Hot Rods The Belly Button Bucket Build Thread
Discussion in 'The Hokey Ass Message Board' started by Tim_with_a_T, Dec 2, 2015.
  1. RodStRace
    RodStRace
    Funny, I was thinking he needed a pool light out of the bottom of the door that had his face shining on the ground!:D
    Tim, that's coming out beautifully. Again, working until it's as you planned.
    I liked Amon more, but neither is going into rotation, at least until I try to wood mine like yours.
    As you said, different generation. I've got a room of LPs and CDs.
    porkshop and Tim_with_a_T like this.
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    So, Tim;
    Since you've now got both doors operable, that means that you ended up w/a rare *Canadian* 'gl*** T-bucket... ? :D .
    Marcus...
    porkshop, brEad, AndersF and 2 others like this.
  3. Dave G in Gansevoort
    from Upstate NY
    And weren't they for export to South America?
    Outback and Tim_with_a_T like this.
  4. Tim_with_a_T
    Tim_with_a_T
    Got both doors fitting really nice, but for some reason my striker pins on both sides need to be lower to work smoothly. I’ll take a look at that early this week. Overall a pretty productive weekend!
    Outback, Bandit Billy, OFT and 10 others like this.
  5. RodStRace
    RodStRace
    Don't let any of those loco skateboarders shoot the gap through your car!
    brEad, Tim_with_a_T and porkshop like this.
  6. Tim_with_a_T
    Tim_with_a_T
    Update time. Been fiddling around with some bits and pieces not worthy of pictures yet, but I did manage to get the cowl nice and braced up by making some diagonal braces from door hinge pillar to firewall. You’d be surprised how much more solid the car feels with those little pieces glued in. The lower ones will serve as mounting locations for the toe boards, when I get that far. Lots to do still!
    OFT, brEad, Tim and 7 others like this.
  7. Dave G in Gansevoort
    from Upstate NY
    I know it's overkill, but it saved me from having to learn: a-woodworking, b-fibergl***ing, and c-how to get that stuff off of my hands, tools, floor, workbench, etc.
    DSCN1441.JPG The firewall is sandwiched between 2---1/4 inch thick aluminum tooling plates, and supported by the 1 inch tubing bracing. And I plaigerized Marty's floor flange concept to bolt the bottom of the body to. There's no flex in any of the body. And yes, I am an engineer who overthinks everything! And I make myself more work because of it!
    OFT, brEad, AndersF and 3 others like this.
  8. Tim_with_a_T
    Tim_with_a_T
    Time for a text update, mainly to motivate myself to get moving again, partially to update you guys as I was reading the "build thread etiquette" thread, and that seemed to be a common request/complaint. Last weekend, I spent some time fumbling about, working to get the door latch/striker pin ***embly more compact. It's a balancing act as each piece of the ***embly needs to be in a specific location, and held to a pretty tight tolerance, to accomplish what I'm hoping to achieve. I ended up re-making the striker pin bracket on the p***enger side 4x.... finally got to where I was happy with that. So far I'm on the second p***enger side door latch bracket, and I'll likely need to move onto the third as it's not quite what it needs to be. I'll post an update, with progress pictures and thought process, once there's something to show off.
    Last week I had my coin purse sliced open so the ol' water cannon can't deploy any more swimmers, and I only took a few hours off work cause I'm gonna be on sabbatical for the next month, and I got *lots* to do before I'm off work (approaching the 48hr countdown, so the finish line is in sight). What does this have to do with hot rods, you may ask? Well, my goal for this particular sabbatical is to get the car on the road, in an unfinished state. Even at that, there is so much to do it's disgusting. I don't want to half-*** it and end up re-doing it later, so I guess time will tell if I pull it off or not.
    At the very least, I'm hoping to provide daily updates of progress. I've had one other sabbatical in my time, and of the 40 days off, I spent 39 of them 10-12hr days putting in pavers/retaining walls/digging in the yard, running power to the garage for a sub-panel, etc. I can only hope this time around is as productive. In those days I was fueled by energy drinks and heavy metal music, but this time around caffeine has been left behind. I will need to be very strategic with my playlist, diet, and tasks at hand to stay motivated and focused. As we are all aware, life gets in the way of building hot rods. And that's ok. But this is my chance to regain some of that ground I've lost. Fingers crossed.
    @Bandit Billy posted this picture of a bucket entering the Good Guys show up in Puyallup last weekend, and it really got me fired up. The dual quad small block, the 5 spokes, the cute p***enger… this speaks to me. “Tim, time to get the car on the road. You’re missing out!”
    BigJoeArt, mad mikey, OFT and 6 others like this.
