Technical 49 Fleetline 235 +automatic
Discussion in 'Traditional Customs' started by Constructionbob, Jun 3, 2024.
  1. Constructionbob
    Constructionbob
    Do I have to cut up the floor to have space for a th700?
  2. Should fit stock tunnel. Will obviously be cross member modifications though
    JohnLewis likes this.
  3. brokedownbiker
    brokedownbiker
    I don't think the 700R4 is any larger than a TH350, the TH350 in my '50 Fleetline fits with unmodified floor/firewall
  4. 49ratfink
    49ratfink
    plenty of room under the floor
  5. If you have the 700, use it. If your looking for an OD trans, the 200r is bout the same size as a th350
    sdluck and The Chevy Pope like this.
  6. 700r4 is roughly same length as a long tail shaft(truck) th350. Car th350 is like 5-6" shorter
  7. Constructionbob
    Constructionbob
    THANKS to U all!!
    Now Im ready for next step. Thanks!
    Bob Lowry likes this.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Look for a later model 700R4 because they had internal upgrades that make them more desirable. Then they became the 4L60 .......same trans different name but with all the upgrades. THEN they became the 4L60E...the electronic version. You don't want that because it requires computer control. Its important to get the throttle valve (TV) cable adjusted correctly or you can burn the trans up pretty quickly from slippage. Best way is with a pressure gage. Check Utube for videos.
    The Chevy Pope likes this.
