Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    yes, I'm coming to that conclusion,
    but not there yet.
    bchctybob and brEad like this.
  2. Tim
    Tim
    from KCMO
    Clever hold Down solution! I dig it
    Kelly Burns likes this.
  3. Dave G in Gansevoort
    from Upstate NY
    Great minds think alike. What's our excuse?
  4. VI Lonewolf
    VI Lonewolf
    afr gauge ground on the battery?
    Kelly Burns and Paul like this.
  5. Paul
    Paul
    Editor
    more on the erratic behavior of the air-fuel gauge.
    I pulled a bag of used resistor plugs from my stash,
    picked out a pile of plugs with decent color ceramics and overall good appearance.
    checked them with an ohm meter and set aside eight with similar readings, all around 6.42 +/- 0.02 (meter set at 20)
    and installed those in place of the non resistor plugs.
    now the AF gauge is working as it should again.
    it also seems to be running a little smoother with no noticeable loss in seat of the pants performance.
    when I spun the magneto on the distributor machine with both resistor and non resistor plugs the non resistor plugs had a noticeably brighter spark,
    which is why I put them in, thinking hotter spark would be better..
    now all things considered I'm not so sure.
    brEad, bchctybob, warbird1 and 3 others like this.
  6. Paul
    Paul
    Editor
    more little ****..
    I had the plug wires zip tied together to get preliminary fit length and routing.
    zip ties must go.
    I pulled a few stock wire brackets out,
    chose a couple that would work with some modification,
    a bit of slice and dice and
    bam! the zip ties are nothing but a distant memory
    now if there was an easy way to clean up the wires on the cowl.. 'tempted to cut a big ole notch there..
    View attachment 6124421 PXL_20240711_040216348.jpg PXL_20240711_174821468.jpg PXL_20240711_175041014.jpg PXL_20240711_193019736.jpg PXL_20240711_194607133.jpg
    rod1, brEad, The 39 guy and 11 others like this.
  7. Flatrod17
    Flatrod17
    Very nicely done Paul!
    Paul likes this.
  8. Dave G in Gansevoort
    from Upstate NY
    Don't cut the cowl! There's got to be a better way! I'm counting on you to find it, so I can plaigerize it!
    OFT and Paul like this.
  9. Tim
    Tim
    from KCMO
    I’ve seen a little scoop in similar situations not dissimilar to a steel toe off a boot. Not sure a notch with a scoop over it is any less distracting than a notch alone.
    I’m sure you’ll come up with something clever.
    Paul and OFT like this.
  10. RICH B
    RICH B
    Would it be possible to turn it 90°; run 4 wires straight out and on to the plugs on the left and turn the other 4 180° and loop around under and out to the plugs on the right?
  11. Paul
    Paul
    Editor
    the tach drive will only work for me in this position.
    bchctybob likes this.
  12. RICH B
    RICH B
    .....and I was thinking of the cable coming out the side when I was typing; but it didn't register when it came to turning the mag! duh!
    Maybe a 90?
  13. Paul
    Paul
    Editor
    'decided a notch was the solution to the plug wire mess.
    thought about fabbing something up with round corners.
    dang that sounds like a lot of work..
    instead of fabbing something totally from scratch I started looking around for something with curves and or round corners already in it.
    pulled an oil pan from the pile, a crusty dented 303 Olds pan, and thought that might fit the bill.
    cut a chunk out of it, cleaned it up and worked out most of the dents.
    did a quick layout to cut the cowl,
    and started hacking.
    no going back now.
    from there it's fit, trim, weld and grind.
    traced the new profile to the aluminum firewall cover and cut, file, fit and touch up the polish.
    squirt some rattle can paint and re***emble wet, only leaving a couple finger prints in the tacky paint.
    dropped the magneto in and fired it up.
    done.
    PXL_20240712_195644450.jpg PXL_20240712_195858701.jpg PXL_20240712_202659125.jpg PXL_20240712_205654054.jpg PXL_20240712_212401077.jpg PXL_20240712_224945378.jpg PXL_20240712_232640576.jpg PXL_20240712_233357209.jpg PXL_20240712_234401683.jpg PXL_20240713_014054959.jpg PXL_20240713_153509718.jpg PXL_20240713_164407583.jpg
    gonzo, bymanr, rod1 and 23 others like this.
  14. Tim_with_a_T
    Tim_with_a_T
    Looks like it belongs there!
    alanp561 and Paul like this.
  15. Tim
    Tim
    from KCMO
    Clean work
    Paul likes this.
  16. RodStRace
    RodStRace
    Beautiful!
    I was going to mention clocking it to the right, but then the choke cable picture popped up.
    I trust the owner but cringed when you said CUT. Should have never doubted you.
    I will be the goof that tells you everything looks great, but you want 5 and 7 wires separated. Just move five from 3rd position to first position. Induced spark. It looks better this way and there is enough of a gap, but IF you have issues, that could be it.
    brEad and Paul like this.
  17. Tim
    Tim
    from KCMO
    I was thinking move the cowl vent lid down towards the firewall and do something more convoluted but I dig how it came out. @BigJoeArt has a similar cowl notch in his T and I believe the dual fan special from your neck of the woods does as well.
  18. Dave G in Gansevoort
    from Upstate NY
    Nice solution. Great execution as always. Plaigerize only if I have to...
    Paul likes this.
  19. Paul
    Paul
    Editor
    thanks guys!
    RodStRace likes this.
  20. goldmountain
    goldmountain
    These are the kind of details that make a car stand out from the crowd.
    Paul likes this.
  21. Tim
    Tim
    from KCMO
    Anything new to report on this one?
  22. Paul
    Paul
    Editor
    hi Tim,
    nothing new to report, it gets driven fairly often weather permitting, mostly short uneventful trips, odometer shows just over 5k miles on the car so far.
    rod1, bchctybob, sko_ford and 4 others like this.
  23. Dave G in Gansevoort
    from Upstate NY
    Okay so how about a video or two for those of us still stuck in the garage for motivation? And play it loud!
    Okie Pete likes this.
  24. Paul
    Paul
    Editor
    this was at Riverdale Raceway in Toutle a couple months ago
    sorry not much audio..
  25. Tim
    Tim
    from KCMO
    Awesome :) reminds me of the videos @Jive-Bomber posts from time to time
    Paul likes this.
  26. Snicklefritz65
    Snicklefritz65
    from Mass.
  27. Tim_with_a_T
    Tim_with_a_T
    Gapped him lol
    Paul likes this.
  28. Dave G in Gansevoort
    from Upstate NY
    Looked good beating him…
