rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Woogeroo
    Woogeroo
    from USA
    oooh weeee, sounds like too much excitement!
    glad you kept it out of the wall.
  2. We have so much power now we need to make a ch***is adjustment.
    Woogeroo, chryslerfan55, Tim and 3 others like this.
  3. milwscruffy
    milwscruffy
    Will you be replacing the rear coil-overs with the struts Jerry had made up to make it a solid rear ?
    427 sleeper likes this.
  4. No. It's going to Brian metzenheims ch***is shop. He was jeg cauflins pro stock ch***is man. He is the local ch***is **** in this area. It will be scaled then a four bar adjustment. Jerry has the car making so much power and there's so much left in it. At 300 feet there is not enough down force on the tires. Kilpatrick had the same issues in the past. Metz made adjustments and cured it. A converter car is different from a clutch car. They can't be treated the same.
    TFoch, chryslerfan55, enloe and 6 others like this.
  5. I have bars to make the rear solid. That won't change the amount of force the ch***is puts on the rear tire. Every fast street car and pro mod uses a suspended ch***is. It can be done I just need to hire a expert that's way more knowledgeable on the subject than me.
  6. kabinenroller
    kabinenroller
    Cool,
    And Brian drives a Comet! He knows his stuff, it runs in the family.
  7. milwscruffy
    milwscruffy
    Know him and he's the guy, known his Dad over 40 years and a gear head through and through. Brian will get you dialed in. He also took the reins over for his Dad's 27 Ford T big block roadster (RatSo), a true 9 second street car from over 25 years ago.
  8. 20240630_173820.jpg 20240630_173847.jpg 20240630_173925.jpg 20240630_185601.jpg The lenco is apart for servicing. I have several gear options. It had a 144 and a 25 in it. I could tug it harder with a 134-25 or a 25-25. Most all funny cars use a 25-25. That's what I'm going to put in. To make it leave harder more timing will go in.
  9. While at the race Danny Sullivan stopped by. He is looking great compared to the last time I saw him. He thanked me and gave me a hug. He wanted to hear the story because he doesn't remember any thing. Several of his friends stopped by to. It was very cool. If you don't know the story go back a page or two. 20240629_163022.jpg
  10. The full crew this past weekend. We have never posed for a pic like this. 20240629_175456.jpg
  11. 19Eddy30
    19Eddy30
    from VA
    Brian , I have been watching your thread since 2015 , watching/ reading along / detail ,
    I am a no one , I have my thoughts ,
    ( just my thoughts to me)
    Not wanting to start argument,
    The car has revolved to close / max of the body Design shape ( brick) , modifications to Arrow of body are going to required, (new engine conbo)
    & Down force on front & rear
    90 -125 wheel base , You ready know
    Hand full,
    The ch***is builder , Brain Metzenheims
    Recommendations needed !!
    If you are going to report to thread , what Brians recommendations ,
    Body modification, Arrow ,
    Down force ((Wings)) ,@ 125 wheel ,,
    Stretch from 125- 150 , ( Wings Down force)
    New ch***is , or with modifications to capability
    of adding pre load adjustments in the frame itself ,or in double rails,
    Hard tailing ,
    P/s & P/mod ,T/sportsman each different in there own , & your current ch***is much different characteristics than the others,,
    There are several A/Fc & type cl***es with your style ch***is switching other over to converter set up like yours to hard tail ...
  12. It's already 125 inches. The same as a modern funny car.
    Ch***is adjustments will be made.
    Trans ratios will be made.
    Stupid ugly wings will never go on the car. The guys putting those things on are no ero engineers. If you not testing in a wind tunnel you don't know if your helping or hurting. The angled roof acts like a big wing. There are a lot of ways to skin a cat.
  13. 19Eddy30
    19Eddy30
    from VA
    I know your wheel base is 125 ,
    Do you remember , over last few year , there been a few questions or suggestions made and innocently suggested/maybe take a look at,
    There was several questions ignored , I get !! Who is this punk !!
    a No one ,,,
    last was your zoomies, In way you wrote / describe it was a big task, ?
