Projects Model a
Discussion in 'Traditional Hot Rods' started by The Chevy Pope, Oct 30, 2023.
  1. So the vehicle I'd previously posted a thread on in this section fell through. I'd delete the thread but can't figure out how lol. Anyway a few guys that were going to be doing some trading with me on part of and for it basically told me they'd basically make sure I got what I actually wanted.... model a roadster or coupe. They aren't going to give the pieces to me but prices were extremely reasonable. To the point I decided to where I decided I'd go ahead and make a generic model a thread with pics of parts I already have and fill in the details when I have at least most of the body on hand. Way the dudes are dealing with me as a new member reflects extremely well on the forum. Anyway what I have or will FOR SURE be picking up soon lol. Luckily the few parts I had or had already secured for hhr other project will work fine on a model a. Also have a complete 57 Chevy power pack 283 I'll be rebuilding Screenshot_20231030-192930.png Screenshot_20231030-192953.png FB_IMG_1698711507633.jpg FB_IMG_1698711503886.jpg
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    So you'll build this 'from the ground up'
    My favorite is the A Model. I'm goofy for most all pre war makes and models.
    But A has my heart. Looking forward to updates
    Have Fun
  3. Oh for sure. Was always the plan to one day completely blow apart a model a and do a ground up build. And a 28/29 coupe and 30/31 roadster (equally desirable in my eyes) are tied for number one with a 56 Chevy 210 two door on my top five rods I want to build list. This thread may actually turn into two model as to be honest. Both h.a.m.b.'rs I mentioned are offering me decent starts on both a 29 coupe and a 31 roadster. So depending on how fast the first one goes I may build a second. but yeah I've wanted a model a since I was a little kid
    Outback, Tow Truck Tom and Okie Pete like this.
  4. Joe Blow
    Joe Blow
    I'd go ahead and snag that Uberti 1873, that someone left out there in the woods, too.....
    Nobey, Lil'Alb, rwrj and 1 other person like this.
  5. Belongs to the buddy that owns the property. Didn't realize he was hunting when we were messaging lol
  6. Would it be sacrilege to use a 31 grill shell on a 29? Lol
  7. Grumpy ole A
    Grumpy ole A
    The ‘31 has a different shape than the ‘29. The 29 is more rounded. You could use a 31 radiator and shell but the hoses will be a problem.
    The Chevy Pope likes this.
  8. It'll have a small block Chevy (57 283). And may have a suicide front end. Eventual plan will be a 32 shell.
  9. I just know of a nice 31 shell for fairly cheap
  10. 29Sleeper
    29Sleeper
    from SoCal
    Taller and narrower. The hoods are also different. All 28-31 radiators have the outlet on the bottom left and in inlet in the center on top. The A uses straight hoses.
  11. So looking like a 29 coupe will be the likely rod to officially take this thread. Also pretty much decided to buy what both members were offering. Meaning I'll have most of a 29 coupe and half a 31 roadster. And an extra set of 29 closed car doors. I could potentially end up with three bodies total as I've own a 29 cowl for over 15 years. May put that extra cowl with the extra doors and scavenge to either make a sport coupe or a custom pickup cab. In any event on the 29 I'll be doing more 60-62 era style on it. So I'll be using my 55 Pontiac rear end along with the 57 283 I mentioned. And already have a 57 Chevy bellhousing and flywheel along with tins, shims and a reman 57 Chevy starter. The 35 Ford trans and rear end I'll likely save for the 30/31 roadster project.
    On the 55 Pontiac rear end I'll need to switch it back to the stock Pontiac/olds bolt pattern though
  12. Illustrious Hector
    Illustrious Hector
    I did ,so let the HAMB police come "C'mon youse lousy cops ! I'll plug ya, see!
  13. Got a pic?
  14. ClarkH
    ClarkH
    In my experience, the 28/29 shells are cheaper and easier to find than the later stainless steel versions. Going rate at local swap meets is around $50; 30/31 are twice that. This is for shells that may need a little work. Early shells being steel makes them easier to work on.
    Tow Truck Tom likes this.
  15. Also a possibility that I'll save up for a brand new Brookville body. Always really wanted one. If I do that it'll be a 30/31 roadster
    Outback likes this.
  16. Nobey
    Nobey
    Something to think about while you gather parts. The 28/29 front cross members are different
    than the 30/31. The 28/29 have a higher radiator pad then that of the 30/31, the later pads sit
    lower in the cross member, that being said, if you build a 30/31 and put it on a 29 frame, the
    shell will sit to high in front to align a hood. Also the the 30/31 radiator is taller, so if you want
    to run one on your 29, just don’t run a hood. Either way it won’t hurt my feelings. Have fun…..
  17. Zax
    Zax
    My Roadster, the one in my avatar pic, is a 28 ch***is and drivetrain with a 31 Brookville Roadster body. The front crossmember was replaced with the 30-31 style. Other than than not much had to be modified.
  18. I honestly would prefer a 28/29 coupe. And like mentioned earlier in this thread another member offered me one for a really good price. But they may not have it by the time I come up with their price. A second choice is a 30/31 roadster. Grill height isn't of too much concern as any model a I do will be fenderless and hoodless and channelled even with the frame. So there'll be grill reworking regardless. If I do a roadster I'd want to make it particularly nice. Hence why I'm leaning Brookville. And something else different from how I'd do a couple is if I did the roadster I'd want to go y block
  19. Figured I'd post this here. 29 aa cowl I've literally had 20 years. Picked it up during the s**** metal craze that start in 06. Was on a bizarre contraption. Shortened aa frame with the original dually axle welded to the frame. Had a second transmission with the input shaft welded to the output of the first transmission. One factory bucket seat bolted an odd bracket. And a crazy cage. Apparently a local family in that county was land rich but cash poor and turned it into a log skidder. Apparently this skidder helped get them to where they were one of the more well off families in that town. Nice people. IMG_20260608_200822976.jpg
