Technical Any hemi gurus know what I have?
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, Jun 5, 2024.
  1. wheeldog57
    wheeldog57
    My brother and his boys came to my house the other day with gifts. Previous owner said it's a 57 392 and heads. I would like to confirm this please and thank you. 20240605_174353.jpg 20240605_174408.jpg 20240605_174420.jpg 20240605_174433.jpg 20240605_174500.jpg 20240605_174524.jpg 20240605_174543.jpg 20240605_174558.jpg 20240605_174626.jpg 20240605_174631.jpg 20240605_174638.jpg 20240605_174700.jpg
  2. And take a pic of the stamping front of the block.
    Where the valley cover goes
  3. squirrel
    twelve pictures, and not the one we need.... :)
    Sharpone, wheeldog57, 73RR and 5 others like this.
  4. silent rick
    silent rick
  5. ^^^^^^ that’s the one ya need ^^^^^
    Sharpone and Deuces like this.
  6. Black Panther
    Black Panther
    from SoCal
    1958 New Yorker (and other models probably) 392
  7. silent rick
    silent rick
    yeah, but we need the number from his block
  8. Black Panther
    Black Panther
    from SoCal
    All the numbers are listed
  9. Andy
    Andy
    You can tell from the front cover position.
    Deuces, Sharpone and squirrel like this.
  10. manyolcars
    manyolcars
    yes, my 392 was in a $50 1958 Imperial. I sold the rest of the car to a s**** metal business
    Deuces and Sharpone like this.
  11. 73RR
    73RR
    The block casting number, 1673729, says 392. The 'modified' engine mount ears will cause some grief...:(
    gimpyshotrods likes this.
  12. wheeldog57
    wheeldog57
    @73RR I was going to ask about that, the other side is modified as well. I will add pictures when I get home today
  13. tubman
    tubman
  14. wheeldog57
    wheeldog57
  15. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
  16. CE57 is a 57 392
    Single 4v Imperial
  17. wheeldog57
    wheeldog57
  18. wheeldog57
    wheeldog57
    Aww **** 20240606_191141.jpg 20240606_192457.jpg 20240606_192952.jpg 20240606_193149.jpg
    Deuces, Sharpone and das858 like this.
  19. wheeldog57
    wheeldog57
  20. chevy57dude
    chevy57dude
    Eeek! Was it run like that? A successful repair, I hope. You've had a lot of good stuff come your way lately. Hope this works out.
    Sharpone and wheeldog57 like this.
  21. I’d run it
    Sharpone likes this.
  22. wheeldog57
    wheeldog57
    It's all dirty like it was run after. I'll just tell everyone that it was a top fuel motor with windowed block and tabs removed for clearance, lol
    SS327, Sharpone and chevy57dude like this.
  23. 73RR
    73RR
    Fixing the freeze damage is easy compared to the ears...what ya can't do with a recip...???
  24. Sharpone
    Sharpone
    Dumb question why would someone saw off/ modify the engine mount ears? Clearance? How was the engine mounted after removal of tabs? Ok several dumb questions.
    Dan
  25. We repaired broken ears on a Dodge LA block, by welding the sawed off exhaust manifold outlet pieces, from a 3 bolt SBC exhaust manifold. Pre- and post heat was used in the welding process. Happened about 20 years ago, long gone, no pics.
    rod1, Sharpone and anthony myrick like this.
  26. wheeldog57
    wheeldog57
    SS327 and Sharpone like this.
  27. George
    George
    Blower motors have been known to break the ears off in drag racing, so a mounting plate is used up front.
  28. Ebbsspeed
    Ebbsspeed
    Even though they say that rod doesn't require pre heating or slow post-weld cooling, you are going to have much better chances of success by using normal cast-iron welding procedures.
  29. gene-koning
    gene-koning
    Depends on what you plan on putting it in, but I would probably go with the front motor plate.
    Unless that muggy rod has improved over the years, I would spend the extra money on real nickel rod and pre heat and slow cool the block after welding the ears on.
    73RR, rmcroadster and patsurf like this.
