Technical Edelbrock SBC Intake Finish - C357
Discussion in 'The Hokey Ass Message Board' started by BHRS, Jun 8, 2024.
  1. BHRS
    BHRS
    from Texas
    I'm in the process of restoring an original Edelbrock C357 3x2 SBC intake back to 1962. It will have a original set of '57 Olds J2 3x2 carbs and mount on a period correct '62 300 hp 327. What was the original finish when this manifold left Edelbrock?
    I have an NOS C4B intake that has a original gray almost like primer finish. It appears Edelbrock dipped the manifold prior to the machine work. All machined areas are bright natural aluminum. Were all the original early SBC intakes coated this way? I've never seen another C4B, C3B, C357, or C26 original or NOS with this finish.
    @Moriarity - you're the resident SBC speed equipment expert. Do you have any do***entation on how the early sbc parts looked?
    Any help is greatly appreciated. Thanks!
    20221017_225500.jpg 20221005_180131.jpg 20221005_180124.jpg 20221005_180119.jpg 20221005_180057.jpg
    Deuces and guthriesmith like this.
  2. squirrel
    are you sure it's coated? Seems to me it would be naturally occurring aluminum oxide....which looks quite different when it is on a raw cast area, vs a machined area.
  3. BHRS
    BHRS
    from Texas
    Looking at it the non machined areas have a uniform color and texture so I ***umed some coating. If there was any oxide I'd ***ume the original machined area would have it as well.
    Deuces likes this.
  4. 427 sleeper
    427 sleeper
    Raw cast aluminum oxidize's more than smooth machined aluminum.
    Deuces and gimpyshotrods like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, I don’t they were coated. It is just oxidized as stated above
    Deuces likes this.
  6. BHRS
    BHRS
    from Texas
    Ok... That's what I needed to know. Thanks for the help everyone.
    Deuces likes this.
  7. gimpyshotrods
    gimpyshotrods
    Yup, just oxide.
    I make cast-appearing parts out of billet 6061, with large radius corners, and then blast the non-mating surfaces with 80-grit.
    Once treated with mildly-acidic tile cleaner (artificial aging), it looks exactly like that.
  8. Nailhead Jason
    Nailhead Jason
    can you recommend a tile cleaner to use? Something like Tilex?
    427 sleeper likes this.
  9. gimpyshotrods
    gimpyshotrods
    About any tile/grout/concrete cleaner will work. Just search for mildly acidic tile cleaner for what you can get in your area.
    I use B2B stuff from Skillcraft ECO, because I designed and built the factory that makes it, and I get it for free.
    https://www.myriadgreeyn.com/Produc...ncentrate--2-L-Bottle--4Pack__NSN7148379.aspx
    Not sure that an individual can buy it. It might look spendy, but that price is for a 4-pack, that is a concentrate. The mix is 40:1. Each bottle is 2L, so the case makes 320L, which is almost 84-gallons!
    Here's the PDF of the MSDS sheet, that indicates the composition, so you can compare the ingredients.
    http://content.oppictures.com/Master_Images/Master_PDF_Files/nsn7148379_sds.pdf
  10. gimpyshotrods
    gimpyshotrods
    This pruned 4-71 is a combination of 75-year-old used cast parts, 60-year-old NOS cast parts, new cast parts, and new 6061 billet.
    You tell me which is which.
