Hot Rods Strange glass bottle on firewall
Discussion in 'The Hokey Ass Message Board' started by hobag65, Jul 15, 2024.
  1. hobag65
    hobag65
    I just picked up a 31 A for my grandson and to work on, can anyone tell me what this thing is and what it is for?
    gary macdonald likes this.
  2. Tim
    Tim
    from KCMO
    Typically when I see a firewall or inner fender mounted jar that isn’t a windshield sprayer it turns a out to be… well I don’t really know what they are called lol, guys basically put marvel mystery oil in them and it syphons into the carb.
    seems a little jc Whitney do dad to me but the oil does work so hey why not.
    The photos are a little hard for me to see but it does look like it has a line to the carb and it’s above where the stock fuel filter is so I don’t think it would be a good position for a non stick fuel filter
    Be curious to find out what it is as well
    If it wasn’t gl*** I would
    Guess it’s an auto pulse fuel pump
    lothiandon1940 and Tow Truck Tom like this.
  3. Bandit Billy
    Bandit Billy
    Pre-oiler?
    firstinsteele and Tow Truck Tom like this.
  4. patsurf
    patsurf
    top oiler?
  5. Tim
    Tim
    from KCMO
    One a buddy ran for a while on his car.
    I still think it looks like a fuel pump but I can’t find anything that looks like that and has a gl*** bowl IMG_5181.jpeg IMG_5182.jpeg
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I've mentioned this many times, but just keep thinking back to when.
    When my head could just see the counters in the gas stations, flat heads were prevalent.
    Father, Uncle, and Stepdad, all were involved, one way or the other, with gas stations.
    Learning to read, I asked what is valvetop oil?
    Years later I understood how the flathead does not get its valves bathed in oil, as do OHVs
    But rather, just bathed in fire.
  7. 1952henry
    1952henry
    Does it have a gl*** dome at the top with a curved br*** tube inside? Is the gl*** held in place with a couple J bolts? Curious as I have two top oilers like that. Hard to tell from pics.
    lothiandon1940 likes this.
  8. Oneball
    Oneball
    What 1952Henry says
  9. Acres
    Acres
    from Sweden
  10. lothiandon1940
    lothiandon1940
  11. lothiandon1940
    lothiandon1940
    bigger picture. always hit that "full image" ****on to avoid thumbnails.
  12. Used to add lead replacement goop while the engine is running. If it has a sightgl*** after the needle valve, 1 drop every 30 seconds at idle. Diesel works fine in these.
    hobag65 and bobss396 like this.
  13. 1952henry
    1952henry
    IMG_0958.jpeg Does it look like these? Best I can discern, these are from early 30s.
    winduptoy and Tim like this.
  14. hobag65
    hobag65
    Yes sir, the one on the left, this 31 was parked in an agricultural building since 52 so surprising they were adding this stuff on in the 50’s?
  15. 1952henry
    1952henry
    I have a small collection of these. A few NOS. The literature of one has the newest cat application as a 54. Another, newest car as 33or 34. Gl*** on that one has turned purple. An Allstate NoS ki has literature dated 52. I believe various makes /designs go back to the 30s from what I’ve seen
  16. hobag65
    hobag65
    The coupe was originally sold in California and brought to northern Utah in the late 30’s. The farmer I bought it from said it was always there, so the purpose is to keep the valves lubed? I want to just drive it all original so I will probably just plug the ports internally so she’s stays the way it came out of the barn.
    firstinsteele likes this.
  17. 1952henry
    1952henry
    Mainly for valves. I have a NOS Ampco vacuum plate for my flathead V8 carb. It has the tubing and fittings so it would draw through that. Heck, fill it with MMO, after a cleaning, and let your banger munch on that.
    hobag65 likes this.
  18. DDDenny
    Snake oil dispenser.
