  1. ALLDONE
    ALLDONE
    thanks a million.... thats real close, but drop the cab to the top bead roll, stretch it 4/5''might even stretch the WB to match, add some small west coast mirrors and call it done...
    Stan Back likes this.
  2. Rot 'n Kustom
    Rot 'n Kustom
    OK. Body dropped, cowl same height as before.
    2FORCEFULL and hotrodjack33 like this.
  3. ALLDONE
    ALLDONE
    hell yeah!!! thanks a million... now I just have to get after it...
    Rot 'n Kustom likes this.
  4. Rand Man
    Rand Man
    Hey, I will be building a sectioned, 1950 Ford coupe. Here’s an example. I want to add bubble skirts and, rather than the Buick side trim. I want to try 57 Chevy Belair bottom side trim to see if that works. Along the bottom, inside that curve and probably on the bubble skirts, I want to try the green color. The rest of the car, I want the sunset orange pearl metallic like I show here. If there’s anyway to make the highlights stand out as gold like the picture of this off-topic car door that would be great. I will probably add lots of clear with a heavy gold flake over both of these colors that affect probably not possible in Photoshop I don’t know
  5. Rot 'n Kustom
    Rot 'n Kustom
    How's this?
    Squablow, Sancho, themoose and 3 others like this.
  6. Rand Man
    Rand Man
    I love it, But there’s more Green than I expected. The Chevy trim would start just in front of the bubble skirt at the rear wheel well and come up to the top of the front wheel well
  7. Rand Man
    Rand Man
    Bubble skirt examples. I will look for a better angle shot.
    Squablow likes this.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I really like the way Rot n Kustom's Pshop came out. I think his take on having the '57 Chevy trim go all the way to the back is correct. Maybe just have the bubble skirts gold.
    The green may be a shade or two too dark.
    Rand Man likes this.
  9. Rand Man
    Rand Man
    It is really great. I just wanted to try it down a little lower right in front of the skirt. My mark on the screen cap is not perfect. Should go closer to the skirt. IMG_7204.jpeg
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  11. Rot 'n Kustom
    Rot 'n Kustom
    I thought so, too much green. I'll give it another go and try out this idea and a few more I have. May take a few days.
  12. Rand Man
    Rand Man
    IMG_7209.jpeg Yeah, you totally take as much time as you want. It’s in the ideas stage right now, no rush thanks.
    I’m taking some inspiration from this coupe. It might be best just to have the bubble skirts, the green, a little lighter shade than what I showed. These big bubble skirts will look huge on a sectioned car, and the proportion of the two tone would probably look best just in this lower quarter area. Might not run any stainless trim on the side
  13. @Rand Man
    Here's another version to take a look at...
    Sancho, Rand Man, Unclebrad and 2 others like this.
  14. Unclebrad
    Unclebrad
    Well, since everyone else is jumping in, here's yet another idea...
  15. Rand Man
    Rand Man
    Yeah, that fade has potential thanks.
  16. Gambler 1962
    Gambler 1962
    20240428_180803.jpg Wonder how my Falcon would look with wide white wall tires, and painted Maroon with white top.
  18. Jim Bouchard
    Jim Bouchard
    ^^^^^Lower it and you have a real winner right there
    Gambler 1962 likes this.
  20. Rot 'n Kustom
    Rot 'n Kustom
    Funny! I was going to suggest the Lee Pratt shoebox for balance of color and you beat me to it.
    As for the skirts. In the old days, the bubble skirts could be cut from a VW Bug roof, split in half lengthwise and the compound curves cut however you liked. But the more I looked, the more I think the stock skirts work better in a sectioned taildragger. Anyway, here are two ideas. An update on the '57 Belair long trim, and and, well judge for yourself!
    1949 Section Coupe Take 3 Green Stripe Final.jpg 1949 Section Coupe Woodie Final.jpg
  21. Jim Bouchard
    Jim Bouchard
    WINNER!!!! That looks GOOOOOD!!!
  22. Rot 'n Kustom
    Rot 'n Kustom
    @Rand Man
    OK, I'm done. Just in case you have that extra '57 Belair top piece.
  23. Rand Man
    Rand Man
    Thank you very much I like that upside down and backwards Chevy trim. I didn’t mention it, but I can’t have anything above the rear wheel wheel no matter what skirt I use. It’s hard to describe, but I plan larger oval tail light lenses. Do you know how a 51 Ford has that trim that exaggerates the “wings” on the quarter panel? I will exaggerate them more.
  24. Can someone add this hood side to my car one in silver and one in the same green? I marked the rough placement with the red lines. The exhaust will be on the outside of the hood side. Sorry the hood side photo isn't perfectly square. I will have to shorten the height of the hood sides by 2" so I may take that off on the top to help make the louvers clear the exhaust cut out.
    Thanks!!!
  25. Gambler 1962
    Gambler 1962
    Wonder how this would look black with white walls skirts and lowered 20220123_123800.jpg
  26. Unclebrad
    Unclebrad
  27. Rot 'n Kustom
    Rot 'n Kustom
