Projects My 57 is home
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Jul 19, 2013.
  1. 40FORDPU
    40FORDPU
    Progressing nicely...this car just keeps getting better all the time.
    Sharpone, Jeff Norwell and hrm2k like this.
  2. I remember seeing the lights in the top corners of the windshield and asking what they were about. I too was told they were "*** lights". That's all fine and good except for one very disturbing fact ... the only "dame" this clown EVER (and constantly) had in the p***enger seat of his car was ... his MOMMY :eek:o_O Ughhh ...
    As for "Dirty Bird" ... ****py Tire or Canada Trash was always Canadian Tire, Dirty Bird has always been another name for Swiss Chalet. Just sayin'
  3. 57 300
    57 300
    from 211 Maple
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well.... gotta take the good with the bad....
    .....a month ago. went for a spring ride after a clutch adjustment... got 10 minutes away and the right bank on the 428 started to smoke like a crop duster.... white steam.. yea you guessed it...
    head gasket.
    No coolant drop, no overheating, no coolant in the oil,, still ran without a missed beat.
    But I had to to investigate and repair....
    Its not the fact of a head gasket .. but the Sheer pain in the *** of getting to do it.
    After yelling at it every time I p***ed it in the shop and cursing her..With help of my good pal Terry we tore into it.I hate dealing with coolant... Detest it.
    Thank god there was no block or head damage.
    Just a bad failed Felpro head gasket....
    My good Pal Terry came by to help and lift heavy stuff. hahahah
    Screen Shot 2024-06-18 at 6.32.29 AM.png IMG_2131.jpeg IMG_2142.jpeg IMG_2138.jpeg IMG_7091.jpeg IMG_2144.jpeg
    Should have it Dailed in within the next 2 weeks.
    The good news is I remembered how much port m***age was done to the pi heads...
    ...anyhow. can't cry..... it's Simply Hotrods.
    Oh Well....
    hrm2k, pwschuh, ratrodrodder and 26 others like this.
  5. I think that is unusual. I don't ever remember having a gasket problem with FE's. Working over the painted fender even with the best fender cloth makes me a little nervous. Best wishes. Cheers for Terry, again. :)
    05snopro440, Sharpone, enloe and 5 others like this.
  6. guthriesmith
    guthriesmith
    Sometimes when things like this happen to me it makes me wonder why I even mess with this stuff. Then I remember after I get it fixed and take a drive. Glad you are getting it back together. :cool:
    05snopro440, Sharpone, Thor1 and 7 others like this.
  7. Roothawg
    Roothawg
    Glad you caught it close to home and not 1200 miles away.
    Sharpone, bobss396, enloe and 4 others like this.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hail freaking Mary.
  9. Ford blue blood
    Ford blue blood
    Sorry about the failed part! Yup working over the painted fender is "testy" at best! Just can't keep the blanket in place without a tussle. My tale with that was just a bent push rod? Not sure how or why, replaced it and no issues.
    Got to ask, where did you get the Rat Fink from? I HAVE to have one. It is exactly like the one I have in my beater 50 Olds when in high school. I later upgraded to an AMT kit about 8" tall and wired his eyes to the brake lights and mounted him on the rear package shelf.
  10. Squablow
    Squablow
    Damn, that gasket failed HARD. Did the engine ingest a piece of that metal ring from the gasket? There's something way less satisfying about fixing something that was already "done". Could have been so much worse though, so there's that.
  11. 41 GMC K-18
    41 GMC K-18
    Hey @Jeff Norwell
    Bummer about that head gasket.
    Just curious, if you are considering replacing the head gasket on the other side?
    Reason I ask is, I would ***ume that what ever the flaw or failure point in the blown head gasket, may potentially be in that other head gasket as well.
    No way around the fact, that doing both sides, is a major pain in the ***!
  12. guthriesmith
    guthriesmith
    So...were all the bolts tight? And, I ***ume you checked everything to make sure it is flat? I was amazed recently when I checked a brand new set of BBC heads for flatness...right before we decided to surface them since I couldn't keep head gaskets in the engine... I also ended up with head studs instead of bolts for the whole belt and suspenders deal. :D
    Sharpone, Jeff Norwell and Thor1 like this.
  13. Okie Pete
    Okie Pete
    If it was easy everyone would build hot rods and drive old cars . We don’t sit down and tell stories about the destination. We share stories about the journey getting there . Sorry about your troubles. Glad you are getting it fixed and back on the road it is a beautiful car
  14. 57JoeFoMoPar
    57JoeFoMoPar
    Looks like your pal Terry didn't skip arm day.
    Glad you're getting it ****oned back up. In the grand scheme of things this could be much worse
    Sharpone, bobss396, Squablow and 2 others like this.
