Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. nunattax
    nunattax
    horses for courses eric.its choc a block here morning and evening the infrastructure is unable to cope.need something that will trickle along when needed to.
    tb33anda3rd likes this.
  2. pila38
    pila38
    Didn’t think about that, you’re driving in a totally different environment than us over there
    nunattax likes this.
  3. pila38
    pila38
    Ripped it all back apart again. Time to clean up the ch***is and put it together for the final time.
  4. pila38
    pila38
    Got something done this weekend:
    Put the correct u-bolts in the front end:
    The shocks were slightly out of plumb and it drove me nuts, so this was my solution to get it right:
    Steering box had a ton of play in it, so I adjusted that:
    Then ripped the brakes back apart and cleaned them up and started cleaning and painting the ch***is:
  5. bubba55
    bubba55
    Looking good Eric - just don't spoil it and look in a mirror - hah -
    pila38 and nunattax like this.
  6. pila38
    pila38
    Haha….no worries, I broke all those long ago!
  7. pila38
    pila38
    Wheelies! No, just spraying some paint. Decided to paint the ch***is in sections. Started with the front suspension. The engine crane has been indispensable. It may spend a lot of time in the corner, but when you need it, you’re glad it’s there.
  8. pila38
    pila38
    More progress. Plan on getting the ch***is finalized this week and then back to work on the cab.
    IMG_4917.jpeg IMG_4918.jpeg IMG_4919.jpeg IMG_4926.jpeg IMG_4927.jpeg IMG_4928.jpeg IMG_4929.jpeg IMG_4932.jpeg IMG_4935.jpeg IMG_4934.jpeg IMG_4959.jpeg IMG_4960.jpeg IMG_4961.jpeg IMG_4962.jpeg
    swade41, loudbang and tb33anda3rd like this.
  9. pila38
    pila38
    This is the box my calipers came in, I got a kick out of it:
    swade41 likes this.
  10. nunattax
    nunattax
    hi eric tell me about your front disc kit .what diameter is the rotor and what thickness is the rotor.in metric or imperial chris
  11. pila38
    pila38
    Hey Chris,
    It’s a kit I bought from ECI probably like 30 years ago (not an exaggeration). It’s for a 41-46 GM axle which is what I had at the time and since I had that front end all redone and had the brakes and everything, I just stuck it under this truck. Essentially they are just mid 70s GM disc brakes (I always just use ‘75 Camaro parts for it). There is a bearing adapter that goes on the spindle so the inner bearing will fit, and the outer bearing I believe is from a Mustang II or Pinto of the 70s flavor. Should be an 11” rotor I think. The thickness I don’t know off hand, but can measure them tomorrow.
  12. pila38
    pila38
    Oh, and I swapped out the wheel studs for 3” ones for racing.
  13. nunattax
    nunattax
    the long studs was going to be another question
  14. Joe H
    Joe H
    I have the same type of kit on my '37 truck, I purchased mine in 1999 from Master Power brakes. It uses '70 - '79 Camaro/Firebird front rotors and stock single piston calipers, I believe stock small bearing ( outer ) and Ford inner bearing on a special made adaptor spacer. I will dig around and see if I can find the bearing numbers, I wrote them down incase I needed one. I maybe backwards on the bearings, Eric maybe correct, I do know one is a Ford. My truck has a rear axle from same years out of a Firebird, I have a manual brake master cylinder from a Mustang that had manual drums all around. I tried a Camaro master cylinder, but didn't like how it stopped. The Mustang unit works better with leverage I have, pedal setup is a universal from Pete & Jakes from 25 years ago.
  15. Joe H
    Joe H
  16. pila38
    pila38
    Joe, you may be right with the bearings. It may have been a ford inner/Chevy outer. I also have the bearing numbers written down, I’ll have to look them uo
  17. pila38
    pila38
    Ch***is is ready to go down the road, save for two things. It needs to be plumbed and I screwed up and put the rear shocks at different settings so it’s sitting crooked. Started cleaning the cab again yesterday to get it ready for primer and lizard skin. Then I can sit the cab back on the frame for hopefully the last time.
    Crusty Chevy, treb11, swade41 and 6 others like this.
  18. nunattax
    nunattax
    looking good
    pila38 likes this.
  19. pila38
    pila38
    Thanks Chris. I’m pushing hard to have this running by the fall and on the road by next spring. Sick of staring at it and wishing.
  20. pila38
    pila38
    Well…its been a bit, work has been really busy. However, I have managed to stay on this thing at night and some weekend days. I’ve just been really bad at posting (surprise, surprise). I’ll post some of the progress here now. Filled the unnecessary holes in the firewall. IMG_5044.jpeg IMG_5045.jpeg IMG_5047.jpeg IMG_5336.jpeg
    LAROKE, TFoch, tb33anda3rd and 3 others like this.
  21. pila38
    pila38
    Plumbed the ch***is for brakes and fuel. Need the cab on and engine in to finish that up. IMG_5075.jpeg IMG_5337.jpeg IMG_5338.jpeg IMG_5339.jpeg IMG_5340.jpeg IMG_5341.jpeg IMG_5342.jpeg
    LAROKE, TFoch, tb33anda3rd and 2 others like this.
  22. pila38
    pila38
    Cleaned and aged the valve covers, breathers, and intake. May not be everybody’s cup of tea, but I wanted that no nonsense look to the aluminum. Clean, but not polished. IMG_5293.jpeg IMG_5292.jpeg IMG_5294.jpeg IMG_5295.jpeg IMG_5296.jpeg IMG_5331.jpeg IMG_5332.jpeg IMG_5333.jpeg IMG_5334.jpeg IMG_5335.jpeg IMG_5343.jpeg IMG_5344.jpeg IMG_5345.jpeg IMG_5347.jpeg Also rebuilt the carbs, so the top end is ready to go.
    LAROKE, TFoch, tb33anda3rd and 4 others like this.
  23. pila38
    pila38
    Spent a lot of time doing some prechecks on the engine as well before sending it back for decking and balancing. Waiting on that to come back to me. Also have a new set of cylinder heads that I set up for the solid roller cam, so I’ve been keeping busy. Just started the distributor last night, should have that ready to go soon. IMG_5348.jpeg
    TFoch, Kreepea_1 and nunattax like this.
  24. nunattax
    nunattax
    i like it i think you can finish it
    pila38 likes this.
  25. bubba55
    bubba55
    Looking great there Eric - nice job on the ch***is - coming together nicely - heading down that finish line and grabbing that checkered flag
  26. pila38
    pila38
    Just keep plugging away, chugging to that line. Talked to the machinist today, going to be another three weeks before I get my block and parts back. Not ideal, but plenty of other **** to do until then.
  27. swade41
    swade41
    from Buffalo,NY
    Nice work, those pictures reminded me of my old setup
    LAROKE and pila38 like this.
  28. pila38
    pila38
    Hahaha…yeah, they look a bit alike! I knew you had good taste.
    swade41 likes this.
  29. pila38
    pila38
    Got the flamethrower painted this week, but had very little time in the garage this week. Oh well. IMG_5377.jpeg IMG_5389.jpeg IMG_5390.jpeg
    TFoch and loudbang like this.
  30. pila38
    pila38
    Finished up the flamethrower. Threw some new points in and cleaned it up. Left the weights and springs as in for now, we’ll see how it runs when we get there. Still waiting on the composite gear to show up.
    TFoch and nunattax like this.
