Finally Got a Henry J
Discussion in 'The Hokey Ass Message Board' started by swade41, Oct 3, 2010.
  1. swade41
    swade41
    from Buffalo,NY
    Now if we speculate my 230 lbs in the driver's seat it still wouldn't be 50/50 weight bias. LOL !
    (I did cheat one inch forward of wheelbase on the new ch***is from this photo)
  2. blue 49
    blue 49
    from Iowa
    I must have went wrong somewhere. Mine is about that much with a small block and no roll bars
    Gary.
    swade41 likes this.
  3. swade41
    swade41
    from Buffalo,NY
    I was really hoping to stay in the 2400's or low low 2500.
    When I thought of where the 190 lbs came from it does make sense when you break it down comparing apples to apples on the things changed.
    I did weigh it twice on different scale pads and it came up the same both times, also who knows if the scale at the track was accurate.
    Mitchell Rish likes this.
  4. swade41
    swade41
    from Buffalo,NY
    I put it out in front of the house where it's pretty flat, I'm the last house on a hill and my driveway has about a 4 degree pitch to it. Anyhow, to check the trans fluid because it seemed to loosen up the stall last time I drove it, it's the same converter I had in it and I knew the big block would make it stall higher, but just how much higher was unknown.
    The trans fluid was low so maybe it won't "float" as much on the next drive, getting it sorted out, by the way the extra fender clearancing did stop the shrill squeaking noise.
    I gave it a drink while at the truck stop, nice that the fuel guage works now.
    dana barlow, Chucky, mohr hp and 7 others like this.
  5. Dooley
    Dooley
    from Buffalo NY
  6. swade41
    swade41
    from Buffalo,NY
  7. swade41
    swade41
    from Buffalo,NY
    I got the garage funk off the paint using a clay bar this afternoon, I've hand washed it 3 times prior to no avail, but that thing did the trick.
    Saturday I changed the Autolite race plugs (same plugs from when I bought the engine) and they were very pig rich.
    I put my go to V power NGK's in it with a 44 gap, the Autolite race plug has a short strap so kind of hard to tell what those were gapped at.
    Car show in the city on Sunday, cutting through the city to get there, I immediately noticed it started faster and was a little more crisp. Anywho yesterday I looked through my jets and figured I'd knock a couple numbers out of the primaries since those previous plugs were so rich, go from 70's to 67's since I had 4 of those.
    I decided to pull a plug first and the damn thing looked pretty good for having city stop and go driving on it, timing mark looked close as well, so I put my jets away and I'll check the plugs again after some more driving on them.
    Car show was a flop, held at Buffalo's iconic Central Terminal train station, in the past you could browse the first floor and see the restoration work going on. They let you park your cars (mostly cl***ic and muscle type show) right outside the front doors, the Terminal is now in the ghetto part of Buffalo.
    Now the show is put on by tuner clubs, Terminal is closed and they moved the car show parking down into the streets of that fabulous area, show was very unorganized to boot, but they had a full stage with live "rap is ****" music drawing in the locals.
  8. swade41
    swade41
    from Buffalo,NY
    I've been trying to get the car out somewhere every week, still doing okay too.
    Somehow managed a couple more awards
    Today I decided to re-clock the steering wheel since everything seems to be where it's going to stay. While I had it off I decided to strip the black paint off the spokes and clean up the gold flake.
    Not sure what brand it is or why it was painted black or why they welded an adapter onto the back of it, but they did.
    I started with a razor blade up near the rim then went with paint stripper afterwards.
    It by no means looks brand new but it does look 100% better
    Then I inspected an old wheel center cap, same as I used in the gas cap, to possibly use as a horn ****on, maybe one day I'll get to that
  9. Baron
    Baron
    Glad your enjoying the Henry J. Drive the wheels off it now as the seasons will be changing quickly. Car looks great Phil. Come a long way from when you first brought it home.
    swade41 and lumpy 63 like this.
  10. 65pacecar
    65pacecar
    from KY, AZ
    Great job, looks like a fun car to drive. Enjoy!
    swade41 and Baron like this.
  11. 1940Willys
    1940Willys
    Glad I get to see this 'J' finally moving under it's own power. I know it has been a Long Haul for you. Gives me Inspiration.
    swade41 likes this.
