Technical Banjo ID
Discussion in 'The Hokey Ass Message Board' started by Binderman01, May 28, 2024.
  1. Binderman01
    Binderman01
    Can anyone ID the banjo year? I haven't had a chance to get a measurement from it. I ***ume 40-42 but figured someone could tell based on wishbones PXL_20240528_154502157.jpg PXL_20240528_154510253.jpg
  2. alchemy
    alchemy
  3. Binderman01
    Binderman01
    You mind sharing what set it apart for future reference?
  4. alchemy
    alchemy
    Solid wheels, so not a 39. No extra boss on the spring hanger, so not a 41.
    The general shape and size of wishbones, housings, and torque tube are the same from 37 to 40. Some internal differences include a ten spline pinion up to some time in 38. But you have juice brakes so it would have to be at least 39.
    I still say 1940.
    Speccie, AVater and wheeldog57 like this.
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    "42 - "48 had a thing on the right side that looks like a modern shock mount stud. Right by the spring hanger. That stud is for the rear sway bar. That sets it apart from the earlier models. Also the pinion to driveshaft coupler is different, 10 spline vs 6 spline.
