Calibrate SW Wings speedo?
Discussion in 'The Hokey Ass Message Board' started by roundvalley, Dec 2, 2011.
  1. roundvalley
    roundvalley
    I have a Stewart Warner Wings electric speedo #482DP. Instructions have been lost on how to calibrate it. This is the one with the rocker switches in the rear.
    Does anyone have any instructions?? I could not find anything with a search or Goggle.
    Thanks Ken.
  2. BrandonB
    BrandonB
    from nor cal
    google "stewart warner speedometer calibration" and on the second page about halfway down will be a link to the instructions.
  3. roundvalley
    roundvalley
    Thanks Brandon, but this speedo has a row of rocker switches under a plastic window in the back. There is no calibration ****on or terminals to use.
  4. BrandonB
    BrandonB
    from nor cal
    Sorry, it's on the first page when you google it. Does it have the trans mounted magnetic sensor. The switches on the back are called DIP switches. It's a pdf file and has the instructions.
    This is what you will click on:
    ] Stewart-Warner Electronic Speedometer System With Transmission ...
    <cite>ww2.justanswer.de/uploads/.../2009-06-07_230501_a5408120wm.p...</cite> Block all ww2.justanswer.de results
    File Format: PDF/Adobe Acrobat - Quick View
    The Stewart-Warner speedometer is calibrated by setting ten DIP switches at the back of the speedom- eter head. See Fig. 1. The DIP switches are set ac- ...
  5. roundvalley
    roundvalley
    Bingo!! Now if I can find the DIP switch chart. There are 2 seperate sets of 8 Dip switches. 16 total.
  6. bill bosch
    bill bosch
    I to am looking for a dip switch chart for a Stewart Warner speedo with two banks of 8 switches in a row. 16 in total. Am at a complete loss as to where to find the chart. Anybody who can help? it would be greatly appreciated.
  7. roundvalley
    roundvalley
    Try 10000101 10100100
    Standard setting for 8000 pulses/mile
    1 is up and 0 is down.
    This worked for mine.
  8. Michael Crown
    Michael Crown
    I have the same speedo and I need to set it to 16000 ppm. For the life of me, cannot find the dip settings. Any help?
  9. Hi all. I’ve spent ages looking for the chart for older SW electric speedometer calibration. My Father in law had his paperwork instruction sheet from the speedo he bought in 1997 and that gave me more clues to google and just this afternoon I found everything I needed to know at Gilmore-Global.com
    http://gilmore-global.com/
    This business markets lots of gauges and instruments
    Look at the ‘catalogs and technical do***ents ‘
    I found the sheet for setting the 16 switches in an early 2000s SW 160mph speedo.
    I hope this helps someone out in the future. Keep on keeping on.
    CM
  10. sinisterracing
    sinisterracing
    I have 3.25 center with a 29” tall tire v8 auto what should I have the settings at to get correct speed reading I’ve lost my paper work for it ty