    Brian a long the way of this thread You have made comments to questions asked a few others & me ,,
    Some answered and some ignored.
    You did not need certain things you were gonna do it the old-school ways,
    ( Just 3 of many not )
    Ch***is /Frame, shocks ,Grid ...
    Not a Jungle Jim ch***is,
    There are many things you are using
    Not old Fashion way ,, I get it !!! You have installed /using modern technology because it's needed,
    The you call Stupid Ugly Wing,
    Do you Really think a lot of us add if we do not need when you get to certain point of speed & Et ? The down force and to stabilize.
    Off topic but about down force ,
    To get a Pro stock /Pro mod License is one of the most expensive and difficult to get, because of No down Force ?
    $60K -100k ,, 2-3 current license drivers
    Present every time the car goes down the track because No Down Force
    slick Arrows compared to a Brick,
    Square Flat windshield,
    If the Rules would let , There would be Wings/ more down force added , Even in MoTo bike ,like F1 of
    bikes have Wings , 230 down straight away ,
    140 plus laid completely over in turn.
    Down force & Arrow required,,
    Do not know your goal ,
    6:99 @210
    6:80's 215-220ish
    6;50s 240 -250
    Not asking your goal,
    Would think if Drag only Now
    Clutches in the Can instead of converter,
    More work thoe , fine tunning adjustment track /tracks
    In last month I know of 3 cars locals get balled up @ legit on Tour NHRA 1/4 tracks in 1/8 & one Legit IHRA 1/4
    They where 3:50 -3:80s
    Limited To Down Force by rules!!
    Not enough down force ,,
    Brian
    I like one day to hear read about
    Satisfied and accomplish of your goal whatever they might be in 1/4 ,
    Brain , To me the car was more
    Unique on Dual Fuel Street /Drag,
    $$$ & some issues, But was unique to its own and you did it, Dual Fuel !!
    Brian , not for sure it was you or here
    Was it you stadding in side a wind tunnel ? Like I think @ MOPAR
  14. The thing with the wing is maybe some day I would need one. When that time comes is the time I won't try to go faster. I agree on the unique comment on the duel fuel. I might go back to it someday after this phase plays out. If i do a wing that means holes in the body for struts. Im not doing that. I just don't like the look. I try to keep it looking old. I use modern parts when necessary. I have covered the clutch thing before. I can't access it for service. I can't get to the inspection cover for the feeler gauges. The entire car would need to be re worked to make the body hinge from the back.
    This is a rapidly changing car right now. We are zeroing in on 200 mph. Everyone's input and ideas are welcome here. Some questions are not answered because the answer would get so detailed and long it might bore people or I might not have a answer. More to come. It's 6am and I haveca lenco to build.
    TFoch, bchctybob, saltflats and 8 others like this.
  15. Calkins
    Calkins
    Bryan Hall went 5.98 @ 240 in the Tramp without retarded looking wings, spoilers, or canards. Brian doesn't need them either.
  16. Calkins
    Calkins
  17. Calkins
    Calkins
  18. Calkins
    Calkins
  19. Calkins
    Calkins
  20. Calkins
    Calkins
    If you are not Facebook friends with some of those people, you may not be able to see the video. Some of the other videos are public.
    milwscruffy likes this.
  21. 19Eddy30
    19Eddy30
    from VA
    Pull Brains 30-31 MOPAR body the way it is , Mount on The Altered/ Fc ch***is shown , will not Act , handle , go threw air the same way,
    Watching Norwalk race , seen a few
    T/Fc windshield start to cave in again .
    I went 220 25years ago my self with a ch***is like shown
    125 wb NHRA/IHRA A/Fc piping
    chryslerfan55 and porkshop like this.
  22. mohr hp
    mohr hp
    from Georgia
    chryslerfan55, racer-x and enloe like this.
