What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. T. Turtle
    T. Turtle
    What's not to like. I wouldn't do it any other way (well maybe a manual box but that's just me).
    drptop70ss likes this.
  2. raymay
    raymay
    Yes I did Billy, Next up is another favorite year car. I took a 66 Malibu 4door Wagon and am in the process of converting it into a 2door Nomad style build.
    seh, whtbaron, 51pontiac and 26 others like this.
  3. drptop70ss
    drptop70ss
    from NY
    Current low buck build, three trucks into one and ending up with a 1956 Chevy 1/2 ton short bed. Jaguar IFS, S10 rear and springs, ranger hangers, monte carlo driveshaft, 5.3/60e fuel injected, 4 wheel disc brakes, etc. $5000 budget for the full build. Tires on the back to simulate weight for suspension setup LOL.
  4. guthriesmith
    guthriesmith
    I didn’t even notice the leaning tower of tires until I read your comment. That is cl***ic. :D
    That should be a real cool pickup on a budget. :cool:
    enloe, swade41, Okie Pete and 3 others like this.
  5. drptop70ss
    drptop70ss
    from NY
    Thanks, should be a fun one, trying to use up parts I have around and keep the costs down.
    enloe, Okie Pete and guthriesmith like this.
  6. TRAVLR
    TRAVLR
    Helped Dad set the dwell on the farm dump truck after changing the points and condenser. 1966 GMC 4000 with a 351 GMC V6.
    The GMC V6 distributor caps do not have the "window" in the cap to set the dwell while running like other GM points style distributors... so you have to shut it off after checking the dwell, take the cap and rotor off, and change the point gap. Then put it back together and check again.
    Good times!
    enloe, 29A-V8, Okie Pete and 3 others like this.
  7. HOTRODPOWELL
    HOTRODPOWELL
    Teaching the next generation how to make dreams come true while learning skills 4AE86ECF-2B42-4CEE-94EC-003181702EFF.jpeg 63CE1391-6B09-43B3-B2E1-D4814401B28D.jpeg
  8. guthriesmith
    guthriesmith
    enloe and Okie Pete like this.
  9. guthriesmith
    guthriesmith
    My oldest son and I put the transmission back in his Camaro today to figure out that the slave cylinder is likely the wrong one. :mad: The previous owner had installed a cheap single disk clutch in place of the original dual disk and it came apart. Anyway, we put a dual disk Lingerfelter clutch back in it but I was trying to skimp on spending money on the fairly new slave cylinder. Pretty sure it is longer than he one needed for the dual disk. :( Good news is that we should be quicker taking it out and putting it back in the second time…:oops:
    67drake, swade41, 29A-V8 and 3 others like this.
  10. SS327
    SS327
    View attachment 6118344 [/QUOTE]
    That is good news! You can never get enough practice at some things! :D
    guthriesmith likes this.
  11. Balljoint
    Balljoint
    My Mom had two Ramblers when I was very young, both a pinkish color, they didn’t run real well but they got us where we needed to go. It’s a rare sight to see one nowadays but I try to get a good look at them whenever I see one. Prayers for you on your knee, I hope it’s on the mend.
  12. JohnLewis
    JohnLewis
    Put the transmission back in for the 3rd time. Got it pulled out, cleaning the inside. Putting the interior back together. Still 4 weeks out for the front wheels. IMG_0403.JPG IMG_0404.JPG IMG_0407.JPG
  13. Sandcrab
    Sandcrab
    I mounted some rollers on the wire wheels and mocked up the Ruby with the 215.
  14. RmK57
    RmK57
    New intake and a new carb to try out and all plumbed and ready for a test. I’ve tried a few different carbs and the bigger I go the faster it runs…..so an entry level 4500 series.
  15. JohnLewis
    JohnLewis
    Wheels showed up early. Interior finished. Got it scheduled to be tuned and aligned next weekend. Get the mustang pulled in and start on the fuel injection after this is finished. IMG_0443.JPG IMG_8611.JPG
  16. Okie Pete
    Okie Pete
    IMG_9429.jpeg 3 u-joints and one carrier bearing in the 946 Versitile tractor
    29A-V8, deathrowdave, enloe and 2 others like this.
