  1. j hansen
    j hansen
  2. gene-koning
    gene-koning
    I used to tell the guys that drove my dirt track cars, "If your going to kill the motors, kill them good! I don't want to pull a half azz dead motor out!"
    Those guys killed those motors good! None of that "It was getting hot" or "it was loosing oil pressure" or "it spun a rod bearing" or "it threw a rod through the side of the block" light weight ****. Those guys got everything out of those motors!
    X-cpe, Deuces, Jim Bouchard and 3 others like this.
  3. j hansen
    j hansen
  4. j hansen
    j hansen
  5. j hansen
    j hansen
  6. j hansen
    j hansen
  7. 40ragtopdown
    40ragtopdown
  8. 40ragtopdown
    40ragtopdown
  9. 40ragtopdown
    40ragtopdown
  10. 40ragtopdown
    40ragtopdown
  11. 40ragtopdown
    40ragtopdown
  12. 40ragtopdown
    40ragtopdown
  13. 40ragtopdown
    40ragtopdown
  14. gene-koning
    gene-koning
    That looks like a good reason to replace a motor, but if that damaged part of the head was at the back of the motor, you had to pull it out and tear it down to access the damage and what was needed to make it run again.
    You have to admit, as far as destruction is concerned, those three I quoted pretty much remove any doubt about the condition of the motor.
    Jim Bouchard and j hansen like this.
  15. 40ragtopdown
    40ragtopdown
  16. 40ragtopdown
    40ragtopdown
  17. 40ragtopdown
    40ragtopdown
  18. 40ragtopdown
    40ragtopdown
  19. swifty
    swifty
    Tony Mullens channelled 32 roadster with Y-block power at the Fishermans Bend dragstrip in Melbourne. There's a 49 to 52 Holden behind and a 56- 59 Holden beside.
  20. CSPIDY
    CSPIDY
  21. bushwacker 57
    bushwacker 57
    j hansen likes this.
  22. bushwacker 57
    bushwacker 57
    Richard Hobbs from D.C moved to Nor Cal early 60s to San Rafael Cal had a auto repair shop. My home town. It never looked that good. I have his the white 32 roadster .
  23. Sky Six
    Sky Six
    from Arizona
  24. jimmy six
    jimmy six
  25. 40ragtopdown likes this.
  26. Stan Back
    Stan Back
    Well, you didn't dodge the answer.
  27. 40ragtopdown
    40ragtopdown
  28. 40ragtopdown
    40ragtopdown
