Technical U-joint question: what is this stuff.....
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Jun 1, 2024.
  1. Ebbsspeed
    Ebbsspeed
    .....and what is its purpose? It appears to be some sort of plastic that was injected after the caps were installed. There is a bubble of it protruding from each side of the cap ring, and it filled a groove within that ring. The caps are smooth sided, but there is a witness mark where it contacted the plastic filling the groove. 20240601_181541.jpg
  2. Just how factory gm u joints are held in. Some sort of plastic
  3. 427 sleeper
    427 sleeper
    That takes the place of the internal snap ring's that the replacement u-joint comes with. You're supposed to heat the fibergl*** with a torch to burn it out before you try to remove the cup's... Atleast they come out easier if you do it that way. ;)
    It stink's like Hell, though!:eek:
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've always heard about melting the plastic , never have done it , never had a problem...
    squirrel and The Chevy Pope like this.
  5. I've personally found that cleanup is easier if you drive them out without heat myself
    Desoto291Hemi and squirrel like this.
  6. squirrel
    amazing to find one with plastic still in it, after 50+ years of use! I thought we replaced all of them
  7. choptop40
    choptop40
    they pop when you heat them...
  8. WashBear2
    WashBear2
    I've never dealt with u-joints that had a retainer for the caps. I thought chasing needle bearings was always part of the process.
    '51 Norm likes this.
  9. bigdog
    bigdog
    It's not to hold the cap on the u-joint, it's to hold the cap in the yoke.
  10. 283john
    283john
    Broke my dads vice in half trying to press my s ten u joints apart. Neither of us had any idea about the plastic seal. Heated it afterward with propane torch just to try to loosen it up and these plastic snakes climbed out of the yoke... Freaked us out. This was all prior to people having the Internet.
    bobss396 likes this.
  11. Driver50x
    Driver50x
    Lol. Yep those plastic snakes were a regular thing back in the ‘80s.
    das858 likes this.
  12. Driver50x
    Driver50x
    My T Bucket still has both of the factory u-joints, held in by plastic. They still feel as good as new. The driveshaft came from a 1979 Malibu. It’s been shortened obviously.
  13. Budget36
    Budget36
    Just a wonderful idea GM had there. Not sure who else did it.
    I just stared at the plastic and called the Chevrolet service center in town and asked “what the heavy do I do here”?
    As was mentioned before they told “do it like you’ve done them before”.
  14. Ebbsspeed
    Ebbsspeed
    Hmm, interesting. I guess I've never seen it before because I'm always working on old Fords and Mopars. These U-joints did have the C-clips on the inside of the yoke as well, so I guess they were doubly secure, or might have been replaced at some time in the past.
  15. squirrel
    oh yeah...that one has been replaced, the plastic is only in the yoke. When you do an original, there won't be a groove for a clip, there will only be a groove with plastic in it
    427 sleeper likes this.
  16. ray
    ray
    from colorado
    I've never had much difficulty dis***embling them, however getting the plastic back in the yoke on re***embly is a major PITA.
    Driver50x, 283john and scotty t like this.
  17. bill gruendeman
    bill gruendeman
    I think if you get it cold it will shrink right up, or it could have been something else.
  18. jimmy six
    jimmy six
    The same seal was in the front bearings used in AIR pumps from 1966-on. Since they were in an aluminum housing they were easily broken when trying to repair one…
