Hot Rods anyone here ever build a bobber????
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Jul 1, 2024.
  1. ALLDONE
    ALLDONE
  2. ALLDONE
    ALLDONE
    I wanna do one with a for bangher and a tall tt cab..
  3. Billybobdad
    Billybobdad
    He used to sell his ch***is on here as Vaphead but for some reason was banned
    chryslerfan55 and 2FORCEFULL like this.
  4. 6sally6
    6sally6
    The kicked-up(Z-ed) rear section of the ch***is......is that why its called a bobber.
    (for some reason the name bobber reminds me of an old girl friend)...jus say'in.
    6sally6
  5. ALLDONE
    ALLDONE
    Did she ever live in vegas???? I think I know her
    jet996 and chryslerfan55 like this.
  6. ALLDONE
    ALLDONE
    i got a ch***is and cab, and side walls for a bed.... IMG_2800[8826].jpg IMG_2801[8825].jpg IMG_2802[8824].jpg
  7. ALLDONE
    ALLDONE
    I was gonna cut the cab up and make a hackney depot rig....but can't seem to get on a path for the build...
    IMG_2061[8646].jpg IMG_2076[8650].jpg IMG_2207[8711].jpg IMG_2668[8773].jpg IMG_2669[8772].jpg IMG_2670[8771].jpg
  8. twenty8
    twenty8
    That cab is way too early for a "bobber", isn't it?o_O
    You will end up with a fenderless Model T phonebooth pickup............ and that would be just fine.
    Bobber would be '35 onwards cab....???
    chryslerfan55 and caprockfabshop like this.
  9. ALLDONE
    ALLDONE
    i've got all the stuff to make one of these...
  10. twenty8
    twenty8
    Yep, 1924 tall T pickup........... or sometimes called a "phonebooth".
    Seems you are going around in circles. We already did this dance in another of your threads........
    iwanaflattie and 26 T Ford RPU like this.
  11. Marty Strode
    Marty Strode
    My Brother built this from scratch, aluminum cab, steel box, gl*** fenders.
    Magfiend, 2FORCEFULL, Lil'Alb and 6 others like this.
  12. caprockfabshop
    caprockfabshop
    Your model T cab will NOT fit on that 35-46 ch***is, it's too narrow and short.
    Bobber trucks refer to the post 1935 Pickups on fenderless truncated ch***is, and while they certainly can be built to appear traditional, I'm not aware of any historical precedent prior to like 1980 where they were commonly done by vintage rodders.
    Sounds like you need to decide what kind of build you want to do, and then need to ***ess if you're capable of fabrication and completion of it. Certainly a hell of a lot cheaper to buy one done nowadays vs trying to build something from scratch.
  13. mohr hp
    mohr hp
    from Georgia
    Better have short (or NO) legs!
  14. twenty8
    twenty8
    There is a reason they were tall............:D
    2FORCEFULL likes this.
  15. MCjim
    MCjim
    from soCal
  16. ALLDONE
    ALLDONE
    the tall cab is 46'' in side.... bout the same as a model A with a recessed fire wall... RPU's are about 50''
    but, being you sit taller... plenty of room..
    I own a fab shop that builds ch***is.... mostly young guy air bag just, and off road stuff, lifting and lowering...
    thats the reason for the posts is I can't seem to stay on a track... I like the cab with the long bottom doors... but would hammer the roof about a foot...
  17. ALLDONE
    ALLDONE
    getting any bites???
  18. ALLDONE
    ALLDONE
    now thats badd ***.... wonder what it woul;d look like chopped about a foot..
  19. caprockfabshop
    caprockfabshop
    Still doesn't change the fact that the frame in your original post is for a 35-46 Truck which is significantly wider than you T body. So I ***umed based on that obvious disparity that you would have to use a different frame for your T.
    Of course, you can't have a T "Bobber" because if you just channel a T truck cab over a T ch***is it's a T Hot Rod, so the term "bobber" no longer applies to the build.
    twenty8 and 2OLD2FAST like this.
  20. ALLDONE
    ALLDONE
    here's where I stopped and can't seem to cross the road..... the T/TT cab has taller door bottoms...which would work ok to channel it.... but, I think it would look way off it you chopped it and run it full fendered....
    I bought this turn key, but all the wood was rotted beyond repair, so I took it off... so I was gonna build another hackney hotrod depot truck....but, I also have this cab.... and being honest here... I wake up in a differant word every day.. beings I have beenworking on hot rods for 60 years,... this has set in.... can't loose a nickle,... I should just take my hickey and send it down the road..... but, can't even make my self do that...
  21. ol'stinky
    ol'stinky
    from New Jersey
    You don’t want that frame, it’s too big. Get a T-bucket frame or get the plans and build it yourself. If you put a short bet with TT cab it won’t be a bobber, it’s just a T-bucket with a roof. Well actually with the bed length you showed in your examples, you just want to build a Model T truck. Either way I think that may be too much frame for that little body.
    caprockfabshop and 2FORCEFULL like this.
  22. ALLDONE
    ALLDONE
    the cab is 52'' wide....I was thinking to over come the long door bottoms.... to channel it??? then chop the top....
  23. A Boner
    A Boner
    Marty’s brothers looks like a human being would actually be able to drive it comfortably. Looks really slick too!
    Lil'Alb likes this.
  24. Mr48chev
    Boy howdy this got way off what the OP askes in short order.
    A bobber truck is a fenderless, often channeled 35/41 cab with a "bobbed" as in shortened bed on it. Example the blue truck in post one.
    When he was on here as Vaphead and selling ch***is to members and couldn't deliver the goods to the buyers for what ever issues he had going on at the time he got banned.
    Boling brothers sells a similar frame.
    I've always wanted to build one since the guy who ran the local Shell station in the early 60's had a chopped, channeled and bobbed 36 Ford with a small block Chevy in it. I may have the sectioned grill shell off that truck in my stash that I bought at a swap meet about 30 years ago. Screenshot (499).png
    caprockfabshop likes this.
  25. ALLDONE
    ALLDONE
    I does not seem that I'm lost.... I am lost, everytime I get on a path to finishing this it gets shut down.... any other time when I say, here's what I'm doing, there are hundreds of post , " If I were you I would do this"............................ So, how bout some ideas... I got a t ch***is with an A motor 12v, cross steering, juice brakes, 34 front axel...fenders , running boards, hood and grille.....annd the tall TT body....I just can't picture any way to put it together.... I've got wires... 16's, 18's, 19's and 21's
    here's how it looked when I got it....
    IMG_2060[8645].jpg IMG_2063[8648].jpg IMG_2064[8649].jpg IMG_2096[8666].jpg R (3).jpg
  26. ALLDONE
    ALLDONE
    this is the frame I was looking at, I own a shop and there is no way I could build a mandrel bent T frame for 2K
    5-12 Model A & Model T Ford coupe, sedan, pickup, roadster hot rod frame | eBay
    I figured with the tall T cab, and slammed ch*** it would look somewhat decient and you'd have something when it was done?????
    but,.... what the hell do I know.... I'm just and old man in a young mans world...
    but, I could just Z my frame and call it a day...??????????????????
  27. ALLDONE
    ALLDONE
  28. toad611
    toad611
    from Tennessee
    IMG_0035.jpeg This is the bobber I built!
  29. twenty8
    twenty8
    My head hurts......
