My austin healey restomod
Discussion in 'Off Topic Hot Rods & Customs' started by JimSibley, May 9, 2024.
  1. Bandit Billy
    Bandit Billy
    This is just an MG but that sports car thing is mighty attractive. This belongs to a friend of my son, he restored it with his grandfather (I think he said). ***y little cars. Needs a V8
    duecesteve, Sharpone, rod1 and 2 others like this.
  2. foolthrottle
    foolthrottle
    There are a few on the HAMB under, hot rod sports cars
    Sharpone likes this.
  3. JimSibley
    JimSibley
    IMG_8352.jpeg IMG_8348.jpeg That mga is beautiful. I have a buddy that os turning one of those i to a steel cobra.
  4. JimSibley
    JimSibley
    I drove the healey to work today. What a fun car to drive. It has been 3 years since I drove this car.It has changed a little bit. IMG_2252.jpeg IMG_9391.jpeg
  5. foolthrottle
    foolthrottle
    Is the roll bar going back?
  6. JimSibley
    JimSibley
    Some sort of a roll bar will be incorporated. I am not sure what as of yet.
    Sharpone, porkshop and foolthrottle like this.
  7. Bandit Billy
    Bandit Billy
    Here is one in the works from tonight's cruise in Portland. Hood was closed so no idea on power.
    Tim, porkshop, Sharpone and 3 others like this.
  8. AmishMike
    AmishMike
    Curious about rear suspension. Pictures of frame show 4 tube mounts on each frame rail. Think I see independent rear & 4 links to axle. Extra tubes to lower link bars? Have you tried lower mounts? What rear is it? Great build!! Have you weighted it? Checked front to rear weight?
  9. AmishMike
    AmishMike
    Oops, went back to re-read & see first post you said c4 zr1 rear: very nice. Looks like aluminum heads on 302. Questions on link mounts & weight still open
  10. JimSibley
    JimSibley
    I weighed it without interior and exhaust. I am going to weigh it on all four corners asap. The extra tubes are to lower it. It is too low on those settings.
    Sharpone and porkshop like this.
  11. AmishMike
    AmishMike
    Confirmed lower mounts to lower & to low. Nice mounts however. Love to know corner weights
  12. JimSibley
    JimSibley
    I will know tonight. A friend is bringing over his race car scales.
  13. JimSibley
    JimSibley
    IMG_2258.jpeg Here is the weight. Half a tank of fuel, 180 lb driver, ready to rumble!
  14. Sharpone
    Sharpone
    WOW 350 - 400 + HP in a 2000 lb good handling car I call shot gun
    Dan
    porkshop, Damon777 and 41 GMC K-18 like this.
  15. AmishMike
    AmishMike
    Wow, 53% on the rear that ****er should be a great ride. Adjust coil overs for bit more on p***enger side, some big fat soft slicks & terrorize the local sports car crowd. Have fun
    JalopyJimbo and Sharpone like this.
  16. JimSibley
    JimSibley
    I am pretty happy with my weight per wheel. This car hooks up pretty good, but it does push the frontend in the corners. I will mess with the alignment and shock pressures and see if I can get this to improve.
  17. JimSibley
    JimSibley
    I messed with the shock pressure a little, added some air to the front tires and got it to drive like a slot car. I can take my 15 mph corner in front of my house at 40 and it doesnt push. This thing gets more fun with every drive.
    JalopyJimbo, Tim, Sharpone and 3 others like this.
  18. SDhotrod
    SDhotrod
    You can always try out different paint schemes on the Hot Wheels 1/64 model.:) All kidding aside that is a sweet car!
  19. AmishMike
    AmishMike
    Slide the back end & do that corner at 60. Nice car
    JimSibley and Sharpone like this.
  20. There is a version called the BN that has the laid back windshield. I am a real fan of the c4 parts. I threatened to build something similar to this but was never in the right place to get a decent body to start with. IMHO, I believe sporty cars need to be painted. They look cl***y when finished well. Having the engine and exhaust hidden is a plus for me. Looking forward to finished pics. :)
  21. JimSibley
    JimSibley
    It will definitely get painted. I am just enjoying the summer in it as is.
    rod1 and 41 GMC K-18 like this.
  22. L. Eckart
    L. Eckart
    Really like what you are doing with your Austin Healy!!
    JimSibley likes this.
  23. foolthrottle
    foolthrottle
    You might need a new hat to go along with that car
  24. hotrodA
    hotrodA
    That just keeps getting better. Please keep the updates coming.
  25. Tim
    Tim
    from KCMO
    Man that rules!
    electric water pump I ***ume?
  26. seadog
    seadog
    Real Nice...Subscribed
  27. kustomkat1950
    kustomkat1950
    from Coastal GA
    Always wanted to put the land rover v8 in this...Now I am selling it for garage space...Sigh... IMG_20230606_134056278_HDR.jpg
    rod1 likes this.
  28. deathrowdave
    deathrowdave
    from NKy
    Years ago there was a TR6 runnin around here , 300 Cu In Ford . 3 carbs , 5 speed , IRS from Explorer . It was nice finished work , I could drive it !
    Tim likes this.
  29. That is one wicked ride. Early Z-28 Healey. Power to weight ratio is off the fun meter scale.
  30. cabong
    cabong
    I figured that I'd throw in an AH that I raced a few years back. It had been wrecked in '58 and mostly re-bodied in aluminum. It had a 265/4-spd back then, so a friend rounded up a factory mule 265 and the boys at HRW and I did the rest. Needless to say it went like stink !!! This was the critter at work in the vintage races at Coronado. vintage a.jpg
    41 GMC K-18 and rod1 like this.
