Technical Ford 347 CU. IN. STROKER ENGINE--NO VACCUMN
Discussion in 'The Hokey Ass Message Board' started by 1955 F-100 guy, Jun 5, 2024.
  1. gimpyshotrods
    gimpyshotrods
    That sounds like ported vacuum, not manifold vacuum.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    S0, if I get this right.......... You have problems, and have been given suggestions, and your selling it........ Will you disclose those issue's YOU seem to have to a potential buyer? And your profile says="Have great friends who help with the work" Hope they aren't helping you diagnose this.............o_O
  3. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    Yes have 2 buyers and they are told the problem none are CONCERN-- it is a like NEW engine
    They all heard it running and are impressed not concerned---
    SO TO ANSWERS INVISBLEKID QUESTION DO NOT BE SO WORRIED-- THEY HEAD IT RUNNING AND SEE THE VAC GAUGE AND HAVE NO PROBLEM ON THERE END WITH IT
  4. 69fury
    69fury
    from Topeka
    The reason they aren't concerned is because even money says its a pretty simple solution. Probably one of the many given here...
    -rick
  5. seb fontana
    seb fontana
    from ct
    My +.030 289 [292] with a 242° @ .050, .535 lift [1.7 rocker ratio]. Idles at 1000, smooth lope, 5" vacuum. Going down the road at 40 mph at 2000rpm it has 13/14" of vacuum. Decelerating will see 17/18" of vacuum. 18° initial and 36° total in by 2200 rpm. Could use some modern heads but pretty happy otherwise.
  6. 05snopro440
    05snopro440
    My truck was doing something similar, and when you stepped on the brakes the first time it had a little, the second time it was hard and would barely stop. Ran rough, didn't make any sense.
    You know what it was? I had a bad backfire that blew the power booster check valve. A $10 part.
    Since you're doing no troubleshooting, it could literally be a $10 part that you're selling a perfectly good engine for.
  7. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
  8. You clearly can't take suggestions. Just sell it already and let this thread die.
  9. 05snopro440
    05snopro440
    Honestly, why bother bumping the thread if you're not doing any of the suggested troubleshooting?
    INVISIBLEKID likes this.
  10. 1953-55 F-100 guy
    1953-55 F-100 guy
    from NE Pa
    DELETE -- THANKS FOR YOUR SUGGESTIONS----
