Technical Hurst Competition Plus Shifter # 587501 and #2083 Identification
Discussion in 'The Hokey Ass Message Board' started by bustingear, Jul 14, 2024.
  1. bustingear
    bustingear
    Hurst Compe***ion Plus Shifter # 587501 and #2083 Identification , Can anyone help me ID the application for this shifter? i am been pounding around and cant seem to come up with anything.. Numbers on the brackets mounting to the transmission are 2442 & 2440 & 1052441. Mounting plate is 5257
  2. jimmy six
    jimmy six
    Older for sure attaches to the case at the tailshaft housing. Might be for a 62-up Ford…
  3. 1935ply
    1935ply
    from peyton,co
    The 2083 # is the case part #. The application numbers are 7 number's, starting with 391. Try to find those numbers and go to shifterdoc.com. I just went thru this recently and was able to Identify mine. The levers are the stud and nut style, pre '68.
  4. bustingear
    bustingear
    Where are the 7 numbers located?
  5. That patent # was issued 11-9-65.
  6. bustingear
    bustingear
    so far im getting early 60's aftermarket and the numbering system changed on the later shifters. Still looking for application ID???
  7. 1935ply
    1935ply
    from peyton,co
    So, making my memory go back a few months- The 2083 is the basic comp plus shifter with the stop adjuster bolts. The mount has the part numbers for the specific trans mounting and car application. If its a hurst mount it should have a part number. It would definitely be for a trans with no mounting holes on the tailshaft.
  8. bustingear
    bustingear
  9. 1935ply
    1935ply
    from peyton,co
    Best guess would be a toploader ford. The rods and levers are close together like the old ford. Weird mount, really far forward. maybe someone made it for a custom application?
    jimmy six likes this.
  10. bustingear
    bustingear
    Mounting plate is #5257 anyone else have an idea?
  11. deucemac
    deucemac
    There SHOULD be a number on the shifter housing between upper mount bolt hole and the lower mount bolt hole. That number should tell you the application of the shifter. It is at least 4 digits lon if you can't decode it, I have an old 1995 Hurst and can possibly decode it for you.
  12. bustingear
    bustingear
    # 587501 and #2083 are the numbers on the shifter housing
  13. bustingear
    bustingear
  14. In_The_Pink
    In_The_Pink
  15. Fordors
    Fordors
    Let’s try some basics and see if this will help. No picture but the C-C dimension of the tail shaft bolts is 4”, there are a number of different Saginaw 4-spd tail shaft housings but the one I have here does not have any tapped holes on the side so no dimension for that rearward facing brace.
    C-C of the forward gear levers is 3 11/16” and from the first/second to the reverse lever is 1 3/16”. Try to lay out the levers and see if these numbers match.
    I never had a Ford top loader but maybe someone can help with those dimensions.
  16. Flatrod17
    Flatrod17
    The shifter, rods and levers look early top loader Falcon (could be T10) to me, but I don't recognize the mounting parts at all.
  17. bustingear
    bustingear
  18. Flatrod17
    Flatrod17
    Its not Falcon T10, I dug mine out, it looks like the same shifter but the rods and arms are different. Still could be top loader. My top loader mounting bracket looks nothing like what you have though.
  19. bustingear
    bustingear
  20. Fordors
    Fordors
    Have you tried lining up the linkage and measuring it? Put a 1/4” rod, or even a drill bit in the shifter to set the levers at neutral and post what you find, you might get an answer that way. Part numbers aren’t helping, maybe measurements will.
