Art & Inspiration How old is chrome plating?
Discussion in 'The Hokey Ass Message Board' started by goldmountain, May 29, 2024.
  1. goldmountain
    goldmountain
    All I really know is that the process predates me. In my Bible, in 2 Chronicles 4:9 it says "He made the court of the priests and the great court with its gates and plated the gates with bronze." Industrial processes amaze me.
  2. Unkl Ian
    Unkl Ian
    According to Wikipedia: "Electroplating was invented by Italian chemist Luigi Valentino Brugnatelli in 1805.".
  3. Oneball
    Oneball
    Chrome plating on cars started in earnest towards the end of the 1920s prior to that brightwork was usually nickel plate.
    Your biblical quote is about attaching sheets of metal to a wooden gate.
  4. Hammering sheets of gold or silver and electro plating are 2 different things.
    wonder if I can hammer a sheet of chrome?
    Could use aluminum foil
  5. goldmountain
    goldmountain
    How did the world work without wikipedia?
    shorrock and JohnLewis like this.
  6. Oneball
    Oneball
    Like this, someone asked a question, someone else knew the answer.
    I know about the gates thing from going to the British museum and seeing the ***yrian gates there.
  7. JohnLewis
    JohnLewis
    Use to be these books called encyclopedias.
    Algoma56, CSPIDY, Mr48chev and 17 others like this.
  8. Unkl Ian
    Unkl Ian
    Some things were harder, a lot of stuff was the same.
    Some people are smarter now, and a lot of people are at least as stupid as they were then.
    Dirty Dug, Driver50x, RMR&C and 8 others like this.
  9. It’s kinda like the tin foil on the chocolate money and Easter bunny’s
  10. '51 Norm
    '51 Norm
    from colorado
    on a related note, I have always wondered why the change from nickel plated to chrome.
    Unkl Ian likes this.
  11. Unkl Ian
    Unkl Ian
    Guessing that Chrome is more durable, long term.
    Also more shiny, done correctly.
  12. 56don
    56don
    I am no expert but I "heard" somewhere that nickel would tarnish over time and chrome did not.
  13. Bert Kollar
    Bert Kollar
    I believe the chrome is a sealant
  14. '51 Norm
    '51 Norm
    from colorado
    I was wondering because I have been doing nickel plating in my garage and so far I can't tell the difference between it and chrome. Maybe I'm looking at it wrong.
    bobss396, Unkl Ian, 29A-V8 and 2 others like this.
  15. willys36
    willys36
    Quality chrome plating is 'triple plating'. First coat is always copper. Think of copper as hi-build primer. it is plated on quite thick then polished to perfection eliminating any defects in the finish. Nickle is the main finish coat and is next in thickness. As mentioned above, if plated over properly prepared copper, nickel will look nearly as good as chrome but does have a slightly yellowish tint and it does tarnish and dull over time. Enter chrome. Think of chromium plating as the clear coat. It is just flashed over properly bright nickel. Nickel is still the 'color coat' and chrome just adds the pretty blue tint and doesn't oxidize as nickel does. Typical quality triple plating will have layers approximating this; 0.005” of copper, followed by 0.001” of nickel, then 0.00001” of chromium.
  16. Mike Lawless
    Mike Lawless
    And then there is "Hard Chrome." This process plates chrome directly to the base metal and is used for a hard finish in high wear areas such as hydraulic rams, plungers, pump shafts, extrusion dies, and other things. It can be build up fairly thick. Just takes time. Where decorative chrome gets a few minutes plating time, a piece getting hard chrome can be in the tank for hours.
    My father was a hard chrome plater during WW2 and through the 60s. I worked in his friend's hard chrome shop when I was young, in the 70s and early 80s.
    Nasty, nasty stuff.
  17. Dan Hay
    Dan Hay
    Funny you posted this, I saw these in person at the British Museum on Monday, flew home yesterday.
  18. The37Kid
    The37Kid
    You had to polish nickel to make look as new, chrome not so much.
    Tow Truck Tom likes this.
  19. clem
    clem
    thanks for the explanation, - I never knew there was a difference, but had wondered about it !
  20. Bandit Billy
    Bandit Billy
    I love chrome. I told my wife I liked the chrome streaks in her hair. That one cost me a trip to the salon. :cool:
  21. 51504bat
    51504bat
    You're lucky it wasn't a trip to the ER:cool:
  22. Bandit Billy
    Bandit Billy
    :D:cool: In the end it worked out, she went for a summer blonde look. Feels like I'm cheating!
  23. Unkl Ian
    Unkl Ian
    And when they say HARD, they mean it. Not fun to try and machine.
  24. Unkl Ian
    Unkl Ian
    You do your own electroplating ?
    Or "Electroless Nickle" ?
  25. Fortunateson
    Fortunateson
    Well stated and explained! The bright work on cars followed the same sequence: first it was br*** then it was nickel and finally chrome. Maybe I should add powder coating and wrapping for those who can bear the cost of triple chrome.
    dana barlow likes this.
  26. '51 Norm
    '51 Norm
    from colorado
    Yes, electroplating. There are a number of YouTube videos that are helpful. And of course some that aren't.
    I did a number of test pieces before trying to ruin a good part. So far I have been limited to small stuff, bolts and brackets mostly.
    down-the-road, Unkl Ian and 1952henry like this.
  27. Mike Lawless
    Mike Lawless
    Really can't cut it with conventional cutting tools. Can't drill it. It has virtually no tensile strength of it's own. We had cylindrical grinders for doing shafting and surface grinder for doing flat stuff, which wasn't often. That was my my primary job. Pre-grind prior to plating to get a blemish free surface, build up with hard chrome to over the finish size, then finish grind to size. Even did some crankshafts, but they were difficult to get even plating on. No automotive stuff. BIG cranks.
    Unkl Ian and Driver50x like this.
  28. Unkl Ian
    Unkl Ian
    I used Carbide, still not easy. On the lathe, the first cut needs to be heavy enough to get under the Chrome.
    On the mill, same idea but still used up a couple Carbide end mills, to make a 3/16" wide slot.
  29. Mr48chev
    Back in 1969/70 when I was working in a plant that made things like TV dinner boxes and head an shoulders boxes there was a shop across the railroad tracks out back that redid and hard chromed railroad locomototive and probably other huge crankshafts that were brought in on rail cars. I ended up having a buddy who worked there who explained to me what hard chroming was.
    down-the-road likes this.
  30. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I believe that the Internet gives the illusion that people are dumber today because, if you look at the Internet long enough, you'll eventually see every damned one of them.
