Technical Need a new distributor
Discussion in 'Traditional Hot Rods' started by LuckyOC, Jul 15, 2024.
  1. LuckyOC
    LuckyOC
    Hey everyone, I’m new to the forum but a long time car guy. I just made a deal on a 1930 Model A that’s running a 283 SBC w/dual 4 barrels. It has one of the Joe Hunt wannabe magnetos on it. What I’ve read on here is that most experiences with them are negative. I’m also having a hard time getting it to run worth a damn and have opted to pull it out. What are your recommendations for a good small bodied distributor to run without an ignition box?
    Thanks!
    Mike
    Tim likes this.
  2. Dave G in Gansevoort
    from Upstate NY
    Find a good mid 60s Chevy dual point distributor and have someone with a distributor machine set it up for you. We used them in the 70s with the sportsman cl*** cars and they were good to more rpm than you are likely to turn that engine.
    And parts are still available in most parts stores, so if necessary you can get back on the road in pretty much the middle of nowhere...
    427 sleeper and LuckyOC like this.
  3. 67drake
    67drake
    from Muscoda WI
    Well, for a street engine I would want vacuum advance. Everyone has their opinion, and you’ll get many, but I’m still a fan of old fashioned points and condenser. Simple, and have never left me high and dry.
    If you’re going to spin your engine high, don’t run stock points, Accel make higher oz rated points. I could spin the 400 in my off topic car to 6000 without bounce.
    Me personally, factory distributor with breaker points with a dialed in mechanical curve and vacuum advance and your set.
  4. Bandit Billy
    Bandit Billy
    I have no idea of what is best, but I am sure many on here do :cool:, and they should be along to share their knowledge or at least an opinion or three. I can tell you I have 4 vehicles (Flathead, HEMI, 455 and an air-cooled VW) all running MSD distributors at the moment, and I have had zero issues with them. The one of the 455 has been there for 20 years and has not missed a beat.
    LuckyOC likes this.
  5. 38Chevy454
    38Chevy454
    Agree that vacuum advance is a good thing for street engine. I use manifold vacuum on my stuff.
    As for what distributor, a smaller cap is needed for your clearance and looks. No HEI with the big diam and coil in the cap. The dual point is a good choice, but you can get by fine with single point. Many like electronic conversions instead of points. The beauty of points is you can fix on side of the road easily.
  6. LuckyOC
    LuckyOC
    Thanks! Appreciate the advice.
  7. LuckyOC
    LuckyOC
    I’m a big fan of MSD too. Thinking a RTR and simple coil maybe the way to go.
  8. LuckyOC
    LuckyOC
    HEI is definitely a no go in this car. I have about 5” from distributor centerline and 9” vertical. Thinking an MSD RTR or Mallory unilite. Not sure I’d go the points route.
    gimpyshotrods likes this.
  9. tubman
    tubman
    If it's the car in your avatar, I'd run an old "flattop" Mallory and a "Best" coil.
  10. LuckyOC
    LuckyOC
    Yes it’s the car in my avatar. Is that an old dual point dizzy you’re referring to? What about a new Mallory unilite?
  11. tubman
    tubman
    I think the distributor should fit the period of the car. It's pretty small, but your avatar looks like an older style rod (mainly the 283, dual quads, "wide whites"). As such, it deserves an old style distributor, and a Mallory "flattop" sure fits that description. They are still not that hard to find or an SBC and surprisingly, parts aren't that bad. They also work very well; I have them on flatheads, a couple of early hemi's, and an Olds "Rocket". A Mallory ""The BEST Coil I Ever Made" rounds out the "look". A "Unilite" isn't even close in style, plus, I've heard they can be unreliable.
    After all, this is a "Traditional Hot Rod Forum".
  12. sdluck
    sdluck
    Dave small-body HEI
  13. LuckyOC
    LuckyOC
    Thanks for the info!
  14. LuckyOC likes this.
  15. saltflats
    saltflats
    from Missouri
    I would find and older cast iron GM distributor. If you go with a Mallory you may not find parts as easy if you have a problem. And I have heard of people having problems with the ready to run MSD units.
    LuckyOC and lumpy 63 like this.
  16. lumpy 63
    lumpy 63
    I have an Nos 57 - 62 dual point distributor if your interested
  17. tubman
    tubman
    This would be a good choice.
  18. lumpy 63
    lumpy 63
    20240715_194856.jpg 20240715_194828.jpg Not real proud of it, if it helps a brother all the better
  19. LuckyOC
    LuckyOC
    What are you wanting for it?
  20. Mr48chev
    Physical size and then being able to repair if needed without having to make an emergency call to have a part shipped red label over night so you can get back on the road are the two main considerations.
    The other consideration is what your personal budget that is no business of the rest of us allows. A complete MSD ready to run 8360 with coil and wires runs 750 from Speedway.
    LuckyOC likes this.
  21. TA DAD
    TA DAD
    from NC
    You could buy one like this that uses points and you adjust the dwell through the window in the cap. And if needed you can add better points or a set of uni-points . Those are where the points and condenser are one unit and easier to change. Or even a factory dual point that you adjust through the cap and just run one set of points. https://www.cl***icindustries.com/p...oho48UX4Y36hhRGF_UEaAnL_EALw_wcB&gclsrc=aw.ds
    LuckyOC likes this.
  22. deucendude
    deucendude
    from norcal
    Just get a early chevy dist. and put a Pertronix unit in it. I have been using them for 30 years. Same on has been in one of my cars for 30 years. Very easy to do.
    Truckdoctor Andy likes this.
  23. rusty1
    rusty1
  24. lumpy 63
    lumpy 63
    I sent you a Pm
  25. Dooley
    Dooley
    from Buffalo NY
    I have the petronix stock look distributor with ignitor iii module and built in rev limiter. looks just like a single point dizzy
    LuckyOC likes this.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    You can buy a new or reman sbc points style distributor from rock auto or other sources for $75 or so , would be period correct , plenty of spark for a mild small block ...
    Unilites aren't a problem , the people using / installing them are , however.
  27. RodStRace
    RodStRace
    @lumpy 63 has you covered for the look and basic around town cruizin and having fun.
    If the plans are plenty of long distance use, I'd want the vacuum advance for more efficiency.
    In either case a set of ignition parts with the lube, a screwdriver and a matchbook (for gap) in the glovebox and you should be golden.
    LuckyOC likes this.
  28. hotrodjack33
    hotrodjack33
    I ran a Mallory Unilite in my old Sedan Deliv. for over 12 years. Always carried an extra cap, rotor and module with me...never had to use them. (Didn't care for the red cap though). 32c.jpg
    Driver50x, LuckyOC and leon bee like this.
  29. rattlecanrods
    rattlecanrods
    LuckyOC and RodStRace like this.
  30. 55blacktie
    55blacktie
    crtperformance.com
    LuckyOC likes this.
