Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. squirrel
    yeah, that's life! at least it's hard to see the ****tershield when it's in the car.
    Engine is in...now for the fun work of getting it all connected back together, and see if it will run. I still have to work on the "new" carb, too.
  2. Sharpone
    Sharpone
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    probably so he could torque the flywheel bolts
    bchctybob, Deuces, squirrel and 2 others like this.
  4. Sharpone
    Sharpone
    Duh, I said it was a dumb ? A lot slicker than the way I do them. Thanks
    Dan
  5. After looking at the above picture, I never realized how the Corvette engine mounts on the front. Are the accessory drive pulleys Corvette specific because of the front motor mount being under the water pump and changing pulley alignment?
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    there is a spacer that goes on the crankshaft before the balancer is put on. The spacer is the same thickness as the motor mount. That’s how they got the pulleys to line up
    brEad, enloe, Tow Truck Tom and 9 others like this.
  7. RodStRace
    RodStRace
    and when looking into SBC pulleys and water pumps, they have a different WP.
    enloe, Tow Truck Tom and Sharpone like this.
  8. squirrel
    There are a lot of flavors of water pumps for Chevys...they made the engine for decades, and things about the cars changed over time.
    The Corvette also uses the fitting on top, for the surge tank. Some trucks used it for a byp*** hose, too.
  9. Deuces
    Deuces
    Peter Rooter?????......:D:D:D
  10. Thank you Mark. That makes sense.
    Sharpone and guthriesmith like this.
  11. BamaMav
    BamaMav
    from Berry, AL
    All small block Chevys are alike, except the Corvette engines where the engineers did their own thing! Seems like to be a true Corvette engine something had to be different, even if it was something small.
  12. squirrel
    The mount is set up that way because the steering gear is right in the way of where the mount should be, I think.
  13. As many Corvette engines that are in hot rods, there should be thousands of those motor mounts for sale at swap meets.
  14. 51504bat
    51504bat
    I thought all SBC engines were Corvette engines?:cool:
    Deuces, WC145, '28phonebooth and 3 others like this.
  15. RodStRace
    RodStRace
    Corvette engine when selling. 283 station wagon when runnin' on the street.
  16. sidevalve8ba
    sidevalve8ba
    I thought if you just put a set of these valve covers on it automatically made it a Corvette engine! :rolleyes:
    brEad, Deuces, WC145 and 5 others like this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    7 fins, it needs a set of 9 fins!
  18. squirrel
    that's only for the 50s cars...
    Tow Truck Tom, Deuces and 427 sleeper like this.
  19. swade41
    swade41
    from Buffalo,NY
    That photo shows how it all goes together, online it seems every car has the radiator still in and blocking the view of the frame mounts.
    427 sleeper and squirrel like this.
  20. MAD MIKE
    MAD MIKE
    from 94577
    You'd be surprised what sealing a few holes and some creative ducting can do.
    Cutting a hole in the hood for a radiator duct is most likely out of the question(traditional Cunningham LeMans stye 1960-Chevrolet-Corvette-Front-Angle-740x493.jpg but that fence can be detracting. ) but would you be willing to do a front snorkel duct, NASCAR style, between grille opening and face of radiator?
    Cooling problem with most cars is simple lack of basic ducting for heat extraction. Just a giant maw gulping in air directionless. Most which just slams into a radiator support and dispersing all over the face of the radiator, with quite a bit spilling over, under, and around the radiator. Not aiding in going through to cool, just pressurizing the engine bay and heat soaking the engine.
    brEad, Deuces, '28phonebooth and 3 others like this.
  21. swade41
    swade41
    from Buffalo,NY
    When I was looking at 62's for that motor mount I ran across this one and was wondering if you have the scotch-brite option on yours ?
  22. tomcat11
    tomcat11
    That's probably a dealer installed fuel leak absorber. WoW, check that super trick carpet mount on the overflow tank with the HP flat hose:eek: Holy Moley
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    man... there is so much wrong with that picture, check out the screws holding the top of fender stainless trim on...
  24. BJR
    BJR
    Kinda makes you sad to see a Corvette treated like that.
    Tow Truck Tom, scotty t and Moriarity like this.
  25. blue 49
    blue 49
    from Iowa
    tomcat11, That flat hose looks more like a bicycle inner tube, to me.
    Gary
    Tow Truck Tom likes this.
  26. squirrel
    Anyways, thanks for making me feel good about how my car looks, it could be a whole lot worse!
    I got it all together and went for a drive. I have to do some tuning, and it has some valvetrain noise, which it probably shouldn't with hydraulic lifters!
    But the big thing now is the water leak, the temp sender hole in the intake is oversize or something. Maybe I'll JB weld the sender in place?
  27. Maybe try a bunch of extra wraps of teflon tape, we get away with that in the steel mill
  28. The fuel filter to nowhere
  29. MCjim
    MCjim
    from soCal
    The overspray is a nice touch...
    427 sleeper likes this.
  30. squirrel
    I played with a few different senders, and another random 1/2" npt fitting, and teflon tape...it seems to be getting looser. It felt ok when I first installed the sender, but it seeped water. Now anything I put in bottoms out finger tight! even wrapped with several layers of tape.
    I don't see any cracks...but the boss is not very deep, only about 4-5 threads.