  9. Bandit Billy
    Bandit Billy
    Eradicating those free swimmers is a step toward having more car time and money. The world needs more nice, traditional T buckets. There were only a few at the Good Guys show up North.
    I'm heading over to Beaches in a bit. I'll see if there are any about and report back with more inspiration.
    brEad, Tim and Tim_with_a_T like this.
  10. Tim_with_a_T
    Tim_with_a_T
    Appreciate the reconnaissance! I've got an evening meeting where I'm hoping to close out the remainder of my deliverables before I'm out. Perfect day to go to Beaches, too... not too hot, not a cloud in the sky.... Sigh... Focus, Tim! Focus!
  11. RodStRace
    RodStRace
    Tim I dig all of your updates, but life first! Rather than try to make each part perfect first time, try to fail fast, as Adam Savage says. You've already proven to be a 'do it until it's right' person, so just be mindful of changes being easy to be improved upon.
    Having it go around the block is going to add new and different things to the list, so I wish you the best.
    I found a dead pedal on the left helped. Easier now than after upholstery.
  12. Dave G in Gansevoort
    from Upstate NY
    And remember Tim, "Better is the enemy of good enough! " Learned that at the research firm 39 years ago. And I have to fight the urge every time I'm making something...
    brEad and Tim_with_a_T like this.
  13. Tim
    Tim
    from KCMO
    Also sit on some ice
  14. DDDenny
    Daddy, what's a "free swimmer"?
  15. RodStRace
    RodStRace
    @DDDenny this is the internet. If you can't find the answer in 5 minutes, ask your mommy.
  16. RodStRace
    RodStRace
    @Tim_with_a_T is there any weatherstrip planned? I could see a bit of rubber causing the striker to change yet again if it is installed. Heck, ask pro painters about how they still have to refit a little after the final coat and cut and buff. Parking in the sun after a bumpy road could change it a bit, although your bracing looks to be more than enough to keep that at bay.
  17. Tim_with_a_T
    Tim_with_a_T
    You're in my brain. I'll explain my approach to this when I post about the latch, striker pin, door gap, door panel, and all the other variables in this area. Lots to consider for sure.
    Tim and brEad like this.
  18. RodStRace
    RodStRace
    I said all that to say, don't sweat it until it's in it's final form. Otherwise, you will adjust it 14 times and still have to do it once more...:p
    So long as there is a little adjustment, move on!:D
    Tim_with_a_T likes this.
  19. Tim_with_a_T
    Tim_with_a_T
    There's still a lot to consider. Finished thickness of each part, and final ***embly considerations are important things to at least guess at this stage. The door latch and striker are relatively unaffected, but how it all goes together as an ***embly is a different story. Like how is the door panel going to mount, how does the interior handle work, how much thickness will x and y add, etc. I've spent enough time thinking about it, I have a vague idea of how to move forward.
  20. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day one.
    brEad, porkshop, lurker mick and 5 others like this.
  21. Tim
    Tim
    from KCMO
    Dig the video update!
    Tim_with_a_T and OFT like this.
  22. Dave G in Gansevoort
    from Upstate NY
    Nice! Also, more videos please!
  23. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day two. Hit a lot of dead ends today. I’m juggling a few other projects as well, one of which is the daily decided to blow a head gasket Thursday night. Oh the joy. Spent about an hour yesterday and a couple hours today starting the tear-down. Hopefully tomorrow is more productive, on all fronts.
    brEad, porkshop, pcbart and 2 others like this.
  24. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day three.
    Outback, pcbart, High test 63 and 9 others like this.
  25. brEad
    brEad
    That works great now! Persistence pays off.
  26. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day four.
    Outback, OFT, lurker mick and 6 others like this.
  27. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day five.
    I had to run some errands today and roll around under the daily for awhile, but I managed to get a few things done. I had a goal of getting all the driver’s side brackets and linkage cut out- I got close but I’ll have to pick it up again tomorrow.
    OFT, brEad, lurker mick and 7 others like this.
  28. Tim_with_a_T
    Tim_with_a_T
    Sabbatical, Day six.
    Today was a m***ive struggle. I successfully completed nothing from my morning list. I did make progress, but slow. I’m about 3ish hours away from having the driver’s door caught up with the p***enger’s. I’ll hit it hard again tomorrow.
    BigJoeArt, Outback, brEad and 8 others like this.
  29. AndersF
    AndersF
    We all have theese days when things dont go as planned.
    But the last weeks of progress have been really impressing.
  30. Dave G in Gansevoort
    from Upstate NY
    Keep after it Tim. I'm counting on you so I can plaigerize your ideas! ***uming that I get brave enough to cut my body...
