Hot Rods 1926 Tudor build hopefully this time
Discussion in 'The Hokey Ass Message Board' started by cb1, Jun 5, 2024.
  1. cb1
    cb1
    from Wisconsin
    20240604_161154.jpg 20240605_172056.jpg 20240605_172109.jpg 20240605_172117.jpg 20240605_172127.jpg I had a '26 roadster in parts with a good ***le, but didn't care for its size, so I let the body and frame go a couple years ago, but kept the ***le. I have been gathering a few 47-53 Chevy GMC trucks, mostly in the heavier persuasion, but have always had a eye out for a '26 Tudor. For some unknown (to me) reason, one popped up on the marketplace I jumped on it, and am glad I did. The body is almost perfect. Finally I get a win. LOL.. I just want to buy or build a ch***is for the parts I have been saving and get something on the road. More to come, again, hopefully...
    hrm2k, Gasser 57, RICH B and 2 others like this.
  2. cb1
    cb1
    from Wisconsin
    20240605_160130.jpg 20240605_165319.jpg 20240605_165305.jpg 20240605_165314.jpg 20240605_165336.jpg 20240605_165326.jpg A couple more pictures. The roof wood is damaged. Not sure how I am going to go with that. Would like a steel replacement, but I see that they (T's) are a bit different than by brothers '30. The rockers (?) are the best I have ever seen in the wild. Again, I'm really happy.
    hrm2k, Gasser 57, GuyW and 2 others like this.
  3. rusty rocket
    rusty rocket
    Damn nice body! I’m sort of fond of 26-7 T’s. I have a few. 24135FCB-D864-4180-9432-721C3B447B4F.jpeg 9F015014-2C74-41EA-A5CB-6A851BDD4AC1.jpeg
    hrm2k, Tow Truck Tom, RAT "T" and 2 others like this.
  4. cb1
    cb1
    from Wisconsin
    20240606_165235.jpg 20240606_175702.jpg 20240606_175727.jpg Make a tool Thursday!
    Enjoy!
  5. cb1
    cb1
    from Wisconsin
    20240613_192332.jpg 20240613_192348.jpg 20240613_192404.jpg 20240613_192417.jpg Even a body this good has some surface crusties in places hard to get to unless you go all the way. The good news is almost all the bolts thread by hand once loosened. A bit more progress. Enjoy..
    hrm2k, Gasser 57 and Tow Truck Tom like this.
  6. cb1
    cb1
    from Wisconsin
    20240613_181300.jpg 20240613_181308.jpg 20240613_181336.jpg 20240613_181330.jpg Reunited the firewall with the ch***is. The neighbor wants this in the worst way, but he never sells any of his treasures, it's always a trade. He will have to step up this time. Just sayin..
  7. The37Kid
    The37Kid
    That body is just about perfect, was there a reason the remove the firewall?
    Tow Truck Tom likes this.
  8. cb1
    cb1
    from Wisconsin
    Going to have a recessed firewall for a V8.
    hrm2k and Tow Truck Tom like this.
  9. cb1
    cb1
    from Wisconsin
    20240616_184026.jpg 20240616_184050.jpg 20240616_184131.jpg 20240616_184135.jpg Did a bit more work on the T tonight. I measured the firewall opening for future reference and those that are of interest. 24 inches between the firewall braces, and 30 inches between the sheetmetal cowl sides. I also dug out a piece of wood on each side that had no appearent reason for being there. And the wood screw holding it there was behind a riveted brace. I think it probably shrunk over the last 98 years, and was there for support the distance between the braces during construction. I see there is two in the back corners as well, but haven't got there yet. And, the inside of the cowl at the bottem is nice, just had some dust and sand, etc. Enjoy.
    hrm2k likes this.
  10. Latigo
    Latigo
    Looking good!
    I’ll follow along.
  11. cb1
    cb1
    from Wisconsin
    Traded the T ch***is for a TT frame.
    Enjoy 20240703_121026.jpg 20240703_121049.jpg 20240703_121100.jpg 20240607_205014.jpg
    Just Gary and Tim like this.
  12. cb1
    cb1
    from Wisconsin
    Found two bolt holes that lined up perfectly with a 27-1/2" firewall to end of front frame measurement.
    Enjoy! 20240703_163156.jpg 20240703_163211.jpg 20240703_163226.jpg 20240703_163239.jpg
    Tim and Kelly Burns like this.
  13. krylon32
    krylon32
    from Nebraska
    Have you done any research about the T sedan built by Little John ****era? It set the bar really high for T sedans.
  14. cb1
    cb1
    from Wisconsin
    Need some examples of lowered T front suspension. I am using a TT frame (will use a different rear axle setup) and the cars and one-tons share a bunch of parts with the 26-27 having the biggest differences from what I read. So, what I would like to do is keep as much as possible, i.e., the front crossmember. So, a different spring mounted behind the axle with a 6" axle drop, etc. This is my first rodeo regards early hot rods, so bear with me and correct when needed. Currently the TT sits at 24-3/4". I will put around 750-800 pounds on where the engine will be going after a different dropped front end and the get the ride height where I want it and work on the rear-end. How much can I loose in height with what I have planned. I would be buying a hairpin style, behind axle, spring front from a supplier. Recomendations there are welcome as well. Also, the 6.50x16 ag tires will not be used, LOL. So, I should loose some height with correct wheels and tires. 20240704_154413.jpg 20240704_154336.jpg 20240704_154522.jpg Thanks.
