Projects My new ride - finally on the road
Discussion in 'Traditional Hot Rods' started by grdra1, Jul 9, 2018.
  1. grdra1
    grdra1
    My advice, only buy brand name USA items, ****, eagle etc, If there are cheap, do not purchase. I feel embarr***ed to mention that I purchased a set of pro comp connecting rods, that were absolute ****ing junk and required me to purchase **** products - eventually costing me double the initially purchase price. Any questions please ask. Glen
    chryslerfan55 and nunattax like this.
  2. grdra1
    grdra1
    The bad is the **** products that I made a mistake to purchase - The good is that the good products work awesome and this hotrod is awesome fast. Glen
  3. AmishMike
    AmishMike
    Old guy never saw before until last year on very mild easy street driver. Cheap imports got to be careful what buy
  4. grdra1
    grdra1
    Rockers were Proform.
  5. X38
    X38
    Ah, that brand. This can happen with them too...
    Outback and chryslerfan55 like this.
  6. grdra1
    grdra1
    I was having issues tuning an off idle stumble, felt the triple carbs were holding the engine back. I wanted to maintain the nostalgia look so I installed a pair of Edelbrock carbs, WOW, what a difference, engine now revs fast and clean, no stumble, sounds real strong, and that's without tuning - mixture screws 1 1/2 turns out. Yet to drive the car as a few little things to do and the weather is ****, cannot wait to tune and drive. Glen 20240711_154444[1].jpg 20240711_154437[1].jpg
  7. grdra1
    grdra1
    Took car for a drive a couple of weeks back, ran like ****, way to rich and not wanting to idle. Pulled the top of the carbs to check float level etc. Both carbs were full of **** (obviously been sitting for a while) and the front carbs metering rods were bent, also one carb was a 1406 and one was a 1405. I ended up rebuilding both carbs and now they are identical in specifications. It started up first go and runs like a dream, took it for a short drive and its so much better than before, from standstill it fry's the Tyres. Yet to dial it in but more than happy with the result. Glen 20240726_174911.jpg 20240726_174925.jpg 20240726_174930.jpg
  8. grdra1
    grdra1
    My 31 recently had cylinder head issues, heads are tired so I decided to replace with some alloy units. I purchased a set of cheap heads from Skip White ( whiteperformance ) on Ebay USA, they look all right for cheap heads, I plan to clean up the ports a little and maybe port match to intake. I also needed roller rockers and a stud girdle and tall rocker covers to compliment heads. While I'm changing heads I decided to fabricate some new headers as well, today I worked on collector position, pipes will be 2 inch and use header plates to suit my SBC, a few pics Glen f6db5457-8336-4f4a-b8e8-6df97c7f5055.jpg 20250711_170545.jpg 20250711_170549.jpg 20250711_170554.jpg 20250711_170600.jpg 20250711_170605.jpg
    chryslerfan55, rjgideon, Tim and 5 others like this.
  9. catdad49
    catdad49
    You better close those ports up quickly, it looks like an invite to multiple Mouse Houses!
  10. grdra1
    grdra1
    A few pics of recent progress, Im so happy with how they are turning out. Glen 20250720_184822.jpg 20250720_184829.jpg 20250720_184836.jpg 20250720_184841.jpg 20250720_184848.jpg 20250720_184859.jpg
  11. grdra1
    grdra1
    A few more pics ccd336b0-3904-4874-b9ec-26238f5eeb31.jpg cf629b05-df7b-47e7-88a3-d91e990e914b.jpg 3621a75f-e363-4cad-bdb6-2c440716fece.jpg 340107ba-6520-42ec-9e77-de4ab9d983dd.jpg
    Outback, rjgideon, Deutscher and 4 others like this.
  12. Gary Addcox
    Gary Addcox
    I like your Model A style.
  13. Tim
    Tim
    from KCMO
    Holy cow those are tough as nails! Huge improvement over the old set as well, love the look of the car with them
  14. grdra1
    grdra1
    A few pics of recent progress, welded up headers and modified exhaust to suit. Still a lot of work to go, but so happy with how they are turning out. Glen 450ff518-13d6-4795-aa53-89bd6c92fac6.jpg 20250724_201812.jpg 20250724_201817.jpg 20250724_201823.jpg 35997133-616c-4d0c-bc4b-cb4ec922c6a6.jpg
    rjgideon, Outback, Deutscher and 3 others like this.
  15. Outback
    Outback
    from NE Vic, Oz
    Wow, looking great, hope to cross paths somewhere
  16. grdra1
    grdra1
    Thanks Outback, pipes are finished now, next job is to match port heads and intake as well as clean up intake and exhaust ports, a few pics. Glen 20250728_154624.jpg 20250728_154700.jpg 20250728_154705.jpg 20250728_154724.jpg 20250728_154731.jpg 20250728_154742.jpg
    justntime, Robdski, Deutscher and 4 others like this.
  17. grdra1
    grdra1
    Started porting heads and measuring spring pressures etc, using my home made equipment, my spring tester may not be 100% spot on but it gives me a guide on how all springs compare to each other. Also adding 1 inch spacers under Carby's, a few pics. Glen 20250731_175321.jpg 20250802_165204.jpg 20250802_165209.jpg 20250802_165220.jpg 20250802_165241.jpg 20250802_173257.jpg 20250802_173306.jpg
  18. grdra1
    grdra1
    My car is finally on the road again, lots of little dramas during the rebuild but Im overall happy with the result, This hotrod pulls like a train in any gear, has more down low power and more legs up top, and I feel the new pipes look the part as well. A few pics, Glen 20250824_165945.jpg 20250824_165954.jpg 20250824_170019.jpg 20250824_170024.jpg
