Projects 1950 Desoto build
Discussion in 'The Hokey Ass Message Board' started by choptop40, Jun 18, 2024.
  1. choptop40
    choptop40
    Posted a bunch of pics in other threads on the 50 Desoto..Dash reworked . Got the new Motor Racing analog gauges.. I like them alot.. and they are unbranded too.. Gauge panel configured , now to cut holes , add 3 more small holes for directionals and high beam.. First pic when it arrived.. undid the frenched headlights and lake pipes
  2. choptop40
    choptop40
    Cleaned up the shop and passenger lake pipe removed...Wheels have to go … Thinking of traditional torque thrusts AE742067-B026-40F5-9718-B605C6760139.jpeg
    2Blue2, chryslerfan55 and dana barlow like this.
  3. choptop40
    choptop40
    Motor and trans ready to pull out next..custom built lift chain made from industrial machine parts image.jpg image.jpg
  4. choptop40
    choptop40
    got a set of red steelies..to relpace the 79 Camaro rims..I like em... 55AD3745-3BFE-4D9C-91E8-161796C4E1FB.jpeg EF17AC95-C982-4A5E-9EF8-E6C4C6184DDA.jpeg
    chryslerfan55 and hotrodjack33 like this.
  5. choptop40
    choptop40
    headlights unfrenched.. C063268C-B6D5-47AD-8819-4131E96ACCC4.jpeg 2EACA2DD-912B-4F6F-B658-C124485A8D38.jpeg 9B2A6126-C835-4D01-8F69-9DD7333D0DD8.jpeg
  6. choptop40
    choptop40
    Thats a 49 Desoto grille just test fitted..
  7. choptop40
    choptop40
    Checking the front suspension.. Everything feels tight . Borgeson fast ratio steering box ready to install image.jpg
    bobss396 and chryslerfan55 like this.
  8. choptop40
    choptop40
    Deciding weather to weld up the trim holes upper body.. thing is the trim makes it easy to paint the Desoto 2 colors.. image.jpg
  9. I'd leave the trim if it is in good shape. Breaks up the paint either way and adds some "flash".
  10. choptop40
    choptop40
    Hey lieutenant Dan . I agree ....the trim is in nice shape....Flash is good ....
  11. choptop40
    choptop40
    Mocked up the GM tilt column.. looks like a good fit… Still on the fence to use a non keyed column..gonna change out the stock steering wheel … CCE2242A-EDA9-41A9-83BF-F3D3425DBDD0.jpeg image.jpg
  12. Restoration Specialties will have any needed clips for the molding. I grabbed a couple of early Chevy C10 non-keyed columns for the Buicks. Non-tilt though. I think they were non-keyed until 71. @squirrel would know.
    The truck ones have the TH400 detent pattern in the years 69?-up
  13. choptop40
    choptop40
    I would prefer non tilt.....the ones I found are rusty and crusty... il check Restoration Specialties for the clips,,,Squirel is an encyclopedia ...lol...
  14. squirrel
    GM started putting the ignition switch on the column in 69...except trucks and vans, which had no switch for several years after that. Trucks got it in 73, vans around late 70s?
  15. Let’s see, vehicle, check, build plan, check, engine, check, transmission, check, color, pending, upholstery, pending, exhaust , pending, a jar of moonshine ( for emergencies, hehe), check, seatbelts, double check, straight jacket in case it all falls apart, check. Carry on.
  16. choptop40
    choptop40
    Pulled the 350 / 4 speed out..Trans on it way to a Trans am project....engine bay looks huge but that chevy 350 filled it up nice.. Gonna reinstall with turbo 400 and set it back 5 or 6 inches more for radiator / mechanical fan clearance.,,. Straight Jacket secured in case TSHTF. 95C4B5CF-3A79-444B-8F56-913FC1AD44D3.jpeg EC2B9FB0-86AB-4639-ACE1-D80CCCBE51BD.jpeg 4E99537B-E585-44C2-84AF-485996E542AC.jpeg
  17. Rickybop
    Rickybop
    Shit nowhere near the fan.
  18. choptop40
    choptop40
    Hey Rickybop , glad to see Hamb holliganing again..
    Rickybop likes this.
  19. choptop40
    choptop40
    Got Power ? Rebuilt 350 set back 6 1/2 inches sitting on the new heavy wall tubular engine cradle with new motor mounts... 5597b6c3-b6f2-4a72-b570-1cbadae015b7.jpg
    bobss396, 3AMideaz and chryslerfan55 like this.
  20. choptop40
    choptop40
    Looks like I'm gonna go with these instead of the block hugger headers....they dump back already and are further from the oil filter so less heat..and they are 1 5/8 primary tubes so more flow....gotta go with the flow. PXL_20241020_232058031.jpg
    Rickybop and chryslerfan55 like this.
  21. Rickybop
    Rickybop
    Thank you sir.
    Good to see you inventin' stuff.
    Go with the flow, bro.
