Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    Still leaking :eek:
  2. Oneball
    Oneball
    Is there something special about the thermostats in these FEs that I’m missing?
    Tow Truck Tom and Jeff Norwell like this.
  3. Pontmerc
    Pontmerc
    from Finland
    Its real easy to drop when installing and bend the expansion tank flange when tightening bolts and thermostat wedged between.
    Check the straighness.
    Tow Truck Tom and Oneball like this.
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    They tend to "slip" upon installation.... I use the rubber band trick.
    When they slip..... they jump out of place and will never seal.... I also use Indian Gasket material. that very sticky stuff that old school guys use.
    Tow Truck Tom likes this.
  5. Oneball
    Oneball
    I used a sealant to hold it in place both times and when I took it out the thermostat was still in the right place. I’ve flattened the flange on a gl*** sheet with some sandpaper and will try again.
    It didn’t leak before when I’d accidentally put the thermostat in back to front!
    What’s the rubber band trick?
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Take a rubber band, p*** it through the thermostat... place into the housing.. feeding the rubber band out of the housing ,...using a small pencil or similar... wrap the band around the pencil on the mouth of the open end of the housing, twisting it, and it draws the thermostat into place.
    Bolt up your thermostat housing to the intake and simply cut the rubber bad and remove it.
    I had a pic.. but can't find it.
    I use the Indian Head Gasket maker stuff by Permatex for a lot of stuff... dark brown, sticky and seals very well.... Learned it from a couple seasoned FE guys. Screen Shot 2024-06-13 at 6.02.19 AM.png
  7. bobss396
    bobss396
    The shellac sealant will hold well. It does take time to set up so the 'stat stays put. Permatex makes a couple of them, their aviation stuff is excellent.
  8. Oneball
    Oneball
    Thanks both.
    I’ve flattened the surface on a flat gl***. Knocked out some of the ridge on the thermostat as it was slightly proud when installed. I’ve made a gasket out of Flexoid gasket sheet which is still made in England and used Loc***e 518, which is basically a modern shellac and sticks like **** to a shovel.
    Bit difficult to use an elastic band due to the baffled tank but did it with some fishing line.
    All back together, will fill it with coolant tomorrow and see
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I forgot Tim you were using the reservoir tank.... seems like you did it though.
    good stuff.
    bobss396 and Oneball like this.
  10. Oneball
    Oneball
    Topped the coolant up and ran up to temp, fingers crossed!!!
    You wouldn’t believe it but it’s the middle of June and I’m sitting here in the car with the heater on, it’s ****** freezing!
    Tow Truck Tom and williebill like this.
  11. bobss396
    bobss396
    Oh yeah, the surge tank... puts another whammy on things... :eek:
    I recall my dad changing the little hose between the water pump and intake.... the tank had to come off. This was on a 352 Ford, I was the helper and all of age 13.
  12. Oneball
    Oneball
    I did that pipe this time around, it was sweating slightly and I thought I’ll just change it and the clamps while I’m there. So far ok.
    Got the tracking set up
    Found 4 of the body mounts were loose which may explain what I thought was the harsh ride over ridges, was all ready for an evening test drive and it’s ******* it down now :(
  13. Pontmerc
    Pontmerc
    from Finland
    Hows today?
    Fog or rain?
  14. Oneball
    Oneball
    Rain and 12c. At the Three Counties Show looking at pigs and tractors today.
    bobss396 likes this.
  15. Oneball
    Oneball
    It lives!
    Popped over to see my folks today, not far it’s only a 15 mile round trip but apart from the steering box probably needing a rebuild it was a successful journey. And even better the Mrs liked it too, better than the TVR and Maserati apparently!! She doesn’t like be in the middle of the road though!
  16. bobss396
    bobss396
    We like an uneventful maiden voyage. I'm not sorting out an OT '66 Belair I just picked up and am working on.
    With my Ford in 2016... I had a flipped 3-4 shift arm and an very loose LR wheel...
    Oneball likes this.
  17. Oneball
    Oneball
    There’s bound to be something that breaks soon! Power steering control valve seems to be the source of the play in the steering it’s so loose it’s almost like the two springs aren’t inside, I’ve ordered a rebuild kit. If it arrives and I get it fixed I might use it at the weekend. I’m racing a mate’s car so don’t need to tow anything but it’s a 4 hour or so drive to get there, anything might happen!
  18. Pontmerc
    Pontmerc
    from Finland
    You do realise that control valve play should be checked engine running?
  19. Oneball
    Oneball
    Yes, it’s the same sort of setup as Corvettes, thinking about it there’s probably that much moment because the ball/sockets are worn out, I’ll go have another look to confirm
  20. Oneball
    Oneball
    The ball isnt too bad but the sleeve is completely screwed up, hopefully a rebuild will sort it.
    End cap is chewed up too so had to order one of those from USA.
  21. bobss396
    bobss396
    Looks similar to the drag link guts on my manual steering.
    Oneball likes this.
  22. guthriesmith
    guthriesmith
    Man this car has turned out nice! Glad to see you are getting it all sorted. :cool:
    Truckdoctor Andy and Oneball like this.
  23. Oneball
    Oneball
    Rebuilt the control valve
    Waiting on a new end cap now.
  24. Oneball
    Oneball
    Thanks, needs a clean and polish but it’s getting there.
  25. Oneball
    Oneball
    It looks like the pin that holds the valve piston rod to the sleeve wasn’t put in properly so the sleeve could move around rather than just wear and tear.
  26. Oneball
    Oneball
    End cap arrived and steering is back together, seems to have sorted the play and wandering.
    Trunk is packed
    Off to my mate’s in Norfolk, google says 4 hours so I’m imagining nearer 5 plus breakdowns.
    bobss396, Truckdoctor Andy and Cooon like this.
  27. Oneball
    Oneball
    Made it, one stop for a drink. Seems to cruise along nicely.
    Race car isn’t looking too pretty though.
    61Cruiser likes this.
  28. Pontmerc
    Pontmerc
    from Finland
    In a steady 50mph cruise, do it feel any like driving in a headwind?
  29. Oneball
    Oneball
    My cruise is a bit faster than 50mph :D
    65-70 seems nice. There’s no real throttle needed at all
    Once it’s shifted to top it gathers speed over 50mph quite quickly. Full throttle from standstill and I get a backfire through the carb so something to sort there.
  30. Pontmerc
    Pontmerc
    from Finland
