Discussion in 'Off Topic Hot Rods & Customs' started by sgtlethargic, Jul 7, 2024.
  1. ...
  2. squirrel
    I have a spool type brake line bending tool that I clamp in a vise, and it works for most of my bending needs, probably better than the one you showed above
    For working on drum brakes, I have the pliers that are used to install and remove the return springs. And a screwdriver type tool to do the shoe retaining pins.
    also an adjusting s****. And a cylinder hone.
  3. squirrel
    that's a distributor wrench. 1/2" for fords, 9/16 for chevys
    427 sleeper and sgtlethargic like this.
  4. 67drake
    67drake
    from Muscoda WI
    IMG_1906.jpeg IMG_1901.jpeg I never really got into brake pliers, so never bought a pair. My go to for drum brakes are my backing plate pin spring remover, and whatever they call the other tool. Bought them off the Snap-On truck in the early 80’s and been using them since. I haven’t seen my adjustment s**** in years, so I just use a screwdriver.
    My bender, which I use often for brake and fuel lines. My hone for wheel cylinder rebuilding, my universal “cube” for screwing rear caliper pistons in ( that tool ****s!) , and my never been used piston compressor. My kids say it’s the greatest, so I got it from them for Christmas years ago. I never used it! I just use my trusty old huge channel locks. I guess they are good for calipers with multiple pistons, but haven’t done one of those in years.
    nosford and Okie Pete like this.
  5. Okie Pete
    Okie Pete
    IMG_9341.png It’s used to make tight bends in hard tubing . Next to male fittings
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I find one of these handy on rear brake drums..............:D
    SS327, 67drake and Oneball like this.
