Technical T-5 disassembly trouble - I need advice
Discussion in 'The Hokey Ass Message Board' started by alchemy, Jun 6, 2024.
  1. alchemy
    alchemy
    I'm trying to dis***emble an S-10 T-5 for a rebuild kit, and am stuck on the 5th driven gear (shown #66 in the diagram above. Says "remove one snap ring and 5th driven gear". Snap ring was a ***** but I got it. Now it seems like the gear should slide off the splines, but it doesn't. Is it supposed to require a puller? It's a tight fit next to the bearing, and will require a very long puller to reach over the end of the shaft, or a narrow puller to fit around the gear but not hit the shaft sticking out below it.
    Any advice is appreciated.
    winduptoy likes this.
  2. TCTND
    TCTND
    Try heating it with a propane torch to expand it a little. Not too hot.
    Deuces, winduptoy and gimpyshotrods like this.
  3. CTaulbert
    CTaulbert
    from Detroit
    5th driven is pressed on. I use a bearing splitter to fit between the case and gear, and press against the end of the mainshaft.
    David Gersic, Deuces and winduptoy like this.
  4. alchemy
    alchemy
    I just need to find a splitter skinny enough to sneak by the lower shaft, and then long arms to reach it from the end of the output shaft.
    I’m guessing a long tube will be required to seat it when re***embling.
  5. A creative drop on a block of wood sometimes helps
    427 sleeper, Deuces, Woogeroo and 4 others like this.
  6. 50chevytx
    50chevytx
    IMG_2725.jpeg You can remove the main shaft ***embly without removing that gear
    pic is from lugnutz’s page
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Anthony Read My Mind....
  8. alchemy
    alchemy
    I want to put fresh bearings and syncro br*** in the trans. I will need to remove the gear to do that.
    I’ve tried tilting the ***embly up to lift out and it hasn’t seemed like it would go. I’ll give it another look. I have a splitter that will work if the shaft ***embly is outside the case.
  9. Paul from t5.com has a youtube video the might help.
    winduptoy and sdluck like this.
  10. alchemy
    alchemy
    The t5.com site seems to be for sale. Got a link to the right video on YouTube?
  11. gimpyshotrods
    gimpyshotrods
    Just remember, if you want that br*** to last, use 70W gear oil, with an API rating of GL-4.
    Grades GL-5 and above are not backwards-compatible, and contain aggressive additives suitable only for differentials.
    Those additives erode yellow metals, like br***.
    Never use ATF in a NWC T5.
  12. alchemy
    alchemy
    Got it. GL4 is “good 4 br***”.
    Roothawg, winduptoy and gimpyshotrods like this.
  13. Johnboy34
    Johnboy34
    from Seattle,Wa
    continentaljohn likes this.
  14. seb fontana
    seb fontana
    from ct
    I changed the 5th ge****t for different ratio. I don't remember having to take the main shaft out of case or needing a puller/press. You have a non World Cl***?
  15. flthd31
    flthd31
    You can remove the main shaft ***embly without removing that gear. Much easier to remove and press back on.
    Some vids:
    Dis***embly:
    ***embly:
  16. MAD MIKE
    MAD MIKE
    from 94577
    I *think* if the 5th gear is ~.80 then it does require removal as it is too large to allow removal where the smaller ~.70 gears allow you to angle it out of the case.
    427 sleeper and ffr1222k like this.
  17. alchemy
    alchemy
  18. CTaulbert
    CTaulbert
    from Detroit
    The aftermarket 0.8/0.81 5th driven gear has to be pressed on and off in the case because the diameter is too large to p*** through the case.
    Any factory BW/Tremec gear can p*** through, meaning you can pull the mainshaft out. It can be a little tricky finding the exact path needed to get the mainshaft out though!
    winduptoy and continentaljohn like this.
  19. alchemy
    alchemy
    Those videos have some great tips in them. Thanks for the help guys, you are much better than the simple manual I was using before. I’ll try swinging the mainshaft ***embly out this weekend when I get back to the project. I’ll definitely be adding some notes to the manual.
    To add a little context, this transmission is for a highboy 32 5-window with a 409. But it should be buried deep enough that the car still has a nice traditional flavor.
    winduptoy and A Boner like this.
  20. alchemy
    alchemy
    It worked. The ***embly wiggled out the top just fine. Thanks for the help guys.
    Any advice on getting the rear bearing race for the cluster out of the case? Videos show lots of smacking with long punches in various places, or even heating the case with a torch. What’s your guy’s experience?
    simplestone, Ziggster and winduptoy like this.
  21. Ziggster
    Ziggster
    I used three vids (incl the GearBox vid) to dis***emble and rebuild mine (still in process), but I found this guy’s vids to be the best.
  22. alchemy
    alchemy
    @gimpyshotrods this trans had ATF in it when I cracked the seal. It decodes to be a 1989 S-10 from a 2.5L. Still think it should have 70W regular GL4 gear lube?
    All bearings and seals will be replaced, but the old stuff didn’t look bad at all. No wear I could find.
  23. Roothawg
    Roothawg
    I see what you did there....
  24. Flatrod17
    Flatrod17
    I am told if it has br*** synchro's it takes GL4 gear lube, but if it has the black synchro's it takes ATF.
    gimpyshotrods likes this.
  25. alchemy
    alchemy
    In my limited experience in the T-5 world, it looks like the br*** syncros are in the NWC and the carbon fiber are in the World Cl***. Correct?
    seb fontana likes this.
  26. TCTND
    TCTND
    Hit that bearing race a couple times with your MIG. It will shrink and fall right out. It doesn't take much.
  27. alchemy
    alchemy
    Only the very edge of the race is visible, with lots of delicate surfaces directly adjacent. Welding on it is not really a good option.
    I ended up heating the case a little with a propane torch, sticking the protruding shaft down through a hole in my steel table, then smacking the cluster with a punch and hammer through a hole in the case. Just like in one of the videos. Seems rather caveman, but it worked and no extraneous damage.
    Roothawg likes this.
  28. Flatrod17
    Flatrod17
    That would be correct as far as I know.
  29. gimpyshotrods
    gimpyshotrods
    As a former Automotive Engineer at General Motors, my professional expertise says emphatic yes.
    I'm not guessing.
    NWC T5's have no bearings under the main gears. They ride directly on the main shaft.
    You are arguing against First-Principles of Mechanical Engineering, and settled science.
    Both are firmly rooted in the Laws of Physics.
    You are en***led to your opinion, but in this case, you are wrong.
    David Gersic likes this.
  30. gimpyshotrods
    gimpyshotrods
    That is correct.
    The black synchros are carbon, but that's NOT what makes ATF ok to use.
    Those black rings are found in a WC transmission.
    World-Cl*** transmissions have bearings between the main gears and the main shaft.
    Non-World-Cl*** transmissions have no bearings there, hence the profoundly different lubrication requirements.
    It is well focused internal GM literature just how many NWC that they had to replace under warranty due directly to using ATF instead of SAE 70.
    I should not have to continuous explain this to people, but here we are.
    Same for high nickel 010 block myth, and that 350's and 400's BOTH had a corner cut on the flange for over a decade.
    Some nonsense just won't die.
    427 sleeper and David Gersic like this.
