History "Shivel-lay" hidden gas caps.....
Discussion in 'Traditional Hot Rods' started by 6sally6, Jun 11, 2024.
  1. 6sally6
    6sally6
    OK......as a Ford guy I gotta admit..the hidden gas cap idea by GM was REALLY GOOD !
    It started in 55 and ended ......when ? (Anybody got pictures !?)
    Did 58 have the hidden cap or was it just a 3 year deal ?
    6sally6
  2. Oneball
    Oneball
    No idea when it finished but ‘49 Cadillac had it under the light
  3. lothiandon1940
    lothiandon1940
    ...Pretty sure it ended when the '58's came out.
    vtx1800 likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    55's were not hidden, there was a fuel door on the drivers quarter.
  5. lothiandon1940
    lothiandon1940
  6. lothiandon1940
    lothiandon1940
  7. lothiandon1940
    lothiandon1940
  8. lothiandon1940
    lothiandon1940
  9. lothiandon1940
    lothiandon1940
    hrm2k, 427 sleeper and Tow Truck Tom like this.
  10. manyolcars
    manyolcars
  11. Jim Bouchard
    Jim Bouchard
    58 had a funky door on the back under the trunk edge and above the bumper
  12. Deuces
    Deuces
    My 1969 Camaros had them behind the license plate below the rear bumper......
  13. squirrel
  14. Bandit Billy
    Bandit Billy
    I don't know if I have owned a GM car in the 60's and 70's that didn't have the filler hidden. Vettes had a cool fuel door, but the license plate filler was standard stuff on F bodies and A bodies (like my Olds). I don't mind looking at them on a hot rod but they need to be worthy of attention like flip caps.
  15. jimmy six
    jimmy six
    I’ve seen one on a 56 Ford wagon behind the left back up light since the outside filler was right there. It was quite ingenious as it had to twist up and away from the main tail light unit.
    Deuces and 427 sleeper like this.
  16. Mr48chev
    I just remember that many of those low rear mounted fillers were an all around pain in the **** because they could puke gas back on you if the pump was running faster than they wanted to take it and if you filled the tank and soon after parked facing up hill on a grade gas would run out the vent in the cap.
    Those 56/57 Chebby fillers tend to attract the non car guy old farts at car shows who want to show their non car guy cronies that they remember that they were there and how to open them. I saw a guy break one on someone's 56 one time at an event.
  17. DDDenny
  18. jimmy six
    jimmy six
    I’ve got a funny one for you. I was sitting behind my 56 FORD at a show and this “know it all” BOZO wanted to show his buddy where the hidden gas filler was. He was determined to push in the reflector above the backup light on the left one and even went to right side and tried it. He actually said to me “Do you have it locked”? I smiled, got up and pulled down the license plate showing the filler.
    If that guy could have crawled away or slivered like a snake he would …. His buddy was laughing his *** off…made my day!
    Deuces and Tow Truck Tom like this.
  19. WiredSpider
    WiredSpider
    Thou not a GM product, my 56 continental MK 11 has the gas filler behind the LH taillight IMG_2673.jpeg IMG_2672.jpeg
    Deuces, winr, lurker mick and 4 others like this.
  20. Dan Hay
    Dan Hay
    Cadillac since the mid 30s I think. I know my grandpas 41 was hidden and probably earlier. Glad I’m not the only one who still says “Shivel-lay”!
  21. jimmy six
    jimmy six
    ^^^^ Best looking FOMOCO ever….^^^^^
  22. Dan Hay
    Dan Hay
    JohnLewis and Tow Truck Tom like this.
  23. 05snopro440
    05snopro440
    GM had them hidden behind the license plates on some cars on and off well into the 80's. I only know of 50's cars that hid them behind the taillight, though.
    Deuces, 427 sleeper and Tow Truck Tom like this.
  24. MARKDTN
    MARKDTN
    The "B" Bodies kept them under the license plate until they ended in '96.
  25. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Growing up we were near the bottom of a steep hill, on route preceeding us was a long hill then a short flat then us on a steeper grade.
    Used to watch a couple Pontiacs some Chevys always leave a trail ( couple quarts ) off good ole leaded gas. Likely HI-test. certainly not close to as much as $1 worth.
    Oh **** ( BTW ) I have, when new, to pumping gas, had to run the water hose down in my pants
    Deuces and lothiandon1940 like this.
  26. DDDenny
    :eek:
    Deuces, Tow Truck Tom and 427 sleeper like this.
  27. "53 and '54 Plymouths were the worst!
  28. 05snopro440
    05snopro440
    The license plate fills aren't the most terrific for filling, but neither are my dad's 64 Impala or my 62 Bel Air. It's nearly impossible to fill them with today's mostly super-fast pumps without getting gas on the ground (and the car). Albeit, everything I own is low, so that doesn't make it easier to fill.
  29. 59-60 Caddy had a small panel in the rear chrome trim which opened up to reveal the gas filler. No hole or handle to open it, just push one side and it flipped out. Mine used to flap around in the wind, so I glued a magnet in the right spot to keep it closed.
  30. Marty Strode
    Marty Strode
    My 65 Falcon has the fill below the deck lid, and has been a slow fill for the last 53 years. Glad I don’t have to put up with impatient attendants, since I fuel it myself now.
