Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. MP&C
    MP&C
    We needed to modify some upper door trim to hold our peep mirrors. We opted for the old school look of the peep mirrors but did not want to use the clamp on paint chippers. The ends of the upper door trim uses a machine screw through the door and into a nut plate. Our plans are to use a formed hole in the trim and use the hole in the door to attach the mirrors.
    As we had used the tail stock of the South Bend before with success, we made some press dies to match the mirror's stepped end and provide a flange in the holes for added strength.
    Initial trial run on a practice piece
    This gives us more of a look like it belongs there instead of clamping onto and chipping fresh paint...
    Trial test of the mirror, yellow rag hung outside the rear window for a more visible reflection
    gonzo, Deutscher, alanp561 and 29 others like this.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice solution Robert.
    I hate the job those clamp-on mirrors do on the paint, even with a plastic liner under the clamp they eventually break through the paint.
    chevrolet50steve and MP&C like this.
  3. MP&C
    MP&C
    Some 1-1/8” louvers that we punched in collaboration with Cody Walls
  4. chrisp
    chrisp
    Some small parts made for that Alfa I posted earlier :
    Both side grilles
    Doors window frames (one polished the other not yet)
    The windshield frame
    And I don't know if it's really metal shaping, more like straigtening : the center grille
    Which is the only original brightwork I managed to save from the car, the rest was too far gone
    Edit I just found the picture of the car when I received it
  5. Okie Pete
    Okie Pete
    MP& C great idea using the lathe as a punch press . Everything is already lined up .
    whtbaron and MP&C like this.
  6. choptop40
    choptop40
    Old locker room doors...heavy gauge...5 3/4 inch veed in the centers... 0479E733-1F9F-4D76-8BEA-1BF873DB985F.jpeg
    alanp561, MP&C, whtbaron and 3 others like this.
  7. cornfieldcustoms
    cornfieldcustoms
    Just finished up this hand made aluminum 64 galaxie tear drop hood skin
    4AD20B56-E8E1-4D48-8A55-512266E3987D.jpeg 40EB524D-07C0-49BA-9FBC-155278DFEF2A.jpeg E9F86448-8D4E-4B31-A8ED-7EBF2052A718.jpeg EDFF108B-D539-4CA2-A23E-75D8BD4B2FC3.jpeg
  8. Tim
    Tim
    from KCMO
    That turned out killer!
  9. 123pugsy
    123pugsy
    Wow, that looks terrific.
  10. 1320 Fan
    1320 Fan
    BEAUTIFUL CRAFTMANSHIP!! - exceptional talent in this thread.
  11. rockable
    rockable
    Mike, you've outdone yourself this time. Amazing!
    When I think about those ****ty old fibergl*** versions that were pop riveted and bondo'd onto so many hoods back in the 60's and 70's, this just blows me away.
    Okie Pete and 123pugsy like this.
  12. Model A Mark
    Model A Mark
    from dallas
  13. CoolHand
    CoolHand
    Alliance Vendor
    VERY nicely done, sir.
  14. Okie Pete
    Okie Pete
  15. choptop40
    choptop40
    Ignition / headlight delete .. last pic Gauge panel and gauges.. 36F7F7DB-8372-446E-A360-4F1674930963.jpeg C19D7EA1-0525-480A-A87F-19FE7E1E4426.jpeg CF000F72-16A0-48C6-910B-163823AEFD67.jpeg 6F942D90-0932-43AA-9EE3-7DD15F55793B.jpeg
    Tim, CoolHand, MP&C and 6 others like this.
  16. cornfieldcustoms
    cornfieldcustoms
    Working on some early Mack truck fenders. Started by making a buck, they are so large I decided to do them in 1/4s instead of halves. Then started patterning and shaping IMG_0983.jpeg IMG_0984.jpeg CD8D13DB-58FC-4FAF-A0E4-B0162333B43E.jpeg IMG_1113.jpeg IMG_1114.jpeg IMG_1116.jpeg 71AB301A-AE33-4AE7-A68A-CADF6DD54436.jpeg IMG_1402.jpeg IMG_1403.jpeg IMG_1404.jpeg IMG_1405.jpeg
    Bugguts, Tim, Deutscher and 15 others like this.
  17. cornfieldcustoms
    cornfieldcustoms
  18. cornfieldcustoms
    cornfieldcustoms
  19. rockable
    rockable
    Great job as usual, Mike!
  20. 123pugsy
    123pugsy
    Friggen awesome job of it Mike.
  21. Okie Pete
    Okie Pete
    WOW amazing. The old Mack will look great .
  22. patsurf
    patsurf
  23. cornfieldcustoms
    cornfieldcustoms
    I dont use the wheel in shaping. Its all power hammer shaping, power hammer rough planishing , then finished on the air planisher
    Tim, MP&C, fauj and 1 other person like this.
  24. patsurf
    patsurf
    superior finishing!!!--thanks
  25. V8-m
    V8-m
    from Alaska
  26. GT40David
    GT40David
    2devilles, MP&C, hammer-time and 6 others like this.
  27. V8-m
    V8-m
    from Alaska
    All hande made parts for deck lid
    32 Roadster
    IMG-20231214-WA0003.jpeg IMG-20231214-WA0020.jpeg IMG-20231229-WA0007.jpeg IMG-20231230-WA0017.jpeg IMG-20240115-WA0012.jpeg
    IMG-20240104-WA0022.jpeg IMG-20221215-WA0028.jpeg IMG-20221216-WA0000.jpeg IMG-20221215-WA0033.jpeg IMG-20221215-WA0040.jpeg
    whtbaron, hotcoupe, brEad and 22 others like this.
  28. rockable
    rockable
    That is some very nice work! Thanks for sharing.
    V8-m likes this.
  29. rockable
    rockable
    I got tired of working on the 34 Ford and wanted to do some metal work. So, I dragged down this rust grill shell for my 37 Packard and went to work. I could have chosen an easier project but it turned out ok. There's a little fine tuning left to do but the hard part is behind me. :)
    Packard grill 1.jpg Packard grill 2.jpg Packard grill 3.jpg Packard grill 4.jpg
    tb33anda3rd, brEad, fauj and 17 others like this.
  30. The 39 guy
    The 39 guy
    The results of your work are awesome. Seeing how you accomplished these results is how we could learn from you. Is there any chance that you could show us your fabrication process on this thread or one of your own?
    hotcoupe and 123pugsy like this.
