Hot Rods Vapor lock/percolation. Its too damn hot
Discussion in 'The Hokey Ass Message Board' started by dogwalkin, Jun 26, 2024.
  1. YES! YES!
    Ben
    Chavezk21 and 2OLD2FAST like this.
  2. 55blacktie
    55blacktie
    Vapor lock was not unheard of before unleaded gasoline containing ethanol became commonplace.
    Ned Ludd, 2OLD2FAST and dogwalkin like this.
  3. flatout51
    flatout51
    I have a Phenolic spacer, holley aluminum heat shield, rubber isolator, and my fuel line wrapped with DEI heat wrap. Still have boiling after shutting it off and letting it sit on hot days but not so bad it won't start. Next I'll be louvering the hood.
  4. 05snopro440
    05snopro440
    My 80,000 km engine still had the cross-hatch visible in the cylinders. 36,000 km of mostly highway miles with a 160°F thermostat later I had the heads off, still has a nice cross hatch in the cylinders.
    I know you've been repeating this info occasionally for several years here. While I don't think the info you have from Summit is wrong, I think it's more telling that they don't seem to publish it anywhere anymore.
    This currently available help article from Summit Racing tells a little more accurate story, I think.
    https://help.summitracing.com/knowledgebase/article/SR-05284/en-us#:~:text=For daily drivers, coolant temperature,move around and wear faster.
    Particularly the last part applies to us:
    If your car is a basically stock daily, a 195°F thermostat is probably the ticket, but if you're worried about running a 160°F thermostat in your fun car because of accelerated cylinder wear, you'll most likely not own the car anymore when that becomes an issue. As long as you warm up your fun car before you beat on it or do any significant speeds, you shouldn't have much concern.
    seb fontana and Jalopy Joker like this.
  5. 05snopro440
    05snopro440
    I have the same setup. Mine tends to reveal itself just as I start moving after being parked or sitting a the stop light, when it surges due to vapour lock. My truck also has a return line from the mechanical pump. In my experimentation, when I take the hood off the vapour lock all but goes away. Once you're moving continuously, there are no issues. The heat getting trapped under the hood is what allows the fuel to boil in the carb on mine. Getting that air out does wonders.
    flatout51 and dogwalkin like this.
  6. I’m running a mechanical pump with return line on my 500. No issues with vapor lock.
    Toms Dogs and Bandit Billy like this.
  7. Bandit Billy
    Bandit Billy
    Like the one that @anthony myrick shows but made for a 427 Corvette so it costs more. There's comfort in that :cool:
    anthony myrick likes this.
  8. Bandit Billy
    Bandit Billy
    Pontiacs had issues right from the factory due to the fuel line routing in the engine bay.
    winr and anthony myrick like this.
  9. Bandit Billy
    Bandit Billy
    1/2" phenolic spacer is good if you have room for it. On my TA's it lifted the shakers up too far so I used this type. It did the job.
  10. proartguy
    proartguy
    from Sparks, NV
    GM used the fuel return system on ‘60s vehicles from Corvette to Cadillac. A insulating carb spacer and installing a fuel return solved my vapor lock symptoms. An electric fuel pump also cures a lot of issues if installed properly.
  11. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I don't know where everyone is talking about vapor lock. The OP is talking about percolation (fuel boiling in the carb). Especially when the car is turned off in hot weather, flooding the engine. The things mentioned in my post address this, which has nothing to do with vapor lock.
    dogwalkin and G-son like this.
  12. Circulating fuel back to the tank keeps the fuel temp lower.
    So it’s cooler when it gets to the carb.
  13. ClayMart
    ClayMart
    I think there's a lot of confusion as a result of not understanding that vapor lock only occurs on the inlet side of the mechanical fuel pump. Stock mechanical fuel pumps, even in working condition, are not designed to pull air bubbles thru the fuel inlet pipe from the tank. They are not an air vacuum pump. They must have an ample supply of purely liquid fuel which they can compress and discharge to the pump outlet to feed the carburetor. Once the liquid fuel leaves the pump under pressure it will easily displace any air in the fuel outlet pipe between the pump and the carburetor.
