Projects Roadster side mirrors?
Discussion in 'Traditional Hot Rods' started by KoolTeach31, Jun 3, 2024.
  1. KoolTeach31
    KoolTeach31
    Can I get some pictures of your roadster side mirrors? I need to install some and I want to see which way I should go. Thanks.
  2. banjorear
    banjorear
    dana barlow and CSPIDY like this.
  3. rustydusty
    rustydusty
    I used old motorcycle mirrors on my “T”… 5F3AC77F-98B1-4884-ACAA-D98A9B965FFF.jpeg
    oldandjaded and dana barlow like this.
  4. denis4x4
    denis4x4
    from Colorado
    I used this sports car mirror with a large convex stick on.
  5. Rice n Beans Garage
    Rice n Beans Garage
    Nice Hiboy
  6. Mr48chev
    I think I had bike mirrors on my T that weren't much different than these on Ebay. I bought them out of the box of take off mirrors at a bike shop in Waco in the 70's just as I did with the park/turn lights out of a box of take off park/turn lights on the same shelf. Screenshot (335).png
    dana barlow and KoolTeach31 like this.
  7. Bandit Billy
    Bandit Billy
    These swan necks were cut down and plated. I like them but nearly useless. I installed convex peep mirrors from Hagan on my 41 PU and they are amazing. I plan to order a pair of heads from them to replace the ones I have.
  8. '29 Gizmo
    '29 Gizmo
    from UK
    Harley davidson aftermarket have the correct thread, and a cone seat. This is mine.
    dana barlow, vtx1800 and 51 mercules like this.
  9. sdluck
    sdluck
    upload_2024-6-3_10-10-48.jpeg screws into ls window post threads should be there,this one is from speedway fit 30/31
    Algoma56 and CSPIDY like this.
  10. GordonC
    GordonC
    I modified a set of peep mirror bases and bolted these on to my roadster. As Billy noted they are pretty much useless at speed.
    dana barlow likes this.
  11. banjorear
    banjorear
    Interesting. I'm going to look into this. They are pretty much unless most of the time.
  12. banjorear
    banjorear
    Can you tell us where you got that? I like how it swoops upward.
    51 mercules likes this.
  13. '29 Gizmo
    '29 Gizmo
    from UK
    Ebay .. its the same as the one in mr48chev post above.
    You can get 3" or 4" mirrors. The one in my pic is 3" but I have now got 4" to swap out as ther are a bit small
  14. nrgwizard
    nrgwizard
    from Minn. uSA
    Since you still have door hinges, you could maybe look at ~'41 ford pu mirrors. They have a long tapered neck(which could be bent to a different shape, cut down for length), & are hinge-pin mounted. Usually come painted, iirc.
    Another candidate is the ACVW bug mirrors, which iirc, is like the ford, only smaller & has a shorter stem, usually nicely chromed.
    Check the hinge-height, & pin dia, you'll need a longer pin in any case, as these mount over both the top & bottom of the hinge.
    Then it's a matter of getting the ball-pivot tight enough to stay that way.
    Marcus...
    Edit: What I meant to write was Ford '42-.'47 ford PU hinge-mounted mirrors, which iirc, use 4"dia, maybe 5" dia, mirrors. '41 ford mirror hinge-mounted-arms might be(probably are) the same as '42->'47. Don't recall any vibration-issues w/the ones I had yrs ago.
  15. evintho
    evintho
    I used the mirrors off my stepsons Harley. I like the rectangle shape and the fact they swoop down. Great visibility too!
    rustydusty likes this.
  16. woodiewagon46
    woodiewagon46
    from New York
    There is a company called Hagan Street Rods 888-464-2426 that has a line of mirrors called "Fatties" They have several different mirrors and arms available. I have them on both my cars and although a little "pricey" they offer what they call "super view mirrors". I can drive the Long Island Expressway or PA Turnpike and see all three lanes of traffic at once, real safe.
    KoolTeach31 likes this.
  17. Blue One
    Blue One
    from Alberta
    USMercUte, dana barlow, WC145 and 2 others like this.
  18. banjorear
    banjorear
    Blue One likes this.
  19. KoolTeach31
    KoolTeach31
  20. KoolTeach31
    KoolTeach31
  21. krylon32
    krylon32
    from Nebraska
    On one of my deuce roadsters 22 years ago I used Moal mirrors. The screwed into the posts, were very adjustable plus I could see out of them. Drawback is a little pricey. I just looked and for a pair of chrome arms and a pair of chrome mirror heads it was $218 plus the ride. It was a high end deuce roadster for the time.
  22. 26 T Ford RPU
    26 T Ford RPU
    I used 32 Ford style mirrors on my T. JW
  23. Driver50x
    Driver50x
    I recommend 4” mirrors, if you want to actually use them.
    26 T Ford RPU and dana barlow like this.
  24. MMM1693
    MMM1693
    X2 on the Fatties!
    Bandit Billy likes this.
  25. ydopen
    ydopen
    hfh, Bandit Billy and dana barlow like this.
  26. I used the 30-31 original style mirrors on mine, screwed into the stanchions. I did add a convex mirror to the right side one. No pictures, as car has moved on.
  27. sdluck
    sdluck
    Same
    Algoma56 likes this.
  28. WC145
    WC145
    from Maine
    clem and dana barlow like this.
  29. dana barlow
    dana barlow
    from Miami Fla.
    WC145, ydopen and Bandit Billy like this.
  30. Bandit Billy
    Bandit Billy
    Ho Chi Mama! Dana you don't need no stinkin mirrors, looking straight ahead seems to be the best view.
