Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Jay Altemus
    Jay Altemus
    I was going to make my own small rotisserie for my 34 frame so I could work smart, and not work so hard as I media blast the frame. I mentioned this to my friend, and he offered to loan me his rotisserie. (I didn’t know he owned one.)
    I went to get it the other day and it’s a monster. The lower horizontal beam connecting the two ends was 17 Feet long, so I cut it in half to get it home. This rotisserie is strong enough to handle just about any size car.
    It has been out in the weather for 11 years, so I’m giving it the attention it needs. I should have it ready to use within the next week or so.
    My friend and I both own 1965 Chevy C10 half ton stepside trucks. His green truck is all original and mine has undergone a few upgrades.
    IMG_6109.jpeg IMG_6146.jpeg IMG_6147.jpeg IMG_6160.jpeg IMG_6161.jpeg IMG_6166.jpeg IMG_6167.jpeg
  2. Jay Altemus
    Jay Altemus
    Well, it’s DONE!
    Brought this rusty rotisserie home Monday 6/17/24. Cleaned and made it ready for service. New 8” wheels welded on today.
    I’ll mount my 34 coupe frame and finish cleaning and media blasting the frame.
    Had to get creative with shop space. Body of the 34 had to come off the dolly and onto the lift so the rotisserie could fit in the same bay of the shop.
    IMG_6200.jpeg IMG_6201.jpeg IMG_6205.jpeg IMG_6202.jpeg IMG_6208.jpeg IMG_6198.jpeg IMG_6199.jpeg IMG_6196.jpeg
  3. snoop74
    snoop74
    Car was running funky. Condenser went bad in my dizzy. Got the engine back together with the risers on. IMG_9360.jpeg IMG_9358.jpeg IMG_9361.jpeg
  4. snoop74
    snoop74
    I boiled two coils in two days lol not running a ballast resister..
    31 B'ville likes this.
  5. Looks like you've mounted the ballast resistor on the inside of the driver's side firewall, seeing those two bolts? If you have the resistor, have you had a chance to fire that '09 to see how the risers worked your temperature issue?
  6. snoop74
    snoop74
    Yeah my coil was installed on the driver side inside to clean it up. So I just installed the resistor next to it because I didn’t wanna drill anymore holes. It’s running better; I’m going to drive it right now actually in the Texas heat to see how it is.
    31chevymike, Jay Altemus and Six Ball like this.
  7. snoop74
    snoop74
    Guess it’s about time for this dreaded door process
    31chevymike and Six Ball like this.
  8. Jay Altemus
    Jay Altemus
    Frame is on the rotisserie. C4 rear axle is off. IFS comes off next.
    Top heavy on the rotisserie. Guess I’ll have to fabricate something to center the weight on the axis of rotation.
  9. snoop74
    snoop74
    Finally found a set of 904-A chrome headlights to run instead of the 682-C
  10. snoop74
    snoop74
  11. Jay Altemus
    Jay Altemus
    I’ve heard that powder coating is affordable. I can’t powder coat. I don’t know how, plus I think it needs to be baked at high temperature. I know how to paint, so that’s been my plan. Plus I will likely need to weld brackets and crossmembers to the frame at some point and I’m thinking powder coating should be done AFTER the frame welding is completely finished. Any advice either way?
    Six Ball likes this.
  12. snoop74
    snoop74
    Yeah powder coating was pretty affordable for me. I did all my crossmembers and all the brackets I needed before. Put the wheels and pedals ect everything on and then blew it apart for powder. I paid $400 for my frame to be blasted and powdered.. painting would have been cheaper I suppose but $400 too cheap to p*** on. IMG_6857.jpeg IMG_6949.jpeg IMG_6620.jpeg IMG_6660.jpeg IMG_0893.jpeg
  13. snoop74
    snoop74
    I’ve been looking for a set of these 904-A’s for awhile.. which do yall think I should run. Both are 7” the 904s are a bit more rare; seems like everyone is running 682’s. The 904 is a little shorter as well IMG_9383.jpeg IMG_9382.jpeg
  14. Six Ball
    Six Ball
    from Nevada
    They are both nice. I think I'd run the 904s.
  15. Jay Altemus
    Jay Altemus
    Today was grunt work day. Nothing fun about it at all. The rotisserie made it more bearable. I cut out the frame modifications done by some previous owner. I’ll weld in new steel where they C notched the frame for the C4 rear axle that was installed.
    I was able to balance the frame on the rotisserie by flipping the front mount. With the front of the frame slightly below the axis of rotation and the rear slightly above, it’s perfectly balanced.
    I’m wondering if the rear bracket in the pics is for the leaf spring.
