Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. dalesnyder
    dalesnyder
    Two questions for the experts, is insta binding a good subs***ute for those of us with no machine? I really like the look of contrasting binding.
    Also, I ordered some vinyl by the yard and it came mailed folded up in a bag, how do I handle the wrinkles where it was folded?
    Thanks
  2. SDS
    SDS
    Insta binding looks cheap and works marginally - doesn't like going around curves, forget about it on inside curves.
    Lay the vinyl out and use a hairdryer to ease the wrinkles out. You may not be able to get them to 100% disappear. Next time make sure they roll it vs fold it before ordering.
    dana barlow likes this.
  3. Whoamel
    Whoamel
    from So Cal
    I just got one of the EZE spray guns, and can really see how much simpler it is. I don't spray all that often since I'm not an upholstery shop, and I've gone through a couple of Harbor Freight cheapies getting clogged in the small p***ages.
    Even if the EZE gets clogged, I can see how easy it'll be to clean and get going again. I'll keep my spray guns exclusively for paint and primer from now on..
    SDS and jakesbackyard like this.
  4. Sporty45
    Sporty45
    I like the way your carpet is turning out, looks great! Is that a Gennie shifter you're using? Where did you get the trim ring? I'm using a Gennie shifter and am going to need one to fit it. I plan on sewing up my own leather boot.
  5. SDS
    SDS
    Yes, Gennie - call Nick and I'm sure he'll hook you up with just the ring.
    As a word of advice, plan in advance which orientation is best for your screw pattern. I did mine like a +, but it would've been better as an X to avoid things (linkage, wiring, etc.) underneath.
    Sporty45 likes this.
  6. Sporty45
    Sporty45
    Thanks, appreciate the heads up on the orientation too!
  7. Whoamel
    Whoamel
    from So Cal
    I don't normally quote myself, but just a heads up. Most of the EZE spray guns are offered with a plastic cup. Albright's Supply in MS has one with a metal cup and lid. I know you can see the glue level in the plastic cup, but I suspect the metal cup might be easier to clean. It might be a tad more durable, but I can't say for sure.
    I cleaned mine the other day with some acetone, and it was simple and fast.
    And remember: My advice is worth what you paid for it!
    reagen, drdave, brEad and 1 other person like this.
  8. 3quarter32
    3quarter32
    Xylene works very well for cleanup. If I happen to need the use of a brush, I keep a jar/lid to store the brushed in the Xylene.
    reagen likes this.
  9. Whoamel
    Whoamel
    from So Cal
    I don't doubt it, but I literally drive out of State to purchase solvents from Arizona or Nevada that work. The Cal-legal stuff is terrible. Both Naptha and Xylene have been banned here. I can't ever recall seeing Xylene here at all, so I ***uming it's been gone quite a while.
    Edit: I just checked, and it's NLA in California.
  10. SDS
    SDS
    Xylene is REALLY bad for you (highly carcinogenic), it can absorb through your skin and vapors are also harmful. It collects in your liver because your body tries to filter it out.
    I don't ever clean my EZE spray gun - when Weldwood landau top adhesive dries, it can be easily peeled of - it will not attack the plastic that the cup is made from. Best thing to do is just leave adhesive in the gun (not frozen or in a hot garage). The solvent from the adhesive keeps it soft. If I'm not using mine for awhile, I put a piece of masking tape over the vent and both br*** nozzles.
  11. SDS
    SDS
  12. Pat Pryor
    Pat Pryor
    Im not an upholstery guy, but I just made this 40s style interior for my buddy's T.
    Squablow, reagen, Okie Pete and 11 others like this.
  13. jakesbackyard
    jakesbackyard
    from ND
    I got talked into doing another hot rod seat. This one’s going in a deuce 5 window. Done in leather.
  14. SDS
    SDS
    jakesbackyard likes this.
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    That is *really* nice!
    Marcus...
  16. Speccie
    Speccie
    That is great work on that seat.
  17. SDS
    SDS
    I want to make some floor mats with the same carpet I have on my floor...
    What do people usually put on the back of the carpet to stiffen it up? Something with those little nubs that keep it from moving around would be great. I'm planning on binding the edge with the vinyl I used to make the seats.
    Have any suggestions?
  18. jakesbackyard
    jakesbackyard
    from ND
    I get this from yourautotrim. Works great.
    brEad, SDS and loudbang like this.
  19. Wow! I’ve been looking for a thread like this. I will be teaching myself how to do upholstery since I can’t afford what shops are asking. Have my machine and after my vacation I’ll be cleaning up the garage and setting it up to start to practice. My machine is a Mitzi LU401-25BTC. I don’t have a manual but am sure either my friend I got it from will help me out learning it.
    Damon777, RICH B, Roothawg and 4 others like this.
  20. Whoamel
    Whoamel
    from So Cal
    I'm buying old Datsun pickup seats on the cheap, and redoing them for practice. I sell them really cheap so I can move onto the next. Here's the third one I've done. I'm not too sure if I'll ever get good at it, but I enjoy the challenge, and it keeps me busy.
    It's a bland color, but the grey can go with almost any interior color. They usually sell quickly.
    6inarow, brEad, safetythird and 5 others like this.
  21. SDS
    SDS
    Put a layer of batting in there and sit it out in the sun - all those ripples and wrinkles will magically disappear. I was disappointed with mine until I did so.
    brEad and Whoamel like this.
  22. jakesbackyard
    jakesbackyard
    from ND
    brEad likes this.
  23. jakesbackyard
    jakesbackyard
    from ND
    For some reason my post is in the quote. Enlarge the quote.
    Whoamel likes this.
  24. Whoamel
    Whoamel
    from So Cal
    Thanks for the tip! That's a good one to remember.
  25. This thread is similar to one on painting. You take ugly and make it in to something to be proud of. Isn't that the basis of hot rodding? Doesn't matter about your skill level, it's about improving. :)
    Whoamel likes this.
  26. SDS
    SDS
    I'm installing my Bop Top and am going to buy a pneumatic or electric staple gun to staple the top to the oak header bow.
    In the install video, Sid Chavers uses a pneumatic stapler that appears to be a 3/8-in crown staple, thin somewhere around 20 gauge.
    Does anybody have any suggestions on exactly what staples to use and/or what staple gun to purchase for use with those (and don't come back with a reply that says, " just use a plain old stapler from Home Depot"
    Thanks,
    Scott
  27. DDDenny
    And for sure not one from HF!
    That's all I have for guidance.
    SDS likes this.
  28. Sporty45
    Sporty45
    This is the one I have. I got it in 21 gauge, but they make them in 20. Works really well and pretty sure it will be powerful enough for oak. I can test mine on a piece of oak if you would like. :)
    https://www.amazon.com/meite-MT8016..._csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM=
    SDS and RICH B like this.
  29. jakesbackyard
    jakesbackyard
    from ND
    You want a series 71 22ga. air stapler and use stainless steel staples. If you want a Cadillac get a BEA. I had a BEA for 40+ years, but it finally died a couple years ago and I couldn’t get a repair kit for my old model any longer. I bought a Numax off Amazon for $30 or so and now retired I use it only occasionally. Works great. I’ve put a few thousand staples through it with no problems.
    brEad, Tim_with_a_T, rod1 and 2 others like this.
