Hot Rods Top Banana Style Slingshot Dragster- Marty Strode-Chris Kopp.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 7, 2024.
  1. Marty Strode
    Marty Strode
    porkshop likes this.
  2. Marty Strode
    Marty Strode
    Today, I traveled down to Chris's place, to see all the work he has put into this job. After he got finished with some radiuses on the mockup, he ***embled it, and got it mounted to the ch***is. There will be more ribs before he starts shaping metal, but it certainly gives you an idea of the final shape. IMG_0713.jpg IMG_0714.jpg IMG_0717.jpg IMG_0723.jpg IMG_0728.jpg [/ATTACH] IMG_0732.jpg IMG_0733.jpg
  3. j hansen
    j hansen
    I only use it on steel and iron,but If I remember correctly it is to aggressive on Alu and Zink.
  4. Marty Strode
    Marty Strode
  5. AmishMike
    AmishMike
    Great looking start. What are specs on falcon as a side note?
  6. pirate
    pirate
    from Alabama
    Yes citric acid will etch aluminum. I would not try to clean any polished aluminum. It tends to turn aluminum a gray/dark gray surface. It does an amazing job on steel/cast iron and other ferrous alloys. This clutch pressure plate and disc were covered with surface rust on all internal and external surfaces. I made a bath of 1/4 to 1/2 cup citric acid to a gallon of water until parts were covered with solution and soaked for 48 hours in a plastic container from Lowe’s. Powdered citric acid can be purchased from Amazon fairly inexpensively. IMG_2184.jpeg
  7. Marty Strode
    Marty Strode
    Looks like it does a great job, thanks. I have a set of rods and pistons out of a 327, that the rods have some light rust from condensation. If I have the pistons pressed off, there is a good chance of breaking a piston. I could make a rack that would have the majority of the rod submerged, and get them cleaned up.
  8. Marty Strode
    Marty Strode
    That's my 65 Futura, factory 4 speed, came with a 289. I bought it in Aug '71, and it has 269,000 miles. I also have a 65 F100 that I bought in April '73 that has over 400,00 miles. I refer to the Falcon as an "old white car, for an old white man". 2014-01-25 093201.jpg IMG_0688.JPG
    prez, bymanr, couverkid and 9 others like this.
  9. Marty Strode
    Marty Strode
    Just when I thought I could trust Chris, he sends me this picture !
    prez, bymanr, 1971BB427 and 11 others like this.
  10. DDDenny
    I've always enjoyed studying these types of photos before the skin is installed, it's a lot like seeing a hot rod or drag cars' new ch***is and suspension before the body goes on, always a bonus for me.
    Something a lot of people don't realize is that having this kind of metalforming skill is only part of the picture, a guy needs to be pretty good with the wood buck building aspect too.
    porkshop and chriskopp like this.
  11. Marty Strode
    Marty Strode
    Chris is the whole package, and a practical joker to boot !
    chriskopp, porkshop and brEad like this.
  12. AmishMike
    AmishMike
    We love old hi miles cars but salt on winter roads eats them alive.
  13. redo32
    redo32
    @Marty Strode something to consider about rust stripping the rods in an acid solution is hydrogen embrittelment. It will affect higher grades of steel more that mild steel. I admit I am more familiar with harsher acids like hydrochloric and plating solutions than I am with citric acid.
  14. j hansen
    j hansen
    alanp561 likes this.
  15. Marty Strode
    Marty Strode
    Thanks, I can probably do a decent job with a wire wheel.
  16. redo32
    redo32
  17. RodStRace
    RodStRace
    Don't let him paint your helmet!
    porkshop, chriskopp and brEad like this.
  18. chriskopp
    chriskopp
    when opportunity strikes…
    porkshop, Dick Stevens and alanp561 like this.
  19. SDhotrod
    SDhotrod
    Love witnessing all this craftmanship. Talented people!
  20. krazee
    krazee
    Marty, I recently have just done that, but wrapped the pistons in cling wrap and dropped the rod in the solution. I check twice daily until I get the result I need. I used to do it this way in a white vinegar bath until I forgot some pushrods and found the vinegar ate material.
  21. Marty Strode
    Marty Strode
    Thanks.
  22. Larry Anderson
    Larry Anderson
    I’ve seen the truck before but I can’t quite place it. I think it was a movie or some damn thing. Incredibly familiar
    chriskopp likes this.
  23. Larry Anderson
    Larry Anderson
    Similar but had a lumber rack
  24. Marty Strode
    Marty Strode
    Yes, and Alan Arkin was driving it !
  25. Stan Back
    Stan Back
    I didn't know you were building a woody.
    Dean Lowe and brEad like this.
  26. j hansen
    j hansen
    Or a duckbill,,,,,,;)
  27. Marty Strode
    Marty Strode
    No, Woody's early Dragster looked like this. I get it, you mean a woody wagon. Notice the nose on the car behind him, The real Top Banana ! Woody and Hank.jpg
    bymanr, Dean Lowe, 1971BB427 and 6 others like this.
  28. AmishMike
    AmishMike
    Do not know how far u are from body builder but would love to see more pictures of work in progress. Sheets of aluminum cut, bend in place, welded up small pieces. Love your projects
  29. RodStRace
    RodStRace
    @AmishMike , the body builder is here on the thread too. It's @chriskopp. I don't know how willing he is to stop and take pics and share all his secrets, but judging from his replies so far, he's a craftsman and a gentleman. Just don't let him get behind you.
  30. Marty Strode
    Marty Strode
    Chris is about 40 miles from me, it takes me about an hour to get there. Never any traffic, just a twisty road over a mountain, and a scenic drive. He will be taking pictures, and I will try to get some video, as it would be great to see him operate his big two headed hammer, and other machines. It would also be fun to capture the banter we have during the build process.
    Dean Lowe, brEad, chriskopp and 10 others like this.
