Projects A late introduction-Junior Conway coupe build
Discussion in 'Traditional Customs' started by jivin jer, Oct 10, 2009.
  1. I'm not too sure about that. I want to lower my 50 at least 3 inches. Not sure how it's lowered at the moment. No blocks under it. I think only the shackles have been altered. Mine rubs the tunnel as it is.
    Although mine has a transmission swap, that may have effected it as well.
    I have plenty of room before a C-notch is required.
    chryslerfan55 and Rand Man like this.
  2. jivin jer
    jivin jer
    I forgot to include, unless you have a "businessman's" coupe without the back seat, you're going to have to modify the seat frame to accept the now higher drive shaft tunnel. So, it took determination to continue to forge ahead and not be overwhelmed with all this Kustom stuff.
    You get to have something that I never had, a choice.
  3. jivin jer
    jivin jer
    By the way I had to make my own lowering blocks because I couldn't find 5" blocks. This is along with de-arched springs. It was amazing to see how far "up there" the tires were.
  4. jivin jer
    jivin jer
    This picture has only been available lately. If it had been available "back, then" this argument wouldn't have had any fuel to keep going.
  5. jivin jer
    jivin jer
    It's comments like this that reveal the p***ion and power that's involved with this custom stuff, no matter which end of it you are on. It's what captured me in my teens, and (thankfully) I've never recovered.
  6. jivin jer
    jivin jer
    OK, the "estate sale" is over. I went over yesterday, and there wasn't anyone there, and the house is locked up. They have my key. I was able to unlock the shop, and everything is still there. IMG_0148.jpg
  7. drdave
    drdave
    A lot of cool in that pic right there. Hope the sale went well and as you expected/hoped Jerry!
    Outback likes this.
  8. Outback
    Outback
    from NE Vic, Oz
    So good to see this pop up again, it must be a strange feeling moving all those treasures on & onto the next chapter.
    chryslerfan55, Okie Pete and drdave like this.
  9. This literally just scrolled across my FB feed lol FB_IMG_1723510171721.jpg
  10. jivin jer
    jivin jer
    Junior told me that he didn't have the money to paint his car at this time with lacquer. This is a picture of the car in old line enamel. You had to be there to understand what a nightmare it was to reshoot the finished "tear drop" coupe in lacquer.
  11. Still it's cool that it was a good looking car along the way and not just in the final iteration. :)
    Outback and chryslerfan55 like this.
  12. jivin jer
    jivin jer
    I need to mention here that I've never shot (painted) a vehicle in a modern booth. Most of my experience was with Deltron, and I learned to put the first coat of clear on really quick and close to the surface. I would let that first coat get really tacky, and then flood the surface with a heavy clear coat very close to the surface, and moving very quickly, and evenly. After this I would wait even longer and then put a third coat on that second coat, being (now) very careful to not overlap/overload this now semi fragile, super thick ac***ulation of material just teetering on the cusp of collapsing. This would produce a very shiny and deep flat surface (like gl***) that needed no buffing other than the nibbing of the few specks of dirt that might be there.
    My paint jobs put me on the map in my area during this time.
  13. jivin jer
    jivin jer
    I have amended this last paint process description. Due to a rethink on that process.
    Outback and AChopped1950ford like this.
  14. jivin jer
    jivin jer
    Here's George demonstrating what was common in the day for spraying cars, very much like my situation. IMG_0169.jpg
  15. jivin jer
    jivin jer
    Being a teenager in the fifties, and being exposed to all the creativity around cars, I was totally distracted by Juniors 50' Ford coupe. It had "that look" that you get when you carefully think through, step by step as you go every new component that is added to what you started with. He mentioned that the main theme he was going for with his (one and only) creation was characterized by one word, modern, it had to be modern. He had the opportunity to put a nice '54 Pontiac grille in it from another custom that would have been "nice", but he caught himself and said "no", that wont do. The end result was the first (or second) straight bar grille.
    When I found out that he was just five years older than I was, I was totally gob smacked. So as I've thought about this post, I've come to realize that Junior was probably my first hero in my life, and as I've said many times before, to have had the privilege to recreate his car, with his input all along the way is the kind of experience that molds, shapes, and changes you. So much, that I had to do another car from "the dream factory".
    I want to include in this post my favorite picture of Junior. It captures the power that he was exposed to at Barris Kustom, and his reaction to it. He's not the only one that this has happened to but the fact that he had no control over this moment speaks volumes to me.
  16. jivin jer
    jivin jer
    Dan was responsib IMG_0178.jpg IMG_0179 (1).jpg le for the body (straightness), and the paint.
    Okie Pete, drdave, loudbang and 6 others like this.
  17. Came across this in a flea market today. Had to grab it. Sadly nothing inside of the car IMG_20240915_230240004.jpg
  18. jivin jer
    jivin jer
    I actually remember this mag. I didn't think that Motor Trend measured up to the "real" custom car mags like rod&custom, Custom Cars etc. I'm thinking that there were a few more that I'm missing. The fact that Junior's car was on the cover, but wasn't inside kinda got my attention.
    Outback, loudbang and The Chevy Pope like this.
  19. Yeah I initially p***ed over it two weeks ago at the same flea market. Grabbed it and a similar mag(forget ***le) after realizing despite ***le they were basically rod mags. Two weeks ago I bought two late 50s hrms from the same booth. All of the mags were 57-61
    drdave likes this.
  20. jivin jer
    jivin jer
    I always liked this pic, and I was seriously considering having it for my avatar at one time IMG_0175.jpg . It never happened.
  21. jivin jer
    jivin jer
    We're getting the trailer checked out after sitting for quite a while. Lites, brakes, new tires, and it just so happens that the display has been secured inside since hauling all over Texas, Oklahoma in 2011.
  22. jivin jer
    jivin jer
    A little peak at what can happen when you push off from the shore on your life adventure.
  23. Outback
    Outback
    from NE Vic, Oz
    Thanks so much for sharing all these thoughts & your journey. I appreciate your honesty through it all.
  24. mikhett
    mikhett
    from jackson nj
    Love the car,JER!
  25. jivin jer
    jivin jer
    I don't know how to do it any other way.
    drdave and AChopped1950ford like this.
  26. jivin jer
    jivin jer
  27. Id totally wanna do a photoshoot with that car with that barris 53 olds foose has been refreshing. Those too cars would look good by each other in color
  28. jivin jer
    jivin jer
    That Olds is a candy color, different than this color.
  29. Oh I wasn't saying they looked the same. Just that they'd "accent" each other nicely lol
  30. jivin jer
    jivin jer
    I agree with you.
    The Chevy Pope likes this.
