Technical Alternator from Hell
Discussion in 'Traditional Hot Rods' started by MikeG5211, Jun 29, 2024.
  1. MikeG5211
    MikeG5211
    Alright so I have this GM one wire alt, I wanna say its about five years old.
    Every once in awhile I would have to re-excite the field winding because it periodically stopped putting out voltage. I did this say maybe 5-10 times since I've had it.
    Well I can't get it to re-excite now, but if I run a 12v wire to the field winding it will put out.
    Now this is where I'm running into more problems, I had hooked the field winding up to the ignition switch but kept blowing ignition switch fuses, sometimes right away, sometimes after going several miles, but she would blow. I tried up to a 30 amp and she blew too.
    Thought maybe between everything on the ignition switch, plus the field winding, it was just too much. So I bought a relay, wired it up so the field winding would be on its own circuit and fuse and activated by the ignition switch, but still even on its own circuit it blew the 20 amp fuse I started off with.
    I checked the field winding for a short to ground and didn't get anything, I'm pretty confused by this whole thing, thought maybe someone could shine some light on the subject.
  2. Sounds like my last girlfriend . . . . every once in a while I had to "re-excite" her . . . as she stopped putting out. LOL
  3. '49 Ford Coupe
    '49 Ford Coupe
    I think at this point I would just buy another one...
  4. Are you talking to Mike or Bored and stroked?
    Ben
  5. squirrel
    You have a one wire alternator...but you are doing something with the field....
    I don't understand. Is it a 3 wire alternator? or how did you get to the field winding?
    Johnny Gee likes this.
  6. 57 Fargo
    57 Fargo
    How about some pictures or a drawing of how it’s wired or something to help us help you.
    G-son and dirt t like this.
  7. MikeG5211
    MikeG5211
    Alright I think I got it figured out, I opened the alternator up and found a broken wire that goes from the voltage regulator to the bridge rectifier. It didn't look factory, I bought it from Bennett, so either they or their supplier converted it to 1 wire I'm guessing.
    I put in a new wire, put it back together, spun it up with a drill and she puts out again!
    I'm also guessing that broken wire may have been bouncing around inside and periodically grounding out which is probably why I was blowing fuses.
    1971BB427 likes this.
  8. MikeG5211
    MikeG5211
    My mistake, what I hooked up to was actually the voltage regulator tabs, marked R and F, reference and Field but they're actually bridged together I just learned while taking it apart. 0630240722a.jpg
  9. BJR
    BJR
    That is one crusty looking alternator. I think I would just buy new one anyway.
  10. joel
    joel
    Looks like the regulator terminals are pretty corroded; I'd suggest a new regulator.
  11. alchemy
    alchemy
    And whatever you were doing to the poor thing to make it that crusty, stop. No electrical components will function in that condition.
    Okie Pete likes this.
  12. '49 Ford Coupe
    '49 Ford Coupe
    Please notice the subsequent responses. No, I'm just one of those "practical" types. Thank you for trying to****ess my condition and intentions.
  13. leon bee
    leon bee
    I think he lives real close to the coast.
  14. :D:D. Just yanking your chain! Seems it worked!
    Did not mean any offense.
    I agree on practical.
    Now, back to the original problem with the alternator.:p
    Ben
  15. Yes, that "jumper" wire is used in conjunction with certain regulators, to make them one wire alternators.
  16. RodStRace
    RodStRace
  17. I only use internally regulated alternators.....not one wire. Internally regulated are much more reliable
  18. squirrel
    One wire alternators are internally regulated. They just have no external reference.
  19. ClayMart
    ClayMart
    I'd have to try thoroughly cleaning those terminals with some emery cloth, giving them a light coating of dielectric grease and building a new jumper wire with some real weatherproof connectors. Seems like a quick and easy way to verify if that's where the problem is.
  20. Kevin Ardinger
    Kevin Ardinger
    Maybe she had blown a fuse as well!
    '34 Ratrod likes this.
  21. MikeG5211
    MikeG5211
    She's working pretty good now, I don't see any reason to replace it. its bottom mounted in a T bucket so you know she's gonna get a little wet from time to time. I suppose I could top mount it to negate some puddle splash but either way it still fully exposed to rain. Ill run it til its belly up.
    Cooon likes this.
  22. squirrel
    you found the problem, you fixed it, great!
    Desoto291Hemi and RodStRace like this.
