Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. NealinCA
    NealinCA
  2. pprather
    pprather
    It's looking better all the time.
    31chevymike likes this.
  3. krylon32
    krylon32
    from Nebraska
    I'm not the sharpest tack in the box but how did you bend the rear of the frame up behind the c notch without modifying the rear floor? Did you have that much gap between the floor and the frame?
  4. NealinCA
    NealinCA
    The rear frame horns must have ****ed down when we c-notched it, as it was too far down. I looked at several original 5 windows when I was at LARS and they were much tighter than how my tank fit to the body. So I just returned it to how it should have been from the factory.
    Here's a couple of pics of Kennedy Bros 5w for reference. Mine fits very similar to this now 20240613_151327.jpg 20240613_151312.jpg
    And mine after bending the frame horns up
  5. Outback
    Outback
    from NE Vic, Oz
    That made me laugh! But see @NealinCA didn't deny it :D haha
    Seriously though, it's so good seeing this attention to detail.
    31chevymike, brEad and porkshop like this.
  6. NealinCA
    NealinCA
    I will preface this saying that I am not a gauge collector. Early SW gauges have always been out of my price bracket, but I stumbled upon most of a set one at a time through swapmeets and estate sales. I Just located a pair of the correct era SW mechanical temp gauges. 1956-ish big block logo, curved gl*** to replace the flat gl*** electric temp gauges. This will complete the quest for a set of curved gl*** 2-1/16 gauges, which incidently set the hypothetical build date for this whole car.
  7. dirt car
    dirt car
    from nebraska
    As has been a prior topic, those early 32 rails were prone to flexing over the axle, particularly with a full fuel tank, & who knows what junk was in the trunk over the years, then of course the optional rear mount spare tire, luggage rack, rumble seat (with the mother in-law along for a ride) & the roads less traveled of the day I'm sure were all contributing factors for the late year frame reinforcements.
  8. Corn Fed
    Corn Fed
    Gauges are just like chrome. If some is good, more is better.
  9. NealinCA
    NealinCA
    Got the trunk latched, picked up the clear Cerakoted polished aluminum parts for the engine and mixed up a light purple for the engine. Dropped the engine off with a friend who's gonna prime and paint it this week. Also plan to ***emble the transmission this week. 99 days until we leave for The Gathering at the Roc.
    I added in the reinforcing plate for the trunk support arm
    The lower catch had to be bent some and I re-located the upper bolt hole in the gutter to get the latch to catch
    With the new deck lid, there was no hole for the handle. I did have an original latch ***embly, so I screwed that into the decklid and used that as a guide for a drill bit through the square hole to punch a hole through the outer skin. I then used a step drill to get it to size and filed the notch to index the handle and to keep the base from turning
    Since all that will end up painted is the block (everything else is polished or plated) I sealed the engine up with and a temporary pan, timing cover, heads and water pump block off plates
  10. hotrodA
    hotrodA
    What a great car! Thanks for the updates.
    Greenblade, 31chevymike and NealinCA like this.
  11. kustomkat1950
    kustomkat1950
    from Coastal GA
    neat build, Neal. As a collector, I say your office needs a 1930/1940s art deco radio to complete...
  12. Such a cool build!
    Not sure how you are working in this heat today!
    I am up in Paso Robles for work and it is a hot one compared to the southern part of the 805.
    31chevymike and Outback like this.
  13. BigJoeArt
    BigJoeArt
    exciting! I can almost see the purple from here!
    cant wait to see it together with all the chrome!
    31chevymike, Outback and NealinCA like this.
  14. Roothawg
    Roothawg
    I love this thread. One guy spending countless hours on details people may or may not see. That's the difference between a real builder and an amateur.
  15. NealinCA
    NealinCA
    It's going together in bare metal for now, but there will be a few purple pieces to give the vibe. Paint is not in the budget this year, so I hope to work out the kinks and blow it apart next year for paint and upholstery.
    I don't know about "real builder", but it may be a guy with OCD...
    When a friend saw the pic of chrome rear mount, he told me, "I said to myself, this man is insane".
    He might be right.
  16. Weedburner 40
    Weedburner 40
    Yup, that's what happens when you blow the paint budget on chrome...;)
    31chevymike, 53 effie, brEad and 10 others like this.
  17. Outback
    Outback
    from NE Vic, Oz
    Hahaha
    31chevymike and Algoma56 like this.
  18. NealinCA
    NealinCA
  19. Why do I think your conversations with your chrome shop might sound like a junkie trying to get his next fix?! The term “All In” is so appropriate! Looks killer!
    31chevymike, porkshop, Tim and 3 others like this.
  20. Black Panther
    Black Panther
    from SoCal
    I follow this thread with so much interest. This has got to be the most well thought out, pro executed, period build I've ever seen. To see the steps in it coming together is a true inspiration. Neal, you are taking the hobby to a whole other level...I applaud you sir. Can't wait for more posts.
  21. alchemy
    alchemy
    I noticed the sealed bearing on the trans output. Do you have experience using these? Does the U joint stay lubed?
    31chevymike, Outback and Algoma56 like this.
  22. NealinCA
    NealinCA
    We have been using those bearings for quite a few years. We pop out the inside seal so the bearing is lubricated by the transmission. Then use the urethane clam shell seal and pump the u-joint cavity full of cornhead grease. Seems to work fine.
  23. alchemy
    alchemy
    What urethane clamshell seal do you get? My cork one is very leaky.
  24. NealinCA
    NealinCA
    I have bought them off Ebay
    Kind of difficult to install but seem to work well
    31chevymike, brEad, Tim and 5 others like this.
  25. NealinCA
    NealinCA
    Today's progress
    Chrome...
    And not chrome...
  26. Outback
    Outback
    from NE Vic, Oz
    That is going to look amazing!
    Greenblade and 31chevymike like this.
  27. Ken Smith
    Ken Smith
    Alliance Vendor
    Wow! I can’t wait to see it completed.
  28. The37Kid
    The37Kid
    I like your engine color, my first reaction was it reminded me of the Tognotti King T.
    31chevymike, brEad, porkshop and 2 others like this.
  29. Tim
    Tim
    from KCMO
    Fantastic
  30. Outback
    Outback
    from NE Vic, Oz
    I was thinking 'The take out T" but it's darker & more purple.
