Hot Rods Cody Walls Builds 32 Ford 3 window coupe “The Ardun Killer “ .
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Aug 21, 2019.
  1. Bcap55
    Bcap55
    from PA, USA
    Thanks for sharing this. I really like seeing lead work, and the belly pan is a great idea.
  2. oj
    oj
    Great detail & finishing, you make it look easy.
    I have a question, when doing your lead work, how do you neutralize the acid in the tinning butter & flux? I just have a hell'uva rustball to deal with the day after doing lead and avoid doing lead for that reason.
    I use Johnsons' tinning butter and liquid flux.
    Thanks, Oj
  3. vilanar
    vilanar
    from Finland
    Thank you for the progress photos. I always enjoy to see how others do they things. Awesome attention to details.
  4. Cody Walls
    Cody Walls
  5. Cody Walls
    Cody Walls
    It’s been a busy weekend. Finishing up the metalwork on the body . Sandblasting a priming . Also a very small portion of chrome parts a piece started showing up from Jon Wright Custom chrome plating . An if your wondering I’ve sent out almost 150 pieces to get chromed including the firewall .
    Stogy, Outback, porkshop and 10 others like this.
  6. Cody Walls
    Cody Walls
    Just water . I’m using Johnson’s flux a solder . But I still have the fuzz . Just sand it a lot .
    Stogy, porkshop, brEad and 4 others like this.
  7. The37Kid
    The37Kid
    Really nice project, no idea why it took me so long to find it. Bob
    Stogy and Outback like this.
  8. primed34
    primed34
    I like it!
    Stogy likes this.
  9. oj
    oj
    I posted the question on AllMetalShaping and they reminded me to wash with baking soda (I knew and forgot that) and after filing they say to hit it with ospho. I haven't tried the ospho step as yet. How much do you mix the liquid flux with? I tried it straight up the first time I used it and my whole shop was a horror the next day! Since then its been 50-50ish and it still affects stuff quite a ways away.
    They also said not to use aluminum oxide sand paper on the lead, you'll have a reaction that shows up after paint. I expect you just use a file.
    Stogy, Outback, rod1 and 2 others like this.
  10. Cody Walls
    Cody Walls
    Sounds like we’re using two different fluxes . I’ll send you a message
  11. Cody Walls
    Cody Walls
    IMG_8502.jpeg Progress . Yes it has filler in it .
    Stogy, winduptoy, Outback and 21 others like this.
  12. Bcap55
    Bcap55
    from PA, USA
    Don't all hot rods have filler on them. Mine sure does. Gonna be a great ride Cody
  13. milwscruffy
    milwscruffy
    Only if you want and like them straight. :D
  14. milwscruffy
    milwscruffy
    Cody, how does the inflatable spray booth work out for the bodywork ? Are you wearing a mask while in there sanding ?
  15. Cody Walls
    Cody Walls
    It works out well . Contains about 95%of the dust inside. . yes I do .
    Stogy, Outback, porkshop and 3 others like this.
  16. Needs a Hilborn injected Olds motor. Hehe.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Did Olds even build an inline SIX motor?
  18. Dick Stevens
    Dick Stevens
    they built a flathead inline 6 up til 1950
  19. 1low52
    1low52
    Nothing against 'injected Olds' but this thing has already pegged the cool meter!
    Tim
  20. Cody Walls
    Cody Walls
    IMG_0145.jpeg IMG_0115.jpeg IMG_0111.jpeg IMG_0114.jpeg IMG_0021.jpeg IMG_0015.jpeg IMG_0013.jpeg IMG_0010.jpeg
    BigJoeArt, brigrat, Stogy and 32 others like this.
  21. GirchyGirchy
    GirchyGirchy
    from Central IN
    Oh my; what is that, a light silvery blue with a gold pearl?
    Stogy, chryslerfan55 and Just Gary like this.
  22. 1low52
    1low52
    I'm color blind and I like it:)
    Stogy and Just Gary like this.
  23. rod1
    rod1
    Wow. Cubic hours .It's going to look amazing .Already does. Your Rotisserie-frame jig is way cool. Thanks for taking us along .
    Stogy, Just Gary and chryslerfan55 like this.
  24. drdave
    drdave
    The details Cody, the DETAILS! The radius on the boxing plates, the radius on the spreader bar mount and let's not even start on the spreader bar itself. Just amazing!!!
    Stogy, Outback, brEad and 10 others like this.
  25. 57tailgater
    57tailgater
    from Georgia
    ^^^^^I CONCUR!!!! ^^^^^
    Outback and chryslerfan55 like this.
  26. Bcap55
    Bcap55
    from PA, USA
    I'm lovin the spreader bar design. Nice job.
    Stogy and Kelly Burns like this.
  27. Nostrebor
    Nostrebor
    Re Dic U Lous!
    Thanks for the continued share.
    Stogy, drdave, RatPwrd and 1 other person like this.
  28. Cody Walls
    Cody Walls
  29. patsurf
    patsurf
  30. Cody Walls
    Cody Walls
    With the binks #7. It’s bluer a the metallic stands up way more .
    The iwata makes it more silver looking a the metallics lay down . Which I don’t want.
    binks #7 for the win .
    rod1, Stogy, winduptoy and 11 others like this.
