Technical KONG Banger Front Driven Ignition
Discussion in 'Traditional Hot Rods' started by Retson the Racer, Jun 30, 2024.
  1. Looking for any info I can find on off the shelf parts I could use to get this working. This will be running front-driven on a Model B engine.
    Also attached is a photo of said front drive with a cap on it. Can anyone identify the cap?
    Thank you!
    Screenshot 2024-06-30 at 6.31.37 PM.png Screenshot 2024-06-30 at 7.18.33 PM.png
    turboroadster likes this.
  2. bushwacker 57
    bushwacker 57
    Kong Jackson and Ed Winfield
    ydopen, Outback and The37Kid like this.
  3. 29Sleeper
    29Sleeper
    from SoCal
    Somebody's homebuilt electronic - late 50s ear;y 60?
    I've got a 1929 Mallory centrifugal advance dual point. I bought a Pertronix kit to change it over. You'll need to change the impulse ring.
    Got anymore detail photos? How does the advance work?
  4. Lil'Alb
    Lil'Alb
    from brier, wa
    It's functional, but I can't find rebuild parts for this old Mallory anymore, maybe I could convert to electronic?
  5. Lil'Alb
    Lil'Alb
    from brier, wa
    Sorry to hijack thread btw, but here's another pic. Electronic conversion seems like a nice way to prolong usefulness of obsolete Mallory distributors
  6. Lil'Alb
    Lil'Alb
    from brier, wa
  7. 29Sleeper
    29Sleeper
    from SoCal
    Mine is older than that one. It's the first generation and has provisions for the pop out ignition switch. My points are the same. You'll want to make a new point plate to mount the Pertronix on. The magnetic sleeve (in the Pertronix/Mallory kit) is very tight and will need to be opened up a little.
    I've also considered making some new point blocks and use the contacts and springs from the FD-66 (Ford flathead 8) that is available. 3/8 thick phenolic is available on Fleabay for $9 (4"x4") that will easily make 8-12 points. Here is a pic of the part #s. You need FD-67. points.jpg
    turboroadster, Okie Pete and Lil'Alb like this.
  8. Lil'Alb
    Lil'Alb
    from brier, wa
    Thanks! I screen capped your post for reference. That confirmed my su****ion that this Mallory shares parentage with the Ford V8 distributors, the vacuum brake is very similar and I've heard it said that Mallory was involved when Ford moved away from the driver's helmet style distributors. It would be really cool to run this as an electronic. Even my later aluminum Y-11 rotors are getting super hard to find.
    Okie Pete likes this.
  9. tubman
    tubman
    I make the correct vacuum brake leather pads for Mallory distributors so equipped; the Ford distributors (helmets included) use the exact same piece.
  10. 29Sleeper
    29Sleeper
    from SoCal
    inside.jpg US Patent 1886566 from 1929 - remember a patent covers ideas not specific products. You'll see how the individual parts in the patent were used in different distributors. The brake in mine is a phenolic block.
    Lil'Alb and Okie Pete like this.
  11. I feel as I should give this thread an update. I have discovered through some of Dan Iandola's photo archives, photos of this drive installed on this really bad*** roadster pickup. The story goes, the engine was a B block, C crank and a Cook overhead 4 port head with two winfields. According to the owner of the pickup, it was a prototype one-off ignition.
    I'm slowing getting it all figured out, but progress is progress!
    72895587423__47F24D0C-95E2-41A4-9809-B4BBAEF722CA.JPEG Screenshot 2025-01-19 at 10.59.50 PM.png Screenshot 2025-01-19 at 11.00.23 PM.png Screenshot 2025-01-19 at 11.00.12 PM.png Screenshot 2025-01-19 at 11.00.00 PM.png
  12. hipojoe
    hipojoe
    I was told by a few KONG used Toyota parts. This is KONGS last ignition before he left us. IMG_0854[260].JPG
    Fordors and turboroadster like this.
  13. banjorear
    banjorear
    I believe the last versions used Toyota caps & rotors.
  14. 25mercury
    25mercury
    Retson, pretty sure the cap you show is a GM with the quarter turn clips and you would lift the door to adjust the points with an allen wrench.
    Retson the Racer likes this.