    Enjoy
  15. cb1
    cb1
    from Wisconsin
    Little John's, a tribute car, and Revells models as a panel. I will be going panel and be filling in the rear side windows, and no fenders of course. Thanks for the reply.
    hrm2k and Just Gary like this.
  16. cb1
    cb1
    from Wisconsin
    20240705_113915.jpg 20240705_113922.jpg 20240705_110656.jpg 20240705_110650.jpg 20240705_110534.jpg The TT frame looks to be 5 gauge steel. Measures .213, and when factoring some paint, .209 works out to be gauge 5, so that is good. A bit thicker than 3/16ths the frame makers use. And its real 100 year old steel.
    Oh, and since I'm a Chevy kind of guy, looks like they needed some GM parts for the last build, LOL.
    Enjoy
  17. cb1
    cb1
    from Wisconsin
    And, I'm really digging this front end setup! Front_End_Detail_szd_large.jpg
    Just Gary likes this.
  18. cb1
    cb1
    from Wisconsin
    20240728_145659.jpg 20240728_145652.jpg 20240728_145713.jpg 20240728_145857.jpg 20240728_145916.jpg Been looking for a grill shell for this project and happened upon this 1921 Graham Brothers "stationary" engine. It has a little 4 cyl Dodge flathead in it dated 1920, and GB trucks started in '21, so that is how I came up with that. Looks like they made a small power plant out of it. Had to buy to whole works and got some other neat parts in the bundle. And, there is a nice rear crossmember that measures 38"s that will also work with my ch***is. I got a new Model A front crossmember in the mail the other day, so things are moving along...
    Enjoy.
  19. cb1
    cb1
    from Wisconsin
    A little down time today. I bought a new tool and had to try it out. The cats meow. Anyway cut off and de-riveted the cross-member off of the '21 Graham Brothers stationary engine I purchased a couple months ago.
    Enjoy 20240927_115122.jpg 20240927_115130.jpg 20240927_120309.jpg 20240927_160837.jpg 20240927_160915.jpg
  20. cb1
    cb1
    from Wisconsin
    A little more work this weekend.. 20240928_141203.jpg 20240928_141229.jpg 20240928_141212.jpg 20240928_141724.jpg 20240928_170833.jpg
    lumpy 63 likes this.
  21. cb1
    cb1
    from Wisconsin
    More work today. Need to buy a frontend and then set it down and then I can vision the rearend. Not sure how much farther I will go for this spin.. 20240930_160029.jpg 20240930_160034.jpg 20240930_175448.jpg 20240930_175456.jpg
    GuyW and hrm2k like this.
  22. cb1
    cb1
    from Wisconsin
    20241004_142443.jpg 20241004_153900.jpg 20241004_162553.jpg 20241004_162602.jpg 20241004_162608.jpg Another day. Worked a bit on the frame while waiting on the compressor to keep up with the needle scaler on the safe I am restoring.
  23. Deuce Lover
    Deuce Lover
    Dec 69 R&C.jpg The one I built in 1968.Have better pics but they are all photos from back then.Rectangular tube ch***is(J&J Ch***is),real Bell tube axle(Mustang Disc brakes) and Jag XKE rear. Silver gray mohair interior. Had to take a loan from my Credit Union to have the $600 uph done. Jake of the orig Pete & Jake painted the body in his driveway in Compton,CA ,I did the fenders.
    34 GAZ, GuyW, Just Gary and 2 others like this.
  24. cb1
    cb1
    from Wisconsin
  25. cb1
    cb1
    from Wisconsin
    VERY Nice. Thanks for the post and reply...
  26. cb1
    cb1
    from Wisconsin
    Just Gary and Chucky like this.
  27. cb1
    cb1
    from Wisconsin
    Bought a tool Thursday, brought door removal Saturday. The doors are not perfect by anymeans, but they are doors and these doors are hard to come by, so will have to work with what I got. That saying, without adjusting hinges, they are on for now. Good winter project getting them up to snuff.. Enjoy. 20241108_114041.jpg 20241109_110835.jpg 20241109_131418.jpg 20241109_131503.jpg 20241109_131447.jpg 20241109_131450.jpg 20241109_131409.jpg 20241109_131456.jpg
  28. verde742
    verde742
    YOU MIGHT LIKE
    lo c dan and cb1 like this.
  29. I wanted a T Tudor for the longest time.......something about the flat roof makes me think of Frankenstein.....love it.
    I finally seen one in person at the swapmeet and decided it's tight inside with 2 beefy people :).
    Great build thread....
  30. cb1
    cb1
    from Wisconsin
    I'm somewhat beefy, that is why I bought the '41 Master Deluxe. Plenty of room there.
    As a side note, it is actually wider inside than our '74 Corvette. LOL. So, there is that. Also, I spent a couple hours at the local junkyard with a ruler and there are virtually no vehicles that have as wide a roof as the Tudor. The Tudor roof measures 55 inches wide, and the closest I could get was a Super Duty 250 at 54 iches, but I need to verify again, as I measured a couple F-150's and they were only 50. The trucks look the same, but maybe the roofs were wider, IDK. Anyway was trying to find an steel top that could be grafted to the Tudor. The hunt is still on.......
