Projects My 57 is home
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Jul 19, 2013.
  1. guthriesmith
    guthriesmith
    Very true and seems you took my own words that I tell others. :rolleyes: However, I’m also not the best at actually handling it well when I do make mistakes… :oops:
    Also, I thought we all just acted like we were perfect on the internet. Maybe I am thinking of some other site for that… :D
    Jeff Norwell, Okie Pete and Sharpone like this.
  2. Sharpone
    Sharpone
    I was told I was a perfect ***hole once or maybe more than once.;)
    Dan
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I like you 2 guys.
    hrm2k, 53 effie, 41 GMC K-18 and 6 others like this.
  4. Sharpone
    Sharpone
  5. Here's to hoping for complete success. :) I really think if he would have had me come do some burnouts, this wouldn't have happened. LOL.
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    As a small side note.. which probably already known.....
    after your intake is on glued and torqued.. you need to shave the gasket lips off with a very small file or you VC's will never seal.
    trial n error here.....
  7. ratrodrodder
    ratrodrodder
    from Boston
    You know, as much as it's a pain to deal with (and then be humble enough to share it with all of us!), it's nice to know that these kind of things happen to others too. The frustrations and problems we each deal with often seem to fall in the "why me?!" category, so it's re***uring to read about the problems of others and remember that it's not just one of us, we all suffer from these kind of problems!
    Glad the head gasket was an "easy" fix, and here's hoping for some happy motoring in the near future!
  8. deathrowdave
    deathrowdave
    from NKy
    Pressure test the coolant system before firing it see what it looks like . Chances all are good as new , but it’s a simple test
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Completely AGREE
  10. Squablow
    Squablow
    I've done way dumber ****. At least you figured out what did it, that's better than never knowing what mystery malady killed your gasket.
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    To be quite Honest..... no idea... had that little Fink for ever... like in High school(I'm 61 now)
    As a collector of highly prized Junk and an official Hoarder..... he has been with me for a very long time.
  12. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yea Know Lane.. there was a time when I seriously thought about this....
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    So.again,. somewhere in this thread I mentioned the procedure.
    Everyone and their Dad told me it couldn't be done.If there is one thing about me... don't tell me it can't be done..... that just makes me want to do it more. I mean. if we can make a plane fly.... Surely I can make shortys on an FE work in a 57-58-59 Ford.
    I simply didn't want god-awful Headers nor was I going to run the Horrible FE flat log style exhaust Manifolds(which would have fit, but Killed any performance.)
    So I use a 58 steering box... a simple cut of 1/8 on the frame where the steering box is... slice n push in. re-weld and space is ample.
    No notice on the steering box angle or issues... its so very slight.
    Now if you're running a 57 box.... thats a different story .... it's just that much bigger to be more of a pain.
    Of course. this isn't a 3 hour Saturday afternoon job..... but When I had the sheetmetal off and the FE went in... it literally took less than an hour...but the front sheetmetal was completely off.There was no steering issues, No interference with the Upper A arms, or any issues with the manual clutch linkage.
    Is it Tight?.... No different than a Caddy in a 40 Ford.... they are all tight.But not impossible to work on.
    Kugel now sells the most beautiful set of shorties... for about $700-$800 bucks.... If I was to do it again.I would buy their new products.... finding a good set of originals is getting harder to find and more than a set of Kugels.
    I really wanted to find a set of Factory Ford long tube Headers... and use them.... and of course..again...everyone said "Can't do that" "It won't work"
    Oh yea?... hold my Beer.
    But the cost of a good set with no broken bolt ears or cracks or welded up tubes are now upwards of $2500-$3500.... and nobody makes them just due to the fact there is no a big calling.
    So. there is my story.
  14. Roothawg
    Roothawg
    Good to know.
    Sharpone and Jeff Norwell like this.
  15. Ford blue blood
    Ford blue blood
    Thanks Jeff, I'll just keep looking.....
  16. 53 effie
    53 effie
    @Jeff Norwell Thank you!! I had gone through the entire thread but apparently missed what you did.. Being my car is a '58, I already have the '58 box. And I have a pair of original shorties.. and the front end sheetmetal is off..
  17. Flatrod17
    Flatrod17
    I need a good 58 box if anyone has an extra.
    I have both long and shortie factory headers. The long tube set came out of a 57 300 with a 428. But I don't know what box he had in it, probably 57 as he took them out because rubbing on the steering box.
    I would like to put my 406 in my 57 wagon with either set of factory headers.
    Sharpone, Jeff Norwell and 53 effie like this.
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well.. all fixed and zero issues... the car is now done...... well. who knows.. but it drives fantastic, pulls like a Freight Train and drives, stops and steers fantastic....
    Very Happy with all aspects of the car from start to end... Learned a TON, made a ton of errors too... but with the help of close friends and this place too.... its an ongoing adventure.
    Thanks to ALL who lent their support and knowledge..... I truly love this Hobby.
    The END.
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    *****in' Jeff.
    Outstanding....be proud brotha.
    The Broderick Crawford look.
    porkshop, Sharpone and Jeff Norwell like this.
  20. Oneball
    Oneball
    Fab!
    Bet you’re pleased.
  21. guthriesmith
    guthriesmith
    Very cool Jeff! Now, you just need to drive it south to come see me and our buddy down in Texas that has that cool salvage yard. :D
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Thank you guys......
    It sure came a LONG way since 2017..... But.... the Lord hates a Quitter!
    @guthriesmith ...... That is the plan..... but with a new Grandchild and the House for sale and moving....
    It will be next summer..I really do miss my US friends. been far far too long.
    Thor1, porkshop, PoTaToTrUcK and 8 others like this.
  23. MOONRNR
    MOONRNR
    I also have been called the perfect a$$hole, especially here.
    But I fooled them. I have hemorrhoids ... :p
  24. bobss396
    bobss396
    Got some nice houses by me up for sale... just sayin... :cool:
  25. Sharpone
    Sharpone
    One beautiful machine, thanks for sharing!
    Dan
    guthriesmith and Jeff Norwell like this.
  26. 57 Fargo
    57 Fargo
    A work of art, although I would expect be less from @Jeff Norwell, make sure you enjoy it!
    Jeff Norwell and Sharpone like this.
  27. GordonC
    GordonC
    I hate endings! That is a great looking 57! Very nice job! It's been fun to watch your journey with it.
  28. ratrodrodder
    ratrodrodder
    from Boston
    Looks great, sounds great! :)
  29. warbird1
    warbird1
    That thing is gorgeous; makes me Jealous!
  30. Dang! Still no burn out video. LOL.
    Jeff Norwell likes this.