    Is that flat bracket for the fenders?
    IMG_6269.jpeg IMG_6270.jpeg IMG_6271.jpeg IMG_6248.jpeg IMG_6249.jpeg IMG_6245.jpeg IMG_6244.jpeg IMG_6268.jpeg
  16. Six Ball
    Six Ball
    from Nevada
    Yes that is for the spring shackle. That center piece probably screws out if you can get it loose. The other bracket I don't know. Too new for me. :D
    Jay Altemus, TFoch and 31chevymike like this.
  17. Your better off removing those original brackets and purchasing a new rear leaf spring mount kit from Speedway or other suppliers:
    Adjustable Leaf Spring Perch, Pad, Shock Mount and U-Bolt Kit
    • Multiple adjustable keys are included which allow you to fine tune the position of your rear axle housing up to 1/4” forward or 1/4” rearward from center
    • Allows you to properly center the wheels and tires in the wheel well of your car or truck for maximum tire clearance
    • These leaf spring lower shock mounting plate is made from steel with a zinc finish
    • Speedway Motors Part #9100151 for $116.99
  18. tb33anda3rd
    tb33anda3rd
    the bracket in the rear is for both the rear splash apron and fender
  19. Jay Altemus
    Jay Altemus
    Got a little bit more done today.
    The M2 front suspension is going bye-bye!
    Whoever bolted this on was either not paying attention, didn’t know what they were doing, or both. Maybe I should give them the benefit of the doubt and say they were just mocking up suspension so they could move the vehicle. I don’t know, but long before today I figured out why the p***enger side tire had positive camber. It has a shorter lower control arm.
    I’ll start looking for a 10 bolt rear axle (or other) that has a wheel mounting surface width of approximately 62.5 inches. Something with a 3.08 gear would be nice.
    I measured between the rear wheel wells. I got 47” – 49”. My wheels with tires mounted need at least 5 inches of backspacing. That brings me to right about 59”. Add a few inches for axle movement.
    IMG_6288.jpeg IMG_6285.jpeg IMG_6286.jpeg IMG_6287.jpeg IMG_6284.jpeg IMG_6281.jpeg IMG_6282.jpeg
  20. Now we're talkin'! Send that **** front end to the s**** yard where it belongs Jay! (We) are proud of you that at this point, you are building a REAL TRADITIONAL HOT ROD brother! Keep your progress going!
    Torkwrench, Jay Altemus and snoop74 like this.
  21. snoop74
    snoop74
    Glad you’re getting rid of that front end as well lol
    Jay Altemus, Six Ball and 31chevymike like this.
  22. Hey brother, you haven't got back to us about your '09 engine temps with your new spacers - any improvement on the road?
    Jay Altemus likes this.
  23. snoop74
    snoop74
    few of us went on a short cruise this weekend and it held up well in 100+ temps. I think the main issue I always had was at a standstill which most cars do with no shroud. But now it takes a lot longer to raise temps; and the fan is closer and higher. When really beating on the engine I'm around 180-190; just putting around 170ish.
    Six Ball, 31chevymike and Jay Altemus like this.
  24. snoop74
    snoop74
    Also got to meet some original members in the club from 1955 so that was super cool
    Too
  25. Glad your engine temps are back on track. Wouldn't have thought your car club started way back in '55, that IS SUPER COOL!!!
  26. snoop74
    snoop74
    Yep and there’s a couple of the original guys still alive one of which still drives his 32 around with us that he used to race.
  27. Six Ball
    Six Ball
    from Nevada
    I'd really like to find a plaque from my brother's club the Plugs from Canyon, Texas. The club was only active for a few years probably done in the summer of '58 when most of them graduated. There were likely only a dozen or so plaques. I was younger but they took me to the drags in Amarillo a lot.
    31chevymike and snoop74 like this.
  28. snoop74
    snoop74
    I bet there’s some stuff out there. One of the guys I talked to this weekend said someone had found a plaque being sold on eBay.. it wasn’t original but they bought it and gave it to him. Someone around that town probably has something. Maybe even antique stores
    31chevymike likes this.
  29. Six Ball
    Six Ball
    from Nevada
    These guys were all my brother's friends and at least 5 years older than me. We moved away 65 yers ago and the ones I knew are gone. I have a picture of one on a car. My brother's plaque was broken but may be around his old home in CA. Maybe I'll have some made from the photo.
    Anyway I'm glad your hot rod is cooler!
  30. snoop74
    snoop74
    Be cool if yall could find it. Appreciate it. Now just to finish the doors.. I need to do those and finish my exhaust.. the exhaust needs then downs so it stops coming through the louvers haha.. guess I’m going to put a inner skin in the deck lid too
