be connected to the rear wheels via chains
  29. animal8324
    animal8324
    from nj
    This is correct. I always meant to sleeve the axles..... but I didn't.... I'm surprised it held up for as long as it did.
  30. animal8324
    animal8324
    from nj
    Got my VIN today. ***le should be produced soon!
    tb33anda3rd, pwschuh, brEad and 4 others like this.