  12. swade41
    swade41
    from Buffalo,NY
    Thank you, I'll be the first to admit the car is very raw and not for everyone.
    It's completely stripped of anything comfortable and of anything that weighs more than it needs be to go faster. It clanks, bangs, sounds tinny, no door rubbers, heat comes through the firewall, you have to climb over the roll bar, lift up on the doors to get them to shut and it's hard to turn with the full spool, but I'm part caveman and just love all of it.
  13. lumpy 63
    lumpy 63
  14. 69fury
    69fury
    from Topeka
    Features like that don't bother me at all. I'm keeping the bench seat to show the wife I really do want her around for the 3 am industrial district side by side pavement surface grip evaluations, but the other features you mentioned can help ***ure that she won't be interested... :)
    -rick
    swade41 likes this.
  15. swade41
    swade41
    from Buffalo,NY
    I finally gave the J a test hit, blew the 30x12.5 ET Streets right off and right on the limiter, jammed second, still on the limiter and getting squirrelly, damn thing is an animal
  16. Dooley
    Dooley
    from Buffalo NY
  17. mad mikey
    mad mikey
    Hell Yea, stay in it a little longer, heat those tires up.:);)
  18. swade41
    swade41
    from Buffalo,NY
    I agree but where I live is just to populated to to find a remote street to do shenanigans on.
    I had to go down this street twice and still had to pull over for cars to go by just so I could give it the beans.
  19. swade41
    swade41
    from Buffalo,NY
    Crazy as it seems this 1/2 mile long road is surrounded by 3 very large cemeteries and still has a ton of traffic on it.
  20. Baron
    Baron
    Just too many people, and too many cars today. :(
    mad mikey, swade41 and 427 sleeper like this.
  21. swade41
    swade41
    from Buffalo,NY
    Yes, this is where my house is (center left), lots of police to keep everyone in check, which is OK by me but not good for testing acceleration lol
    mad mikey likes this.
  22. 69fury
    69fury
    from Topeka
    Nice vid! I love this car. Absolutely *****in!
    You get those tires hot and hooked up to the ground and I bet she'll get up like Trigger on bath salts.
    -rick
    swade41 likes this.
  23. swade41
    swade41
    from Buffalo,NY
    Spring maintenance to address a couple issues found while driving it last season, first was the weeping intake at the two halves.
    Turns out, it ain't got no gasket in it ...
    So I made one
    Even got the holes in the right place
    It had ran rich, giving a puff of fat black smoke on the hit, so I knocked 2 jet sizes out of the mains and secondaries
    70 front to 68
    80 rear down to 78's
    All ****oned back up with the new gasket and jets
    If you recall the kill switch wouldn't kill it so I moved the alternator charging wire to the other post on the switch, hopefully that fixes that. I haven't put the battery back in it yet to test any of the new fixes.
    AHotRod, Chucky, dana barlow and 6 others like this.
  24. papajohn
    papajohn
    Uncle Joes first cruise night of the year today and its 79 degrees out!
  25. swade41
    swade41
    from Buffalo,NY
    I just seen that, gorgeous day out today for sure.
    I don't have anything ready, just ordered brakes all around and front hoses for the t-bucket, I really want to fix this brake line at line lock issue before driving the Henry J. I was looking at it today and it looks like it's weeping where the line goes into the farrel, odd place to be wet at.
    The 41 pickup only has a couple blocks drive time under it's belt so it's not ready for road tripping yet.
    mad mikey and papajohn like this.
  26. papajohn
    papajohn
    You didnt miss much. Maybe 75 cars. Too many new vettes, challengers and mustangs.
    swade41 likes this.
  27. mad mikey
    mad mikey
    That's a damn shame, happens in my neck of the woods as well. actually brings more attention too my hot rod, good and bad.
  28. swade41
    swade41
    from Buffalo,NY
    First start of the year, I think it likes the new gasket and jet change
    Edit : kill switch still doesn't kill it
    Chucky, mad mikey, loudbang and 2 others like this.
  29. mohr hp
    mohr hp
    from Georgia
    Sounds great. You have the coolest stuff.
    swade41 likes this.
  30. swade41
    swade41
    from Buffalo,NY
    Thanks, I think my next step is putting a diode in the alternator wire to see if back feeding is my issue with the kill switch not working.
    enloe likes this.
