Hot Rods How much power can a banjo rear take?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Jul 7, 2024.
  1. hotrodA
    hotrodA
    When I built my roadster back in 70’s I did what @willys36 showed above. Thanks for the pics!
    I used two 28 spline short side axles from two 69 Cougars.
    Ground the axle gears as shown, and used NOS earlyFord spider gears and cross.
    Machined out the carrier and ring gear as shown.
    Set up the tubes with the later bearing cups, used the 28 spline axle with bearing and the ring gear as a fixture to locate the ends for welding. The inner end of each axle was trimmed off 1/4”.
    My center election was a 201 Halibrand but the guts were as shown above.
    Still running behind a mild 350 SBC.
  2. lumpy 63
    lumpy 63
    It's kinda like the age old question .... Hey wise old owl.... How many licks to the center of a Tootsie pop?
  3. willys36
    willys36
    I considered welding on modern bearing bosses but decided to modify the early Ford so I could keep the old Ford backing plates to honor the original Mysterion.
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That's the easy way out. If it's not hard, it's not right!
  5. Weedburner
    Weedburner
    from Wa State
    You generally locate the cylinder somewhere on the pedal or linkage system that will give you about 3"-4" of cylinder stroke distance. Gives you the ability to adjust how fast the clutch can draw inertia out of the engine's rotating ***y. Inertia energy discharge rate is typically what breaks drivetrain parts, not actual engine torque.
    Grant