  15. 53 effie
    53 effie
    So.. you have "shorties" on this.. most people claim they won't fit on '57-60 cars. What did you do for clearance on the left side? Want to use them on my '58 Custom 300..
    Sharpone and Jeff Norwell like this.
  16. 57 Fargo
    57 Fargo
    Well ****! @Jeff Norwell maybe you should have put a Hemi in it?:)
  17. hotrodA
    hotrodA
    Sorry for the toe stubber. You’re reminding me of me and my 40. You handle it better, though.
  18. deathrowdave
    deathrowdave
    from NKy
    Murphy has a way of creepin in when and where you lease expect him to show up . I can’t say I ever blew a head gasket on an FE . Man that one went on vacation big time . Beautiful. Car . You get tired of workin on it , I’ll take a turn at my house !
  19. 57 300
    57 300
    from 211 Maple
    I love my fender covers that Mrs. Fuller made in 78.Only half of the snaps work due to heavy usage.40 dollars well spent. expo10_td0903_011.jpg
  20. belair
    belair
    At least you got a steam clean on the piston.
  21. RmK57
    RmK57
    Does Felpro sell a premium head gasket set? Might be something to look into.
  22. Oneball
    Oneball
    I’m glad it’s not just me, every time I have to do something with mine I hope it doesn’t involve coolant, it always gets on everything.
  23. Troublemaker427
    Troublemaker427
    1020 FelPros is what you want.
    Jeff Norwell, RmK57 and 57 300 like this.
  24. deathrowdave
    deathrowdave
    from NKy
    Do me a favor and copper coat any head gasket . Amazing the results you will see .
  25. Coolant all over the place is a real blister. Sometime way back in the late 60's I was shown what to do not to make the Mess to start with. I have yet to work on anything automotive that doesn't have some kind of outlet at the lowest point of coolant that can be removed to drain the water chamber of 99% of its coolant. Once removed no more mess, well unless your catch pan is too small, or you just plain miss it. Draining the radiator never drains the block below the lower radiator hose feed point.
    Jeff Norwell and Sharpone like this.
  26. Sharpone
    Sharpone
    Not all head gaskets but most benefit from copper coat
    Dan
    Jeff Norwell likes this.
  27. Oneball
    Oneball
    Ford did think of that, but on the bench! The rad drain plug on mine nestles above the front cross member and the right bank drain is behind the engine mount!
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Everything is just fine so far.
    All is going back together very smoothly ....
    Checked the deck on the Head and the block... clean and straight. no warpage....
    no cracks, no nothing.
    ....this was my biggest fear.....
    All is just fine.
    Now, I just need to attach the small stuff and hook lines, fill coolant.drain oil ,new filter, etc,etc.....
    Adjusting the rockers now....
    When I had the head off.I notice very nice port work on the head... which made me smile.
    Anyhow, the biggest angst I had was ripping it all apart... it just pisses me off.... mostly because How I lack free time in my life at this moment.(hell,ANY moment!!!)
    I will have all back and running within the week.
    Pretty sure I know what caused this,... and with great embarr***ment.....
    ..it was me.
    When I first had the car running... it was perfect.... remember when the thermostat Housing area on the intake cracked and broke?(It's somewhere in this long thread)... well..I had to the the intake repaired...
    Engine was running solid... I removed the intake, distributor, bla, bla, bla...
    After it was fixed... put the engine together .. yes. it was on number one at TDC...
    The car fired up perfectly... ran great at idle.... went for runs... but for about 1 week after this procedure.... the engine would have a "popping" when my foot was in it.... like a very strange backfire.(and only when I was hammering it)
    After a week of this and playing with timing.. playing with the carbs... It would not go away.
    So my good pal Terry(FE Guru) comes by the following weekend..... looks at it and stone face tells me... "uhh, number 2 and number 7 wires are crossed."
    Well... stupid doesn't even begin to come to mind on how I felt.
    Pretty sure that damaged the number 2 gasket area. Pre-detonation .
    So... a small "Pop" would occur only about 4 times while driving in the last year... it concerned me. but not something that kept me up at night.
    And then, well ... here we are.....
    So,.... the damage was done but it took a while for it to really fail.....
    Anyhow, thats my story.... and my theory.
    hrm2k, 53 effie, Thor1 and 13 others like this.
  29. guthriesmith
    guthriesmith
    Well, that at least explains it. I had a similar failure recently when we went to start a blown big block that someone else dropped the distributor in. We quizzed him multiple times if he was sure he dropped it TDC and he said he did. Well, he was wrong and it was 180 out. Shot a huge flame out #3 cylinder exhaust and we then had a head gasket to fix soon after…
    Thor1, 41 GMC K-18, Squablow and 4 others like this.
  30. Sharpone
    Sharpone
    Hell guys, there is only two types of people, those who have mistakes and those who do and accomplish nothing:D
    Dan
