Technical Power booster under floor master chev 37
Discussion in 'Traditional Hot Rods' started by Jdmcrx, Jun 14, 2024.
  1. Jdmcrx
    Jdmcrx
    IMG_4686.jpeg Hey did some searching and did not come up with much
    Is anyone rocking this style under floor power brake booster setup ?
    I was looking at doing this master with 7" booster with 2 -10lb residual valves and the remote master on the fire wall .
    My orig master has too much rust to repair and I wanted a dual master with power booster
  2. deathrowdave
    deathrowdave
    from NKy
    I switched my 37 to overhead pedals the brace and pedals from a 66-67 Chebbie 2 , seems to fit as God wanted there , best as I can recall
    lemondana likes this.
  3. Jdmcrx
    Jdmcrx
    any pictures of this set up under the dash and engine bay ?
  4. Dan Hay
    Dan Hay
    I’ve got one of those boosters and brackets I’d sell if you want to go that way. I bought it and decided not to use it. Message me if you’re interested.
    instead I used a Chevs of the 40s bracket for a modern manual MC under the floor in the stock location.
  5. Jdmcrx
    Jdmcrx
    PM sent. Im trying to see if there is provision for the clutch lever or im going to have to fabricate something i guess
    Dan Hay likes this.
  6. hepme
    hepme
    I did a 40 with this type setup--miserable. First used a single diaphragm, it and 4 huge boat anchors would stop the thing in 200 yds. Went to a dual diaphragm, better but still kept your attention at any stoplight. Planned a firewall type but sold the car before that. Retrospect--firewall type first.
  7. BJR
    BJR
    Here is how I did it on a 40's Chev pickup. Don't know if cars are the same.
  8. Jdmcrx
    Jdmcrx
    Its in the same pos issue is mine mounts to the crossmember and the master is part of the pedal ***embly, im wondering if the 7/8" booster helps with the drums
  9. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    If you are running drum brakes, I recommend leaving that residual valve out.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Any specific reason ?
  11. '29 Gizmo
    '29 Gizmo
    from UK
    Used this style on a 34 chev. Works fine. Just got an inspection panel in the timber floor to access the master cylinder. Dual diagram booster is awesome.
    No residual valves, drums rear, disks front.