  23. mohr hp
    mohr hp
    from Georgia
    I think I get what you're saying. Brian has a combination that is pretty much a one-off. When you're mixing ch***is/motor disciplines and styles, there's bound to be some decision points where it's pretty much uncharted territory, and you have to take a guess as to what will work. He's no dummy, and I think he has some sense of self preservation. I'm a big fan of these shenanigans.
    No doubt, wings would help a bunch, but there are a very few newstalgia fuel altereds are still out there showing it can be done without much aero. I just saw Pure Hell in Bowling Green, and they definitely have an ironed-out combination that puts down good numbers with no aero. I'm not claiming I could figure it out, I've had my *** handed to me a time or two, but I'm pretty sure it could be done, repeatedly.
  24. 19Eddy30
    19Eddy30
    from VA
    Was not putting down Brain , @ Least it was not my intentions to,
    Just gets to a point @ around 200 thing get funky ,
    In 1994 a family member was running
    A all steel street car none chop 32 5 w with fenders , was a hand full , Blown , tubbed on Mcorys , hand full @ 155 around
    900 ft thew 1/4 , Brick ,No cage ,@
    Speed World tossed out 2nd p***
    About Dual fuel ,
    I have said before , I Only know of Two
    Cars running/ Ran dual fuel
    Brian , MOPAR @ a black 1932 roaster from
    Cali around 1957
  25. Part of not wanting to put a wing on it is the fact I might put it back on the street. What do I do with at least four big holes?
    TFoch, bchctybob, Woogeroo and 3 others like this.
  26. mohr hp
    mohr hp
    from Georgia
    Chucky and impala4speed like this.
  27. DDDenny
    You've come a long way baby!!!
  28. Dick Stevens
    Dick Stevens
    :eek::oops::eek::oops::eek: Hell NO!!!!
    oldsroller, racer-x and Calkins like this.
  29. 19Eddy30
    19Eddy30
    from VA
    I am with Brian on cutting up on body ,
    Rear struts could be slip join out from under body , to be removable , front struts Would have to go threw Sail panel, Quarter , Deck lid .
    In my 32 I have been wanting to use a
    Lenco , or clutchless trains , I do not want to cut up floor & remove original seat, also wanting to add 10-12 point
    Jungle Gym ( roll cage) but not to run back bars out side of body , want one like Fryberger F-Rod with engine plate maybe mid , & Jungle Gym all slip joint & removable ,& keep all four fenders , It needs one now , that why I only run the 1/8 100-115 mph , 4 link none tubbed
  30. The car is now making some power. It's spinning the tires at 300 feet. Now let's get into lenco gears.
    I have a 3 speed trans. I can run it as a two speed I just need a gear engaged.
    As a three speed my 1st gear ratio was a 1.86. This was too much. It was almost un driveable. So I started shifting it in second gear that made it 1.25. That calmed it down alot.
    I have a second lenco with 25 percent gears in both cases. If I shift it as a three speed the first gear ratio is a 1.56 if I leave in second it's a 1.25. Most modern day funny cars use the 25-25 gear ratios. So I will try it as a three speed again geared down. If the track is good and it sticks the 60 foot times should drop. It should also create more speed before 300 feet. This should help it not spin the tires as all the timing is coming back in.
    So how do you make more power to pull the gear? Timing. Timing is everything on a nitro engine. Having the ratios close to each other makes a hemi happy.
    As far as the ch***is tuning goes Brian Metzenheim will be hired to scale and set up the ch***is next week. I will bring the bars to eliminate the shocks. We will have a discussion on them. Whatever he recommends on a instant center along with shocks or no shocks will be followed. A setting can be made to apply more pressure to the tire as the car goes down track. He did it on a buddies car that's similar to mine.
    So between the ch***is the gears and the grid we should be able to get it dialed in by the fuel altered nationals. We are closing in on 200 mph. Jerry Newman swears it's got a 220 -230 in it.