  17. swade41
    swade41
    from Buffalo,NY
    Are you going to put the Jag rims on the rear too ?
    enloe likes this.
  18. HOTRODPOWELL
    HOTRODPOWELL
    4D0722E0-DF86-4090-86CB-8141C9453014.jpeg Youngster is learning 3AD36A6D-FEC0-4080-A8C8-538E1A5898CF.jpeg
  19. spanners
    spanners
    Aren't Jaguar same stud pattern as Chev?
    swade41 and enloe like this.
  20. Dick Stevens
    Dick Stevens
    No, Jaguar is 5 x 4.25 and Chevrolet is 5 x 4.75
    enloe likes this.
  21. twenty8
    twenty8
    Some are 5 x 4.25 (108mm).
    Some are 5 x 4.75 (120.65mm).
    None came with 5 x 4.5 (114.3mm).
    Dick Stevens likes this.
  22. guthriesmith
    guthriesmith
    More Ot ****. Fixing to learn how to rebuild a torque tube in this car owned by my youngest son. I sure like working on simple old stuff better…at least in my comfort zone. I think I am paying for getting my kids into cars.
  23. deathrowdave
    deathrowdave
    from NKy
    DB728B4B-7F5E-4C55-8335-8C41A129796D.jpeg 2791434B-B93C-486D-BFEF-0B07889132FE.jpeg 2E42C040-B9BE-4B6E-B6EC-7FA2ADA0E39E.jpeg DD055FC4-920E-441E-AFFA-3D0532FAB54C.jpeg DB728B4B-7F5E-4C55-8335-8C41A129796D.jpeg Cleaned a clutch out of one of the Harleys , goin back together . Lesson well learned AGAIN , China racing clutch not near as good as HD OEM clutch . Silly me again
    29A-V8, swade41, Okie Pete and 4 others like this.
  24. JohnLewis
    JohnLewis
    Sometimes those prices are hard to p*** up though.
  25. guthriesmith
    guthriesmith
    Understood. I have only replaced one clutch in a Harley and I think I put a Barnett in it? That was about 25 years ago and I remember there was no letting the clutch out easy anymore. It was basically in or out. I even tore it apart during Sturgis to see if I had put something together wrong. :oops:
    Anyway, this is the other OT deal I am working on now as well. Started tearing my bike down yesterday to replace the tensioner on the timing chain. I’m at least hoping that is what is making the whining noise. My buddy that works on bikes regularly didn’t even have to think when I told him what it was doing and how many miles it has on it. Hoping to find out if he was right this week when I finish getting it apart.
    Okie Pete likes this.
  26. deathrowdave
    deathrowdave
    from NKy
    D9C65EB1-BD88-4BFC-9BF0-8B19D576D5FE.jpeg Silly me , I had the OEM stuff on hand , wanted to try high performance clutch , totally junk . HP unit had 5 threaded studs , OEM 3 threaded studs design was great , manufacturing was total junk . Sheared off 3 of the 5 studs .
    29A-V8, swade41, JohnLewis and 3 others like this.
  27. Lloyd's paint & glass
  28. guthriesmith
    guthriesmith
    I think I found the problem inside the torque tube… Seems someone either forgot to tighten one of the bolts or didn’t use Loc***e. Whatever the case, they did replace the rubber couplers with aluminum. So, appears my kid is just out labor and not parts to fix this deal.
  29. JohnLewis
    JohnLewis
    IMG_0492.JPG Got the mustang down to the shop. See how far I get with it this weekend. Could use a good cleaning, buff and polish. 62k original miles, bought it off original owner. IMG_0485.JPG IMG_0486.JPG IMG_0488.JPG IMG_0489.JPG IMG_0490.JPG IMG_0491.JPG
    51pontiac, Squablow, ffr1222k and 5 others like this.
