Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. BamaMav
    BamaMav
    from Berry, AL
    That’s what they make hood scoops for…:p:p:p
    Tow Truck Tom and scotty t like this.
  2. MCjim
    MCjim
    from soCal
    when I got my first Corvette, a 1960 with the "powerful" 283, I had to run right out and get a "hi-rise" intake and a Holley double pumper down at Gratiot auto supply...oops, the hood don't close. So I spaced up the hood latch mounts on the back about 2 inches...the original cowl induction. Look closely, best picture I got.
    brEad, enloe, bchctybob and 7 others like this.
  3. lumpy 63
    lumpy 63
  4. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Squirrel
    If you can use it it’s yours. I’ll put it in an envelope and send.
    brEad, enloe, Deuces and 8 others like this.
  5. DDDenny
    Wasn't a problem for Paris Fish!
    Driver50x, brEad, enloe and 10 others like this.
  6. 427 sleeper
    427 sleeper
    ^^^^^ That look's just about Perfect!!! ^^^^^
    enloe, Deuces and lumpy 63 like this.
  7. scoops are cool
    Spoggie, oldandjaded, brEad and 13 others like this.
  8. swade41
    swade41
    from Buffalo,NY
    My friend has the teardrop on his too
  9. lumpy 63
    lumpy 63
    49986.jpeg In case I ever pull the tunnel ram...
    brEad, enloe, bchctybob and 11 others like this.
  10. lumpy 63
    lumpy 63
    Back to regular Squirrel programming now:D
    enloe, Deuces, Sharpone and 7 others like this.
  11. squirrel
    yeah....
    getting closer, it has oil to the rockers now.
    brEad, enloe, bchctybob and 13 others like this.
  12. swade41
    swade41
    from Buffalo,NY
    What is that thing on the front ?
    enloe and Sharpone like this.
  13. squirrel
    the motor mount?
    enloe, Deuces, Sharpone and 1 other person like this.
  14. swade41
    swade41
    from Buffalo,NY
    I'm going to have to look up the engine bay to see what that attaches to.
  15. wrenchbender
    wrenchbender
    No worries on the hood just hang it on the wall when you install the supercharger lol looking good Jim I’m currently putting together the same basic engine for a 40 ford coupe can’t wait to see how good it runs
    enloe, Sharpone, SS327 and 5 others like this.
  16. patsurf
    patsurf
    that was quite a few yr's--water pump doing the" hurst" job of motor mount-wasn't the best...
  17. squirrel
    62 was the last year of that nonsense.
    periodic maintenance: torque the water pump bolts, so the engine don't fall out
    Spoggie, bchctybob, Deuces and 11 others like this.
  18. lumpy 63
    lumpy 63
    Scotty just got a refresher course on that subject:p
    bchctybob, Sharpone, SS327 and 4 others like this.
  19. I was a day late on my periodic maintenance but i got lucky and got away with just tightening the pump/mount bolts. No leaks so far and i HAVE been banging gears:D
  20. squirrel
    if you spot the drips before it gets too bad, you can save it :)
    brEad, enloe, bchctybob and 8 others like this.
  21. DDDenny
    I had "the drips" once in my twenties:eek:, got them again in my (almost) 70's, albeit for different reasons.
    enloe, '28phonebooth, Deuces and 5 others like this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I hear whispers of Cheech and Chong now.
    enloe, Deuces, Sharpone and 3 others like this.
  23. Mitchell Rish
    Mitchell Rish
    from Houston MS
    This in itself is a history lesson. Keep on teaching. Lol
    enloe, Deuces, swade41 and 4 others like this.
  24. squirrel
    Time to fiddle with the distributor. The cam says I have to use a plastic or melonized gear, so I bought a melonized gear.
    The advance was still not right after the last go round with it in December...too much mechanical advance. I backed off the initial some to keep it from pinging. Since I had to get the shaft loose to change the gear, I decided to look into the advance again. I had installed a rather thin plastic bushing, and had purchased a br*** Moroso bushing as part of a weight kit, but never installed the bushing. Reading more on the vette forum about how to deal with this, I decided to make as big a bushing as I could to fit in there, and now it feels like it's gonna be a lot closer to what I want. I may have to change springs again, but the travel should be right. Since I don't have a distributor machine, I'll check it with the timing light once I get it running again, and go from there.
    Bushing dimensions are 0.183 ID, 0.295 OD, 0.205 long. Everyone needs a lathe.
    Now...on to the carb....I need to figure out the new PCV setup as well as rebuild it....then I can put it all together.
  25. Oneball
    Oneball
    I’ve got the largest bushing I can fit in my distributor on the race Vette, and the lightest springs I can get away without the timing floating when you rev it, with 36deg all in it means I’m running mid 20degs initial.
    enloe, Tow Truck Tom and Sharpone like this.
  26. squirrel
    that sound perfect :)
  27. MAD MIKE
    MAD MIKE
    from 94577
    Engine out, ideal time to get in the engine bay and figure out where all the air leaks are to improve on cooling.
    Especially since you're gonna add more heat underhood.
    enloe and Tow Truck Tom like this.
  28. squirrel
    heh...I know where they are, but I don't think it'll make enough of a difference to bother. I kinda need 50% more radiator, which is hard to fit in there, the way the car is built.
  29. squirrel
    I finally made a tool to hold the flywheel still. Almost ready to drop it in....
    rod1, brEad, enloe and 19 others like this.
  30. Oooh, the colors clash!
    427 sleeper and Deuces like this.
