1930 Ford Coupe. ** SOLD** Many thanks to the HAMB !
Discussion in 'Cars For Sale' started by Caddy-O, Jun 17, 2024.
  1. Caddy-O
    Caddy-O
    City: Amarillo
    State: TEXAS!
    Price: 21 k OBO
    Testing the waters on my 1930 Ford. Basically, everything on the car has been gone through. Runs and drives great.
    · 1960’s black lacquer paint.
    · Very cool 1960’s gold seat and door panels
    · Roof insert was done in the 60’s. Still holding up well, although the perimeter tack strip might use a re-do.
    · Body is rust free except a small area on both rear wheel wells. I have both patch panels if you want to fix them.
    · Rebuilt 38 flathead.
    · Rebuilt 39 3 speed trans with all new clutch, , etc.
    · 32 Ford K-member.
    · Frame was blasted and painted.
    · All new chassis fittings and wheel bearings throughout.
    · New Firestones with 35 spoke wheels.
    · Thickstun P-7 intake with big label 97 Strombergs.
    · New Power Master 12 volt 1 wire alternator.
    · Converted to 12 volt.
    · Distributor and coil rebuilt by Skip Haney.
    · 48 Lincoln steering wheel.
    · Rear brake lights and turn signals.
    · Pontiac re-pop taillights.
    · All new wiring.
    New Walker radiator.
    · Original cowl tank, but I’m using a 10 gallon aluminum tank in the truck set up with an electric fuel pump.
    · Mechanical brakes are set up correctly and work fine. I have 40 backing plates, spindles, brakes,
    hubs, etc to covert to hydraulic that will go with the car.
    · I have a model A 4” dropped axle that will go with the car.
    · Installed Millworks clutch and pedal set up for original A hangers with 39 transmission.
    · New exhaust.
    FSRFE9517.JPG PSIA0241.JPG IMG_8734.JPG IMG_8755.JPG IMG_E9024.JPG View attachment 6099894 View attachment 6099895
  2. Caddy-O
    Caddy-O
  3. Caddy-O
    Caddy-O
