Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. roseville carl
    roseville carl
    yep Tom your correct, heads cam, intake manifold and valve parts........
    but we got a step closer today, hope to fire up tomorrow, thanks to grandson for helping me today as the ol bon es don't work like they used to.
  2. Schramm. I have a couple.
    ottoman likes this.
  3. roseville carl
    roseville carl
    Well just thought I post something I did 20 years ago and still use it daily
    alanp561 likes this.
  4. roseville carl
    roseville carl
    And now for my enjoyment will be the following............
  5. Sounds good Carl - no go have some fun!
  6. Irish
    Irish
    A literal blast from the past! Thanks a Carl!
  7. spanners
    spanners
    Why wouldn't you be happy? Only thing left to do is park you're **** in the seat and go. :)
  8. roseville carl
    roseville carl
    Yep tha's what I am lookin to do, now just to get ready for Eagle Field and all the craziness down there!!!!!
  9. roseville carl
    roseville carl
  10. roseville carl
    roseville carl
    58 more getups for the Flathead V8 /6CYL Clash at Eagle Field come join us ........................... 20240320_094808.jpg
    loudbang and Countn'Carbs like this.
  11. AmishMike
    AmishMike
    Does that mean 58 rails are running in V8-6 cl***? Wow!
  12. roseville carl
    roseville carl
  13. AmishMike
    AmishMike
    Get it now. Get ups in morning…. Dam I got excited thinking it was rails
  14. roseville carl
    roseville carl
    Eagle Field in just 30 More getups!!!!! wahooooo just some memories from the past......... 2009 till now
    2009.jpg 2010.jpg 2011.JPG 2012 (1).jpg 2012 (2).jpg 2013.jpg 2014.jpg 2015.JPG 2016.jpg 2016A.jpg 2017.JPG 2017A.jpg 2018.jpg 2019.JPG 2020.JPG
      360.6 KB
      213.8 KB
      262.8 KB
    alanp561, Toms Dogs and loudbang like this.
  15. Harv
    Harv
    from Sydney
    Man that looks like fun.
    Can I ask a dumb*** question please Carl?
    My FED is getting closer to completion, and in between works I've been thinking through some of the track practicalities. I have the trailer sorted, fire extinguisher mounted, thinking through the tools I will need trackside etc. I'm uncertain on fuel though. The cars I have taken to the track so far have been road going. I fill them up with enough pump gas to last the event, and if I am a little low I fill them up on the way home at the nearby gas station. The FED though will run on methanol. This is my first methanol vehicle, so a little unsure on fuel handling.
    The FED will probably run once every second to third month. I know I need to flush the fuel system out with gas, and can visualise how to do that. I cannot store a 44 gallon drum of methanol, and will not have enough use to consume that volume. I am figuring on buying methanol in 5 gallon drums and storing it in those drums at home. I can take those drums to the track and topup the FED via a funnel and filter sock. Is there something I am missing here?
    Cheers,
    Harv
  16. Also, Marvel Mystery oil is your friend for things like fuel pumps, poppets, valves, etc. Lubricate pumps/valves after you flush the alcohol out of the system. If you have a fuel-filter, clean it as well. Before you race again, check all your poppets, main jets, metering valves, etc - and make sure they're in good shape. It is not a bad idea to take the pump, poppets and other such stuff off the car between races - to clean, inspect and reinstall later on.
  17. roseville carl
    roseville carl
    Harv when I was running methanol I would by it in 50 gal drum stored at house and bring 2- 5gal cans to race weekend. Made an adapter to apply 4lbs of air pressure (no more than 4!) to drum to push the fuel out to fill the 5 gal containers. Like Dale says make sure you clean it out after each race and don't leave any in system.
  18. Bandit Billy
    Bandit Billy
    Electric fan, but still pretty cool. :cool: Do you have dyno numbers with the blower?
  19. DDDenny
    Precious!
  20. Harv
    Harv
    from Sydney
    Thanks gents. Agree on the oiling part - drain alky, pickle with gas, pull off and oil anything that moves.
    Cheers,
    Harv
  21. roseville carl
    roseville carl
    don't have any dyno numbers just 117 @ 11.3 in quarter 97 + in 1/8
  22. AmishMike
    AmishMike
    Formulas on internet calc horsepower based on quarter mph & et & weight
  23. roseville carl
    roseville carl
    is it time for a new blower? 439336806_747584664029604_878284937540693628_n.jpg
  24. roseville carl
    roseville carl
  25. Looks like some good fun Carl! Thanks for posting!
  26. spanners
    spanners
    I hate watching your videos Carl. I wish I was there racing with you lot. I'd be too slow for the trophy, just be there for the grins.
    That carnage was bad. What let go?
  27. roseville carl
    roseville carl
    Yea Dale it was as usual a wonderful weekend, and my new driver Christopher had a grin from ear to ear, I think he likes it!!!
    Spanners we run it as a Bracket race so everyone has a shot at the trophy, and you are entirely welcome! Don't know the final outcome on Rons engine but he almost split the block in half, a tremendous amount of carnage. They will be back in October I'm told.
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    He should get a "Grenade Award" for that one Carl. Impressive dis***embly.
  29. Hey Carl - what engine in that? Is that the guy running the 6 Cyl rail? Any boost? Looks like he lost a rod and the "cement mixer" fired right up!
  30. roseville carl
    roseville carl
    292 with Alky injection no blower damn near split the block in half he did a 360 into the dirt about 5/8 the way down, didn't get hurt thankfully and didn't roll but came damn close to flippin her.
    jet996, KiWinUS and loudbang like this.
