Projects 1950 Chopped Chevy Sedan Delivery
Discussion in 'Traditional Customs' started by RMONTY, Jan 15, 2016.
  1. Nice!!!!
    RMONTY likes this.
  2. skyblue50
    skyblue50
  3. RMONTY
    RMONTY
    I think I have gathered several cars worth of parts since early 2016 lol
    poco, Okie Pete and brEad like this.
  4. RMONTY
    RMONTY
    Trying to get the stance right and I think we did. Trevor and Saul came over this morning and we installed a 2" lowering block kit on the rear. I'm a couple of weeks away from getting the green light from the foot surgeon but I am trying to do what I can to get closer to making some extended shake down runs. 20240526_144023.jpg 20240818_114034.jpg
  5. atch
    atch
    Stance is MUCH better now.
    brEad, guthriesmith and RMONTY like this.
  6. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Yep, what Mike said. Looks way better Robin! :cool:
    RMONTY likes this.
  7. Lone Star Mopar
    Lone Star Mopar
    Looks good man ! Shoot me a message, broke my phone & lost your # with it.
    chryslerfan55, Outback and RMONTY like this.
  8. Looks great Robin!! Lead Ain't Dead in a few weeks?
    guthriesmith, RMONTY and Okie Pete like this.
  9. RMONTY
    RMONTY
    I'm not going to make it this year. Work stuff has me tied up with a bunch of projects but shooting for the 500 in the spring for sure. Hopefully will make the drive in this old heap!
    poco, chryslerfan55, brEad and 3 others like this.
  10. poco
    poco
    from oklahoma
    Looking good Robin
    RMONTY and guthriesmith like this.
  11. You will be missed!!
  12. RMONTY
    RMONTY
    Well it's been a little while since I have been able to work on the car due to some health issues. Hopefully those are coming to an end and I can get back out in the shop.
    I need to do some patching on the inner fender on the passenger side beneath where the battery sits. Then get the front sheet metal all back together and the a/c condenser mounted.
  13. Baumi
    Baumi
    I know I´m late to the party to tell you you´ve done a great job saving this( these) sedan deliver(y)ies. I´m sure most would have thrown in the towel. I would have. Congrats and have fun!
    brEad, Outback, Dick Stevens and 2 others like this.
  14. Man Robin! I hope all is ok and you will be good enough to be back out in the shop soon!
    chryslerfan55 and Outback like this.
  15. Outback
    Outback
    from NE Vic
    Was thinking of you & this thread @RMONTY good to see an update
    Squablow likes this.
  16. hillbillyrabbit
    hillbillyrabbit
    I hope all is ok with you, Robin.
    Its been a bit, since we talked.
  17. RMONTY
    RMONTY
    Hey Rabbit....PM sent......
    So I have a tire question, and maybe I should start a new thread on it, but I will throw it in here and see how it shakes out....
    Question is......I currently have 205/75R15s on my car. I am going to be aquiring a set of wide whites to set this car on. I want to fill up the rear fender wells as much as possible without taking the chance of rubbing and digging into the tires. I also want something a bit wider.
    The question is, what would be the best size tire to accomplish this, and also something a bit wider than what is on there now. The wheels I will be using are pretty much stock wheels. I Don't know the backspacing and/or width of the wheels at this point.
    Any input would be great! Thanks in advance!
  18. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Robin, do you have room both sides of the tire now? I assume you are wanting taller and wider? Or, just wider?
    Also, sounds like you will be changing wheels too?
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    Look under the car to measure much room you have, both fender lip and inner fender or spring clearance.
    You could go on a major tire web site to compare tire size charts; the sectional width dimension is most likely what will decide how big you can make fit. ;)
    alanp561 likes this.
  20. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Also, are you considering putting skirts on it?
    Okie Pete likes this.
  21. RMONTY
    RMONTY
    No skirts....
    B Bay Barn likes this.
  22. RMONTY
    RMONTY
    Yes but just using steel wheels...nothing special on the wheels that i can see. I want something wider, but not sure how much taller i want to go if any, or if i have to. We installed some lowering blocks a few months ago on the rear.
    Okie Pete and alanp561 like this.
  23. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    The tires you have on it are basically 8” wide and 27” tall. I’m thinking the height seems about right and betting that you can’t get much more than a 9” tire under there. A 235/70/15 would get you a 9.25” wide tire that is 28” tall. That could maybe work?
  24. RMONTY
    RMONTY
    THAT is exactly what I was thinking, not knowing much about all this.....
    @trevorsworth I think we had it spot on earlier today.
    trevorsworth and guthriesmith like this.
  25. RMONTY
    RMONTY
    Thanks as always for your input Jeff.
    @Lone Star Mopar brought me some A fenders, front and rear, and a sandblast cabinet free gratis, and I hooked him up with some 235/261 motor mounts, sort of. These came from Buffalo Engineering that I bought years ago. I can't recall what I did with the rudimentary instruction sheet so it's a bit of a puzzle, but hopefully it has what he needs to get some motor mounts engineered. Right now it's a box full of pieces of plate steel drilled and shaped wanting to be motor mounts.
    Maybe those fenders can go on one of Trevor's projects. I'm sure we can work out some kind of deal! :cool::p:rolleyes:
  26. Lone Star Mopar
    Lone Star Mopar
    Thanks for the mounts bud. Don't forget to charge extra for all the brass brazed on those fenders !
    brEad and RMONTY like this.
  27. 1-SHOT
    1-SHOT
    from Denton
    Body filler does not adhere to brass very good. It tends to bubble over time. If you do be sure to get all the flux off and abrade it well. The voice of experience
  28. RMONTY
    RMONTY
    No brass on this car. We were talking about some Model A stuff but thanks for the heads up!
  29. 1-SHOT
    1-SHOT
    from Denton
    I walked into a body shop in 55 when I was 13 to get my mother ironing board fixed and never left still fool with old cars. Frank IMG_1574.jpeg IMG_1630.jpeg IMG_1636.jpeg
    Okie Pete, 40two, Outback and 4 others like this.
  30. 1-SHOT
    1-SHOT
    from Denton
    IMG_8158.jpeg IMG_8157.jpeg Two insulated drink holder end to end with a large hole in one for the neck of the bottle. Keeps beverages colder a LOT longer