    Fuel percolation can still occur in the float bowl and fuel line from the pump and cause a flooding condition. But that's a different condition than vapor lock.
  14. Bandit Billy
    Bandit Billy
    Me no think they are listening too good to you, Senior.
  15. I’m no scientist
    The return has kept mine from hiccuping
    My mechanic buddy credits a return line and no fuel bowls for this not being an issue for EFI.
    We had a Holley with a bad boiling issue.
    Ran a return line and it stopped. I don’t know
    I just did what the boss said.
  16. 55blacktie
    55blacktie
    The OP did mention the possibility of vapor lock.
  17. 34Phil
    34Phil
  18. Jalopy Joker
    Jalopy Joker
    anymore potential solutions to carburetor gas boiling? going to get up to around 107 degrees by end of coming week in Sacramento, CA area
  19. Jack E/NJ
    Jack E/NJ
    from NJ
    >>anymore potential solutions to carburetor gas boiling?>>
    Amazon's choice. Pretty good reviews too.
  20. 1971BB427
    1971BB427
    from Oregon
    You might want to consider putting a fuel pressure gauge in the line before the carb to see what your pressure is. Even factory stock fuel pumps can occasionally run much higher than your carb is designed to handle, and I've seen more than a couple be up around 9psi. If it shows high pressure then simply install a pressure regulator and adjust it down around 4.5-5 psi and likely this issue will disappear.
    I put pressure regulators on everything I build whether they're electric or mechanical fuel pumps, just to avoid any issues.
    seb fontana likes this.
  21. Bumpstick
    Bumpstick
    Believe or not but here in So Cal it gets hot. I was getting bad vapor lock. (car stalling after about 20 minutes) I did the old Clothes pins on the fuel line. Haven't had VL since. Its been years.
    jimmy six likes this.
  22. George
    George
    Wood is an insulator, there's no way adding them to a fuel line could help cool the line. I did buy a car one time that had metal clothes pins on the fuel line, that could shed some heat, at least in theory.
  23. Jack E/NJ
    Jack E/NJ
    from NJ
    > > Wood is an insulator, there's no way adding them to a fuel line could help cool the line. > >
    Sure it can. Insulators help keep things cool or warm, cold or hot. Lotsa clothespins needed. Cork's good too. 8^)
    Jacksmith and SS327 like this.
  24. George
    George
    Most people put 1 or 2 on the fuel line.
  25. 55blacktie
    55blacktie
    Better call your AA sponsor.
    Toms Dogs and ClayMart like this.
  26. G-son
    G-son
    from Sweden
    This place is about cars. If we have to call anybody, we call AAA!
    clem likes this.
  27. ClayMart
    ClayMart
    Just out of curiosity, did you place them on the inlet or outlet side of the fuel pump, or both?
    Toms Dogs likes this.
  28. The real challenge is the open engine compartments with the carb bowls getting direct sunlight
  29. y'sguy
    y'sguy
    from Tulsa, OK
    I've battled this issue of boiling for years and tried most of the fixes mentioned here. They all help but It's damn hot and my car is black too! Vapor locked just last week right before I turned off back to my house. Luckily this time it restarted pretty easily with the electric pump, but it was really cycling fast.
    I would like to find some finned fuel line to try from the pump to the filter on mine. It's a vertical run and the fan blows right on it. I used to own a 74 Bronco with Pwr steering, a 302 v8. It had a finned section of tubing that seems like it could be adapted as a section of fuel line. I'm on the hunt for one to try out. Mine also still has a gl*** bowl filter so you can watch the fuel bubble easily.
    Sorta like this. But I would want it to have threaded ends not hose clamps
    I know Perma-cool makes a cooler that may adapt as well.
    winr likes this.
  30. 55blacktie
    55blacktie
    You might have better luck with Uber or Lyft.
